Old 05-11-2009, 12:39 AM   #1
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
Default Do I need engine management?
Ok, so I just purchased a 96 impreza the other day which has a bunch of work done to it and I am having a very problem with the idle. It idles very rough and if I put it into neutral it stalls almost instantly. The car has a lightweight pulley and flywheel, a unknown brand cat back custom headers and a few other power modifications so I believe the cause for the stalling and rough idle is a lack of engine management causing the air/fuel ratio to be off. Do you think I just need engine management?
Thanks,
Luke
97 Pimpreza is offline   Reply With Quote
Old 05-11-2009, 02:27 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No.
45
Old 05-11-2009, 03:10 AM   #3
3barboost
Member#: 73609
2002 wrx
just lift the idle speed at the throttle butterfly with the little screw and nut combo - one or two turns will be all that you need
why overcomplicate things ?
3barboost is offline   Reply With Quote
Old 05-11-2009, 08:11 PM   #4
Blase
Member#: 54702
2000 impreza 2.5rs
brp
check for vaccum leaks and/or loose sensors.
Blase is offline   Reply With Quote
Old 05-12-2009, 02:20 PM   #5
WcW
Member#: 209963
If he has a poor idle and a functioning IAC he needs to solve the problem, not mess up the TB calibration. Subbies use a fully closed TB with near 0 flow so the IAC is designed to do all the metering. If you have a poor idle you need a tuneup. Going to an aftermarket controller to fix a leak or a bad sensor is dumb. Even if you can fix the problem with a mapping tweak the real issue still exists and is going to need fixing. Never put an aftermarket ECU on a poorly running car unless you know why it is running poorly (you changed something) you will waste time and money and tuning will be a huge hassle. Get it right then hot it up.
WcW is offline   Reply With Quote
Do I need engine management? VtecThisWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-05-2004 05:36 PM
do i need Engine Management black Engine Management & Tuning 3 12-07-2002 10:23 AM
do i need Engine Management ? black Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-05-2002 03:23 AM
Turboback, Uppipe, ITG Filter, Switchable MBC... Do I need engine management? treybomb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-14-2002 03:54 AM
When do I NEED engine management? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2002 09:58 AM
