Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Non-Subaru Stuff
Old 05-12-2009, 06:07 PM   #1
twinbrd
Member#: 37225
2003 Dodge Ram
Default FS: Monitor Audio- GS60 Pair and GS LCR Center- Piano Black- Flawless!
These are listed on CL as well, not getting too much of a response, they are very high end. Will take best offer...
$2,500 for the pair if purchased without the center
The Gold Signature 60 is the most accomplished performer in the Gold Signature range boasting a wide frequency range of 28Hz-to-43kHz. It incorporates advanced, low-resonance drivers, a rigid build, and smooth contoured cabinets available in a selection of premium wood and lacquer finishes.
The GS60 features new low-distortion 6˝-inch C-CAM (Ceramic Coated Aluminum Magnesium) woofer and midrange drivers with RST (Rigid Surface Technology) and a new 1-inch C-CAM gold dome tweeter developed especially for the Gold Signature range.
This two-and-a-half way, four-driver configuration is built around a unique dual-cavity cabinet design, in which the dual 6˝-inch woofers and the midrange driver work in separate enclosures, tuned to different frequencies and impedances. This provides high power handling and delivers fast, deep, and more dynamic bass with great transparency through the critical mid-range.
Specification
Frequency Response: 28 Hz - 43 KHz
Sensitivity ([email protected]): 90 dB
Nominal Impedance: 6 Ohms
Maximum S.P.L
(Per pair in room): 112.5 dBA
Power Handling (RMS): 200 W
Recommended Amplifier Requirements (RMS): 60 - 200 W
Bass Alignment: Sealed Mid-Range Enclosure. Dual Chamber Bass Reflex with Differential Tuning (HiVe®II Technology)
Tweeter Crossover Frequency: 2.7 KHz
Bass Crossover Frequency: 150 Hz
Drive Unit Complement: 2 x 6” RST®II bass driver
1 x 6” RST®II mid driver
1 x 1” (25 mm) gold dome C-CAM® tweeter
External Dimensions: Excluding Plinth
H x W x D) 1060 x 206 x 330mm
(41 3/4 x 8 1/8 x 13 inch)
Including Plinth
(H x W x D) 1070 x 322 x 403mm
(42 1/8 x 12 11/16 x 15 7/8 inch)
Weight (Including Plinth): 27.1 Kg (59.7 lb)
AND
$600 for this center if purchased separatley.
Speaker: GS LCR
Type: Two-way
Tweeter (size in inches, type): 1, ceramic-coated aluminum/magnesium alloy dome
Mid/Woofer (size in inches, type): -
Woofer (size in inches, type): 6.5, ceramic-coated aluminum/magnesium alloy cone (2)
Nominal Impedance (ohms): 8
Recommended Amp Power: 40–150 watts
Available Finishes: Santos Rosewood, Walnut, Cherry, Piano Black
Dimensions (H x W x D, inches): 8.1 x 22.1 x 9.1
Weight (pounds): 27.5
I also have a Thiel Model MCS1 Black Center channel that I am asking $1,500 for.
twinbrd is offline   Reply With Quote
FS: JL Audio 500/1 and JL Audio 10W6v2 w/ JL enclosure FujiFast NESIC Private Classifieds 8 10-03-2008 11:44 PM
FS: JL Audio 10W6v2 Sub and HO1010R JL's High Output box RexTuner1204 Interior/Dressup/Audio & Security 3 03-17-2008 10:51 AM
FS: Car Audio - (Cadence Amp and bass shakers) Andrew Interior/Dressup/Audio & Security 0 09-23-2007 07:27 PM
FS: Diamond Audio 12" sub and RF 900W Amp!! AzSandSlinger South West Impreza Club Forum -- SWIC 0 11-12-2005 01:45 AM
NJ: FS: JL Audio 500/1 and 300/4 NIB MattNJ2.8 Private 'For Sale' Classifieds 5 04-12-2005 10:26 PM
