Old 05-11-2009, 12:04 PM   #1
Mike_Subaru
Member#: 189378
Default Bent Valves Question....
My Timing belt skipped after the Vibration Damper seperated. The Dampner, seperated at the rubber (5 years old and 110,000 miles) and the pully part of it, slipped into the Timing cover, melting the plastic, and the plastic get into the timing belt, causing the skip.
All 8 of the exhast valves are bent.
2002 - 2.5 - Non turbo.
The pistons have tiny impact marks (fingernail size and shape) barely 1/4 in long, and maybe 1/16 inches deep into the piston.
Any worry here, or does anyone have EXPERIANCE with the rods being damaged ( twisted) from the impact?
Any other info, or "Watch-out for's" that I should be watching out for?
I will have the valve guides inspected for cracking, and I will also be installing new Intake Valves too.
I will be using a new Perrin Pully, have one on my other two Subaru's, and I love them.
Thanks in advance. Mike
Mike_Subaru is offline   Reply With Quote
Old 05-11-2009, 12:51 PM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
the only damage I have seen from this kind of failure has been isolated to the valves. I haven't seen any bottom end damage.
crampfan is offline   Reply With Quote
Old 05-11-2009, 06:46 PM   #3
GrundleJuice
Member#: 165749
just replace the guides... even if they are not cracked they will be out of spec dimensionally and may lead to oil consumption to be on the conservative side. premature valve wear, bad sealing, etc etc are also likely. The parts are reasonably cheap and with the heads out to do the valve job, labor will be next to nothing.
GrundleJuice is online now   Reply With Quote
Quick bent valve Question (engine in crash) DHRDAN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-29-2009 11:01 AM
Bent/damaged valve question drfrink24 Pre-2002 Factory Turbo Powertrain 3 10-12-2007 11:01 AM
Bent Valves....Expense overrated? elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-02-2004 03:54 PM
How 2 check 4 bent valves? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-26-2003 06:23 PM
WRX w/ Bent valves need advise cky211 Service & Maintenance 10 02-05-2003 04:55 PM
