Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 05-11-2009, 09:39 AM   #1
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Default 99 2.5L overheating
My 99 Legacy GT has started to overheat at 113K miles. At first I thought it might be the HG but the symptoms seem different.
It overheats randomly, usually when on the highway. When it overheats the heater blows cold air. At the same time the coolant overflow fills up and spills over. The lower radiator hose is cold and the upper is hot.
I just replaced the thermostat which was definitelly busted...thought that would fix it, but it overheated the same way yesterday.
I am thinking it could be the water pump, but I thought they leaked when going out.
Could a bad radiator cap be causing this?
Thanks
maciek is offline   Reply With Quote
Old 05-11-2009, 11:10 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Are you sure you got all the air out of the cooling system?
~Josh~
Old 05-12-2009, 12:26 AM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
I am pretty sure all the air is gone...it's been weeks since the new thermostat and no overheating until yesterday.
Old 05-12-2009, 01:03 AM   #4
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
If the upper is hot, lower is cold....id take out ur thermostat (possibly bad thermo) and see what happens. It sounds like whats happening is theres an obstruction somewhere, and the question about your water pump, take the cap off and see if coolant moves or not. Long shot here, have u checked your dipstick to see if u have a water jacket crack or blow out? Talking from experience with a fully blue printed motor, and they didnt replace diverter inserts and all the sudden it did the same thing.....hope its your thermostat, GL
rivman05 is offline   Reply With Quote
Old 05-12-2009, 02:14 PM   #5
WcW
Member#: 209963
the problem sounds like classic HG. All the symptoms mentioned were clear HG problems.
WcW is offline   Reply With Quote
Old 05-12-2009, 03:55 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I have a 91 2.2 Legacy and a 98 2.5 outback with the same symptons. It is the headgasket in both of these cars.
2.5L overheating + coolant leak 05co92x Newbies & FAQs 6 06-10-2009 09:24 PM
WTB: MN Area, 97-99 2.5L DOHC longblock MadDogSTi Private 'Wanted' Classifieds 1 07-23-2008 12:20 AM
I need 2 '97-99 2.5L DOHC people for a blind taste test Patrick Olsen New England Impreza Club Forum -- NESIC 18 05-14-2007 05:18 PM
NY: 99 2.5L Forester Engine and intake manifold txl146 Engine/Power/Exhaust 2 09-13-2006 11:12 AM
WTB 99 2.5L Intake Manifold D-Speed 2.5 Private 'Wanted' Classifieds 1 10-19-2003 03:13 PM
