Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 05-12-2009, 04:32 PM   #1
mikemikeburke
Member#: 158194
2013 WRX Sedan
Default Power window problems?
Ok well i have some problems with my power windows and ive been researching the forums to find it out but no good answers yet.
All of my motors are good cause all of them will roll down and back up. Problem is my master panel will roll down all the windows except the driver side back window, you have to use the switch on that door to roll it up and down. The passenger side front window switch doesnt work at all and the back passenger side door works sometimes.
I have checked fuses and relays so i dont know if i missing out on anything. hopefully someone may have some insight on this thanks...
mikemikeburke is offline   Reply With Quote
Old 05-12-2009, 04:52 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would look for a problem with the switch in the main control panel for rear driver side window. The passenger side problem may be due to dirty switches in the door or broken wires in the door jam. Some folks have cleaned the switch contacts and fixed the trouble. If you do that take the switches apart in a clear plastic bag. There are springs inside that can fly when the switch is opened up.
Old 05-12-2009, 04:56 PM   #3
mikemikeburke
Member#: 158194
2013 WRX Sedan
ok are you talking about the plastic switch itself or the switch board on the underside?
Old 05-13-2009, 09:27 PM   #4
Cougar4
Member#: 53443
Winestone
The contacts inside of the switch.
Power window problem jimbo1972 Electrical & Lighting 1 03-01-2004 01:06 AM
GC8 power window problem squeeks Electrical & Lighting 4 07-21-2003 06:40 PM
Power window problem ilmaestro Service & Maintenance 2 03-29-2002 12:35 PM
power window problem funkadellic69 Service & Maintenance 2 03-24-2002 12:44 PM
Power Windows Problem funkadellic69 General Community 4 03-18-2002 09:31 AM
