Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Notices
Old 05-11-2009, 11:07 PM   #1
PitwrkzZ1
Member#: 94316
Default Curious-what are your oil/coolant temps?
I know it doesn't make a huge difference with short autox runs, but what is everyone seeing as far oil and coolant temps at autox? I have the stock gauge pack in my 02 and at my most recent cone dodging session, I saw temps just below 100 degrees Celsius on a very very hot afternoon in New Jersey. Ambient temps were probably in the mid 90s. This is much higher than I've ever seen on the street, where I'll see maybe 90 degrees Celsius on a hot summer day idling in traffic at Lime Rock. As for coolant, I don't yet have a way to measure it beyond the useless cluster gauge.
PitwrkzZ1 is offline   Reply With Quote
Old 05-12-2009, 12:38 AM   #2
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I see 220-230 oil temp on hot days (except now, the gauge is pegged at 260 even when the car is cold because it is borked). I don't have a non-OE coolant gauge.
Do you have the probe in the drain bolt or at the top of the engine? The temps read higher, and more consistently, in the galley.
Old 05-12-2009, 10:17 AM   #3
PitwrkzZ1
Member#: 94316
I have the OEM drain bolt sensor. Are you talking *F or *C?
Old 05-12-2009, 07:04 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
F, sorry.
I had it in the drain bolt first and later switched to the galley. The drain bolt is a bad location but better than nothing.
What is your Oil Temp? Stames_wiltz Rocky Mountains Impreza Club Forum -- RMIC 14 05-03-2010 01:03 PM
Tell me how hot your oil/coolant gets. Not sure if mine are normal or not. lennyTR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-06-2009 11:29 PM
What are your egt's @ idle. Trying to figure temp differences w/ probe location. MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-03-2008 04:19 AM
What are your oil pressure and temperature readings, what do you like to see? 02R6 Built Motor Discussion 4 10-23-2006 07:10 PM
What is your Oil Temp? cantex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-12-2002 10:17 PM
