Old 05-11-2009, 12:48 PM   #1
OutbacKid
Member#: 211048
Unhappy 98 outback engine swap
So here is my dilema I have a rod knocking on my 98 outback and so I am goig to need to replace my engine. I will have the work done at my dads shop so everything will be much cheaper than anywhere else. But I was wondering if it would be worth it to put a wrx engine in instead of the same thing. My dads main concercn is the ammount of time that one of his mechanics is going to have to spend on my car instead of a paying customers car. So what I want to know is has anyone done it and how much extra work would it be instead of replacing with the same thing.
OutbacKid is offline   Reply With Quote
Old 05-11-2009, 01:13 PM   #2
Member#: 189490
It's time consuming will require replacing harness and ECU.
BTW Subaru offer a remanufactured short blocks for your car, it's comes with oil pump, water pump, oil pan etc.
Artie@Agile Auto is offline   Reply With Quote
Old 05-11-2009, 01:42 PM   #3
3MI Racing
Member#: 200987
The Phase 1 DOHC EJ25's are well known for two things. Headgasket failures and eating rod bearings.
The rod bearings fail because they are infact narrower than stand EJ series rod bearings. That is the ultimate issue that you could run into again. I still wonder what subaru was thinking when they put in a heavier piston, short rod ratio and narrower rod bearing
I'm assuming the car is pretty much stock however...?
3MI Racing is offline   Reply With Quote
Old 05-11-2009, 02:23 PM   #4
OutbacKid
Member#: 211048
Yea everything is still stock I have replaced the heads twice already (the car has 233k miles) I think I should just say forget it and buy a new car but my dad says I should just replace the motor because I can't afford the wrx I want so that's where I got the idea to put a wrx motor in it.
Old 05-11-2009, 02:59 PM   #5
3MI Racing
Member#: 200987
If you have the time and money a swap would save a lot of time and money over the WRX; especially with insurance.
I never did ask, is this an outback or an outback sport?
Old 05-11-2009, 03:08 PM   #6
OutbacKid
Member#: 211048
It's the legacy outback
Old 05-12-2009, 08:03 PM   #7
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
A WRX swap isn't something that 'one of your dad's mechanics' is going to be able to handle, because of the wiring involved. Throw another ej25 in there and call it a day.
Dan Cech is offline   Reply With Quote
98 forester engine swap jstrm Newbies & FAQs 3 10-03-2009 11:28 AM
Outback engine swap illuzion-atrix Outback Forum 1 10-10-2007 10:49 PM
98 Outback Legacy Engine Swap question johnnnnny5 Subaru Conversions 2 09-13-2007 08:41 AM
Outback engine swap? Balr14 General Community 13 05-18-2006 12:55 AM
98 Forester Engine Swap--which one 2002WRX_5speed Subaru Conversions 8 05-19-2005 02:54 PM
