Old 05-11-2009, 10:57 AM   #1
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
Default hybrid question (not hg or cam questions btw)
heres my setup
2.5 with 100mm cps/eagle rods/acl bearings
2.0 heads with cometic .051 hg and sti cams
sr55 w/ forge wg actuator
pe800s
coolingmist stg2
avcr
injen sri
injen fmic(yes i know its too small but am not allowed to get a new one as of right now)
helix dp
greddy evo 2
06 six speed 5-114 w/brembos
i did break in for 750 miles. i had my tuner remove the rev limit he put on during break in. my question is what is safe to rev to(fuel cut is 7400 right now)? by safe i mean 100% no worries what so ever safe. the car is only at 15psi right now on 91 w/o meth. should i stay in the 7500 range?
AWDWRXLOVER is offline   Reply With Quote
Old 05-11-2009, 11:20 AM   #2
25rsti
Member#: 166324
02 V8 Spec C 03
V9 Limited 2013 Legacy
i dont know it all what so ever, but i have done tons of research. From what ive read, our cars (subies) arent built for high revving. Your setup IS built compared to factory setups, but i doubt your going to get much up top anyways. just my .02. Hope some other more experienced members can chime in.
Old 05-11-2009, 01:09 PM   #3
Artie@Agile Auto
Member#: 189490
I would not push it farther then stock rev limit. You do not have anything in your build that will support high rev. Where is your hp peaks?(rpm)
Artie@Agile Auto is offline   Reply With Quote
Old 05-11-2009, 02:00 PM   #4
3MI Racing
Member#: 200987
+2 on both accounts.
I also see you have an 02 and that would mean you have shim over buckets for cam lash...those and high RPM aren't exactly friends
3MI Racing is offline   Reply With Quote
Old 05-11-2009, 03:03 PM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
i havent had it on the dyno yet. should i lower the redline to 7200 then? the car is daily driver and must be reliable so im not worried about maxing it out anyways.
Old 05-11-2009, 03:35 PM   #6
Gixxer1K
Member#: 81631
stage 11
How do you figure that? My bike motors all have shim over bucket.
Gixxer1K is offline   Reply With Quote
Old 05-11-2009, 03:39 PM   #7
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
And they have a lot lighter valvetrains and they are not Subaru motors.
kellygnsd is online now   Reply With Quote
Old 05-11-2009, 03:53 PM   #8
Artie@Agile Auto
Member#: 189490
Very good question. As long as there is no valve floating, shim over bucket is OK. However people will switch to shimless buckets to reduce weight of the valve tain thus being able to rev higher.
Artie
Strange WRX Hybrid Noise, not ticking or knocking. alex02wrx Built Motor Discussion 3 12-10-2009 04:32 PM
building a hybrid..cam question. ricky05 Built Motor Discussion 14 09-29-2008 08:32 PM
Hybrid build not reaching or holding target boost. Starch Built Motor Discussion 4 09-10-2008 05:22 PM
2.5L hybrid, retarding intake cams question Turbo_Mike Built Motor Discussion 20 01-06-2008 02:56 AM
Hybrid Cams Question thejean Built Motor Discussion 8 01-16-2007 09:29 PM
Message Board Statistics All times are GMT -4. The time now is 09:54 PM.
