Old 05-20-2009, 01:33 AM   #1
bigjoshsubyfan
Member#: 193332
Default 98 RS running rich
I just put a new motor in my 98 RS the motor was from a leggy GT and is also a 2.5 dohc but its running rich and won't idle I replaced the long block but not in the intake manifold I can smell gas and i know i have an exhaust leak on the header so any ideas as to why its running rich thanks
bigjoshsubyfan is offline   Reply With Quote
Old 05-20-2009, 12:55 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
the 98 rs had a dohc?
watchunglava is offline   Reply With Quote
Old 05-20-2009, 02:04 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
is this just based on the gas smell are you actually logging AFR? are we talking closed loop or open loop?
if the exhaust is leaking in the vicinity of the O2 sensor I think that can throw off the reading e.g. the sensor reads lean because of the exhaust and the ECU compensates by adding fuel
UkNuck is offline   Reply With Quote
Old 05-20-2009, 06:38 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
wow, that was just one big run-on sentence. And yes, the 98 had DOHC.
yarrgh is offline   Reply With Quote
Old 05-20-2009, 10:44 PM   #5
bigjoshsubyfan
Member#: 193332
yeah i do have an exhaust leek at the headers would that make it that bad though?
Old 05-20-2009, 11:53 PM   #6
bigjoshsubyfan
Member#: 193332
well its running better still way rich but i fixed the exhaust leak reset the ECU and i'll try agains tomorrow so if anyone has futher sugestions i'm still looking for some help thanks
Old 05-21-2009, 10:45 AM   #7
bigjoshsubyfan
Member#: 193332
bump still really rich runs fine at higher rms and on the first start up will idle very poorly for a while then chokes out
Old 05-21-2009, 07:16 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
how are you diagnosing that its rich?
Old 05-22-2009, 01:39 AM   #9
bigjoshsubyfan
Member#: 193332
well theres alot of unburnt gas coming out and it smells bad and then theres the smoke and also the spark plugs where wet when i pulled them out and the where brand now and now have tons of build up so any help please
Old 05-24-2009, 09:58 AM   #10
bigjoshsubyfan
Member#: 193332
bumop for new ideas???
Old 05-24-2009, 11:41 AM   #11
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you may have injectors that are stuck open. Your O2 sensor may be crappy and telling the ECU that you're running lean, causing it to fuel more. Have you cleaned your MAF sensor lately?
Old 05-24-2009, 01:10 PM   #12
bigjoshsubyfan
Member#: 193332
MAF and 02's were you of the car for a while the 02 and the whole exhaust where sitting in the back yard for a while so those need to be checked and the MAF was sitting in the trunk for about a month so i'll clean that up too
Old 05-24-2009, 01:47 PM   #13
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I'd replace the O2 if it was sitting in the elements, especially if it rained. moisture on the O2 sensor is bad when its not energized and fatal when its energized.
Old 05-24-2009, 02:46 PM   #14
bigjoshsubyfan
Member#: 193332
I don't think it was ever exposed but i'll take a really good look at it and living in utah there isn't much moisture thanks though if you think of anything else please let me know the more things i eliminate the fewer things there are to check lol
Old 05-26-2009, 07:13 PM   #15
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
even if you dont see anything wrong visibly, you should test it. Find out what the P/N is any do some searching for how to test it. It is one of a few likely causes for your troubles.
Old 05-27-2009, 11:03 AM   #16
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Replace the front O2 sensor and see what happens.
If not fixed, clean MAF sensor and see what happens.
If not fixed, start looking at injectors to see if one is seized open and pumping gas into the cylinder.
AJ711 is offline   Reply With Quote
Old 05-27-2009, 06:38 PM   #17
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The old shotgun approach... usually works eventually and costs you a bunch of $... but at least you get to replace old working parts with new working parts.
Got my 98 RS running fishheadback Member's Car Gallery 11 06-27-2006 06:48 PM
Got my 98 RS running fishheadback Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-27-2006 04:45 PM
01 rs kinda hesistating...running rich maybe? newbiescooby2.5rs Normally Aspirated Powertrain 3 04-06-2006 12:19 PM
Anyone running EManage on a 98 RS Tattoo Collector Normally Aspirated Powertrain 11 09-12-2005 09:01 PM
Running rich- very rich Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 19 04-12-2003 08:11 PM
