Welcome to the North American Subaru Impreza Owners Club Sunday December 28, 2014
Old 05-19-2009, 11:02 AM   #26
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Intake and Cutout look good! you running friday night?
cnstman is offline   Reply With Quote
Old 05-19-2009, 11:29 AM   #27
GeneralTJI
Member#: 152680
I Parted out WRX
for my Pilots License :)
At that sea level you got 11's man easily. Do what I do....go through the water box. Get to the line back up and mini launch to sling the heavy water off. Then give er all ya got! You want those tires to spin but I understand with a big turbo it's hard!
Thanks for the info. I will try this if I have trouble again. How did you make enough power on a stock 205 to trap 124 without blowing that sob up? Weight reduction?
Thanks! ...
Yea buddy! .. if the weather holds.. seems we might get some rain (only on the weekends ) Thanks for the info the other day btw, I took my block to Rocky Mountain to get it bored for my CP's.. then I can start slapping parts in it!
GeneralTJI is offline   Reply With Quote
Old 05-19-2009, 11:31 AM   #28
cnstman
Member#: 9548
2004 WRX STi
Originally Posted by GeneralTJI View Post
Thanks! ...
Stan is the man
Old 05-19-2009, 12:36 PM   #29
CatfaceType-R
Member#: 81102
ahh, i remember this car
how many lb/min is that holset turbo?
awesome mileage for a large hp motor
CatfaceType-R is online now   Reply With Quote
Old 05-19-2009, 01:28 PM   #30
GeneralTJI
Member#: 152680
I Parted out WRX
From what I understand it has a 60lb compressor... the 9cm exhaust housing might make it hard to get all 60 out of it though... probably 55-57 (just a guess).
Old 05-19-2009, 01:31 PM   #31
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I have some weight reduction but nothing drastic. Car weighs 3030 lbs with me in it and I weigh 190 lbs when the car is drag strip prepped. I take all seats out, take sti wing off and other things.
CoolRex is offline   Reply With Quote
Old 05-19-2009, 01:39 PM   #32
GeneralTJI
Member#: 152680
I Parted out WRX
Man thats impressive. I don't see mine holding out much longer, and it would be lucky to trap 118. 124 is screaming!
Old 05-19-2009, 01:41 PM   #33
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I'm boosting 26-27 psi on my car daily. I alter it enough to lean out and boost 29-30ish at the strip thanks to a special drag map. Stock EJ205 and stock internals. And the car has 134,000 miles on it.
Old 05-19-2009, 01:53 PM   #34
GeneralTJI
Member#: 152680
I Parted out WRX
And I thought when I ran my old t3/t4 setup at 28psi through a couple gears I was brave.
Very cool. Period.
Old 05-19-2009, 01:54 PM   #35
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Heh you are cool
I have this Ej257 sitting here and it talks to me every night.....but my original love just won't die.
Old 05-19-2009, 02:06 PM   #36
GeneralTJI
Member#: 152680
I Parted out WRX
At least your prepared, thats the main thing... never know, maybe you will get sick of waiting and just pull the 205.
Old 05-19-2009, 02:08 PM   #37
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Not that simple.....I still have to throw some forged pistons in but we're getting off subject here.
Go crack that 11!
Old 05-19-2009, 02:10 PM   #38
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
It surprises me that you're nearing the limiter in 4th at under 120. Unless my brain isn't working properly today, I though you could run closer to 130 in 4th on the 07 trans....
Audiosavvy is offline   Reply With Quote
Old 05-19-2009, 02:12 PM   #39
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Nope....4th runs out at ~118 mph at 7K rpms on the 07 trans where the previous years 4th ran out at like 100 mph.
Old 05-19-2009, 03:16 PM   #40
GeneralTJI
Member#: 152680
I Parted out WRX
Yea it thought I could squeeze out slightly higher traps with the 07.. but I was hitting my 7300 limiter just past the line. Going to need those cams!
5th is more of a 4.5.... but it would be nice not to have to make another shift that close to the line.
Old 05-19-2009, 04:34 PM   #41
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
And that's going by the speedometer which is about 5-7mph off at those speeds. To truely trap 118mph you'll need 5th gear.
04-06 STI needed 5th to hit 100mph using the factory redline of 7k.
Steve.804 is offline   Reply With Quote
Old 05-19-2009, 04:50 PM   #42
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Cool, ive seen a few of your posts before but never knew you were on the stock motor, thats just rediculous man, good for you. As far as the 07 trans, from the factory it is supposedly good for 113 in fourth.
One uncrowded day at the track I played around to see how much the trans actually helps. I had a set of bald tires, and ran fourth out to 7400 and only trapped 114. With another set of brand new tires I would trap 113-114 at 6900. My speedo also tells me im crossing the traps at 118-122, and we all know that is pretty much impossible for a stock turbo STi to do.
STi Mikey is offline   Reply With Quote
Old 05-19-2009, 05:06 PM   #43
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
When i was just at california speedway and got a clean run in I was pretty phsyched before i got my timeslip. Speedo was showing ~117mph when i cross the line, trap speed on the slip was 110mph
My speedo is ~5mph off even down around 40-45 mph. I always notice it when they have the police "Your current speed is" machines on the side of the road.
Old 05-19-2009, 06:46 PM   #44
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Good to know, thanks. For some reason I thought it was higher, I'll blame someone else
Old 05-19-2009, 09:47 PM   #45
GeneralTJI
Member#: 152680
I Parted out WRX
With cams it would be
Or you could just over rev the piss out of it
Old 05-20-2009, 02:46 AM   #46
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Ya, my future will include cams with V8 JDM STi heads (with AVCS), AEM EMS, and probably a set of 272/272 Kelfords, 280 at the largest. The motor I'm running was run out well over 9k by ESX (it's their design, they ran it to 9500 if I recall correctly), so with a small enough cam to make it subtle and very streetable, I don't see any reason why we can't take it out to 8500 with the turbo I intend to eventually run (3076ish, maybe slightly larger). At 8500 with a 255/40/27, I think it would be right at the limiter with a mid-11 run
I've put a lot of thought into it, and the transmission is the next step (as I recently turned my 5-speed into a 4-speed ), so I have plan my future trap speeds so that I get a transmission that suits it best.
Old 05-21-2009, 02:11 AM   #47
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Wow man I always knew you were a nut! Chasing you any further into the 11s is pointless for my skinnygearedness,....
This sounds nice to me oh Auditory one
jmlaser is offline   Reply With Quote
Old 05-21-2009, 03:17 AM   #48
WRX Harvey
Member#: 13025
1998 RS-T
Rally Blue
Great work man. I read your webspace blog on the project and I am amazed. I run the dyno here at SuperRupair in Boulder and would give you a break on any dyno time you need.
WRX Harvey is offline   Reply With Quote
Old 05-21-2009, 11:58 AM   #49
GeneralTJI
Member#: 152680
I Parted out WRX
Wow Harvey, thats awesome.. thank you!!!
Would like to get it on a dyno at some point... btw, what kind of dyno do you guys have.. I didn't see it mentioned on your site. thanks again,
-Todd
Old 05-21-2009, 12:02 PM   #50
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I've logged 122 in 4th gear.
wrxwhat is offline   Reply With Quote
Couple subbys at the track e2blade Member's Car Gallery 12 02-09-2010 02:00 PM
A couple pics from the track in my 06 bhhamblin Member's Car Gallery 31 03-14-2008 02:24 PM
looking to get the timebomb faster down the track... OMG_WTF Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 11-29-2007 05:34 PM
06-07 Forester XT 5mt power handling limits? And a couple Qs about the recent 5MTs Davenow Transmission (AT/MT) & Driveline 12 05-03-2007 12:30 AM
('93-'01) Saw a couple WRXs at the track last night TTA89 Impreza Forum 3 08-09-2001 04:50 PM
