Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 04-21-2002, 02:30 PM   #1
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Omori P107 1DIN gauge panel
The first thing you should be aware of is that this will not fit the Subaru OEM gauge housing without modification.
That said, I am the most inexperienced DIYer on the face of the planet, and I was able to make it fit and not hack it up too badly.
What you have to do is remove the 1mm lip on the top and bottom of the panel (leave the sides alone). I used a utility knife/blade and whittled it off like I was working on a piece of wood. It took me 20 minutes to do the top and bottom cleanly. Go slowly and take your time. While you're technically always supposed to cut away from you, I found that doing the whittling as you see in the picture below you get a lot of control (you obviously have your other hand at your disposal as well, but I had to take the pic somehow )
Stage 2 is to attach the brass-colored plates to the plastic panel with the allen-head screws. Then slide the plates through the front of your Subaru OEM housing and see what happens. For me, with a good 3mm left to go before the P107 was flat against the front face of the housing/hood, the plates/sides that I just attached began moving toward each other the more I pushed the panel toward flush and the center of the P107 itself started bowing out of the mouth/front of the hood. It was clear that more material needed to be removed. For me, the side plates were rubbing at all 4 points against the main housing opening sides. Go slowly and start removing material from the housing itself at the appropriate inner opening corners if you have this same problem. Check your fit every few minutes so that you don't remove too much material from the housing opening (I did on one side ). The plastic is significantly harder than the P107 itself, so expect to spend the next hour carefully working on it. I used a rat-tail file and a utility knife until the center of the P107 that bowed out toward the cabin (once it's in your car) was not noticeable and there weren't any really visible gaps created by what little bowing there was.
Just be aware that it's not a drop-in setup is all... bleah.
jblaine is offline   Reply With Quote
Old 09-02-2002, 09:52 AM   #2
paul99se
Member#: 17822
Bumpin' this for saving me much time and hassle this morning. The hobby knife approach is smooth and easy to control. I do not think a dremel (my other plan) would've worked out as well.
paul99se is offline   Reply With Quote
Old 09-02-2002, 06:32 PM   #3
Supapooh
Member Sales Rating: (5)
Member#: 4461
02 2.slow
Where would one find this panel???
Supapooh is offline   Reply With Quote
Old 09-03-2002, 01:16 AM   #4
tokigiracing
Vendor
Vendor Sales Rating: (0)
Member#: 15567
you can get it all direct from Omori ---> www.omori-na.com
tokigiracing is offline   Reply With Quote
Old 09-03-2002, 09:52 PM   #5
PSMWRX
Member Sales Rating: (7)
Member#: 21030
What does that din panel cost? Very interested in one.
PSMWRX is offline   Reply With Quote
Old 09-06-2002, 03:45 PM   #6
paul99se
Member#: 17822
Default Cost?
Somewhere between $35 and $50 IIRC.
Old 09-07-2002, 02:33 PM   #7
blubaru
Member#: 13001
1)Carving not required. If you look closely at back of the panel, a slight groove is molded at the base of the 1mm lips. You only need to make several passes in the groove with your knife then bend the lip to break off very cleanly.
2)Use 1/4" spacers and longer bolts and mounting brackets will fit behind front edge of pod cover requiring no mods to cover. Use countersunk bolts for an even cleaner look.
blubaru is offline   Reply With Quote
Old 09-26-2002, 04:27 PM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Okay, I just wanted to update this thread.
I took the housing and panel-with-gauges apart 2 months ago and redid the whole thing.
This is so hard to explain without pictures. Bah.
Originally, I had it all set up by (step by step)
1. Screwing the Subaru gauge housing metal bracket down
2. Routing the gauge wires through the Subaru gauge housing "mouth"
3. Snapping the Subaru gauge housing in place (with wires and vacuum hose hanging out of its mouth now)
4. Hooking the Omori panel side brackets to the Omori panel + gauges with the allen-head screws
5. Hooking up the wires and vacuum hose to the gauges
6. Sliding the whole assembly in the mouth of the Subaru gauge housing.
This is how I saw someone say they had done it in a separate thread (search for "Omori panel" and username jblaine and you should find a big nasty thread on the topic).
It's all pretty confusing (to me at least -- I'm not used to dealing with this custom tweak crap ), and this left the gauges + panel + brackets moveable and not 100% sturdy. It really was pretty okay, but not acceptable to me. The fit was snug.
NOW, I redid it all, listed below as if starting from scratch. This is how I assume most sane and experienced people went about it:
1. Screw the Subaru gauge housing metal bracket down
2. Attach the Omori side brackets to the Subaru metal bracket instead of the to the Omori panel and tighten that stuff down 95%. Now here's the tricky part of this step. Since the Omori side brackets have elongated screw holes instead of circular ones, you can slide the brackets in and out an inch or two for adjustability (toward engine and toward trunk = in and out). You need to bolt them in so that they will be in the right position for you to snap the Subaru gauge housing in place and then attach the Omori panel to the forward facing ends of the Omori side brackets with the allen-head screws.
3. Run the wires through the mouth of the Subaru housing and snap it into place so they're hanging out of its mouth now
4. Attach the wires to the Omori panel + gauges "chunk"
5. Screw the Omori panel + gauges chunk to the forward-facing ends of the Omori brackets which are now inside (to the left and right) the whole assembly.
6. Now redo everything 6 times until it's just right, and before you put the gauge housing into place the last time, tighten those Omori side brackets to the Subaru gauge housing metal piece very tightly (otherwise they will vibrate loose, regardless of the lockwashers).
Whew. Now you have a rock solid assembly.
Screw this car modding crap
EDIT: Also, if I had to do it allll over again, I would
1. Take the Omori side brackets and throw them over my shoulder, stand them up in the garden as Scarebrackets, or tape them together to use as a make-believe cell phone
2. Make a custom plastic faceplate for the Subaru gauge housing that covers the entire opening except where the gauges need to go through in the center (while they're attached to the Omori panel)
3. Install the Subaru gauge housing metal bracket and install the Subaru gauge housing itself, with wires hanging out of its mouth
4. Attach the custom faceplate with some form of adhesive that can tolerate car temperatures
5. Attach the wires and vacuum hose to the gauges
6. Screw (or use a strong adhesive) the Omori panel + gauges to the custom faceplate.
7. Now the whole unit (housing + custom faceplate + panel + gauges is ONE ITEM that can be pulled out just like you pulled the clock out and disconnected it -- like an OEM gauge pack)
Old 09-26-2002, 06:12 PM   #9
blubaru
Member#: 13001
Yeah it was kind of a pain in the a$$ wasn't it.
Old 09-26-2002, 08:29 PM   #10
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Thank god, I thought I was just a moron struggling with it all. Good to know I wasn't alone
Old 09-27-2002, 09:10 PM   #11
wrxmontao!!
Member#: 14826
2002 wrx
do you guys have any pictures I'm thinking about buying this gauges.....also how much did you pay for the set up? I want boost, egt and oil pressure.
Pedro
wrxmontao!! is offline   Reply With Quote
Old 10-08-2002, 02:34 PM   #12
CirrusWRX
Member Sales Rating: (4)
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Great info - book marking it cause I'm going to have to do it soon too!
CirrusWRX is offline   Reply With Quote
Old 10-08-2002, 02:57 PM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Pedro, sorry I didn't see your post until now. For some reason I didn't get emailed that you had posted. You can see pics here at the Omori North America site. Mine looks just like that.
Off the top of my head, I seem to remember my mechanical boost, electrical EGT, electrical oil temperature gauges, and P107 DIN panel costing something like $650. The Subaru OEM gauge housing is $65 or so on top of that. Those prices are from around 4/2002 direct from Omori NA.
Old 10-08-2002, 05:23 PM   #14
blubaru
Member#: 13001
Thumbs up
Got mine from the Malaysian site -- just over $400 shipped for the three gauges and DIN panel. Took 6 weeks from mailing a money order to a box at my door. They honor the warranty to, just have to ship to Japan for repair. Don't hesitate to post or email any questions on the install -- there is a lot of stuff you have to figure out the first time through.
Old 10-26-2002, 07:20 AM   #15
racerx7
Member#: 25942
2004 wrx wagon
black
I have several guages on order from the Malaysian since July 23. It was only suppose to take three weeks. Still nothing yet. At least they reply to my
emails fast.
racerx7 is offline   Reply With Quote
Old 11-06-2002, 04:08 PM   #16
mca
Member Sales Rating: (1)
Member#: 5447
2002 95 Integra GS-R
92 Sentra SE-R, 90 Miata
I have the same setup with three gauges and the P107 DIN panel with Subaru gauge pod.
I don't understand what all the fuss is about. The install really wasn't that hard. The Subaru gauge pod and Omori P107 panel did not fit *perfectly*, but there was a very small amount of material to be removed at eh corners. When I say small I mean much less than 1mm, easily removed with a file or sandpaper.
Other than that minor modification, the install went quickly. It is easier to assemble the metal mounting brackets and gauges off the car, then put the whole assembly in at once. I found it easiest to assemble the Omori side brackets and DIN panel together, mount the gauges to the panel, then mount the gauage assembly to the Subaru bracket. Then you can place the gauge pod housing onto the assembly to make sure the DIN panel lines up with the opening. Then you mount the Subaru bracket to the car with the 4 provided screws.
I found that it took much longer to run all the sensor wires into the firewall and up to the housing than it took to mount the actual housing.
If anyone needs any help with the install, please feel free to PM or email me with questions.
Aaron
mca is offline   Reply With Quote
Old 11-16-2002, 06:42 PM   #17
jagwoods
Member#: 24179
2009 Mazdaspeed3
Does anyone know if these instructions work for the P105?
Jay
jagwoods is offline   Reply With Quote
Old 11-16-2002, 07:54 PM   #18
blubaru
Member#: 13001
P105 is for the 52mm gauges, right? Won't fit the dashpod. Will fit in the dash but you're gonna have to swap the stock sounds for a single DIN.
Old 11-16-2002, 08:06 PM   #19
fuzzy13
Member#: 14178
2002 WRX Sedan
Platnium Silver Metallic
Jay
The won't work as the P105 panel is metal. I'm modifing the OEM pod to accept the P105 (almost there).
fuzzy13 is offline   Reply With Quote
Old 12-13-2002, 01:20 AM   #20
WRXVII
Member#: 15854
VF34'd...
guys.... I have aftermarket indash player so P105 will work with it? Please let me know where I can order it. It will be a perfect fitment or will require some modification to fit?
Thanks
Tim
WRXVII is offline   Reply With Quote
WTT: 45mm EGT omori gauge for 52mm Omori oil pressure gauge (NY) gopsu Interior/Dressup/Audio & Security 0 08-29-2009 11:17 PM
Gauging Interest: Omori Full Color Gauges with DEFI hood EdsWRX Private 'For Sale' Classifieds 13 03-07-2006 10:09 AM
OEM Gauge Pod (52mm) & Omori Oil Temp Gauge 52mm WRXerist Private 'For Sale' Classifieds 13 10-06-2004 12:36 AM
Omori WRX look gauges and gauge pod willib Private 'For Sale' Classifieds 18 09-04-2004 10:58 AM
Anyone done the stock column gauge housing and and omori 43 mm gauge? WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-19-2002 02:15 AM
