Old 05-11-2009, 07:07 PM   #1
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
Default remove HVAC Deck?
How easy is it to remove the HVAC "deck" itself? I see a couple of connections when the radio is out. What else is there holding the system in?
jmonty is offline   Reply With Quote
Old 05-13-2009, 07:25 PM   #2
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
bump anyone?
Old 05-16-2009, 01:59 PM   #3
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
Has anyone taken the thing out?
Old 05-23-2009, 10:09 AM   #4
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
before I try this weekend one last bump up
Old 05-23-2009, 10:31 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There are mechanical cables for the mode and temp controls.
Old 05-24-2009, 02:16 AM   #6
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Remove the screws in front (very easy).
Two electrical plugs on the back (easy).
Two metal cables on the top and one on the underside (not as easy).
Then you'll be able to pull the assembly out. The cables are kind of tricky to put back on as well.
khail19 is offline   Reply With Quote
Old 05-25-2009, 01:27 AM   #7
jmonty
Member#: 97716
2013 BRZ GBS LTD
Outback Ltd
thanks I will give it a try
How to remove HVAC to clean? BeBop86 Newbies & FAQs 10 12-05-2007 08:10 PM
How to remove HVAC/Radio cover for 06 WRX some dude Electrical & Lighting 10 04-17-2006 07:56 AM
Removing HVAC , stereo bezel ?? Matty Car Audio, Video & Security 3 11-20-2003 01:15 PM
how to remove HVAC kenchan Interior & Exterior Modification 3 02-06-2003 11:15 AM
Removing HVAC bulbs chrisdeaner Newbies & FAQs 3 11-30-2002 04:50 PM
