Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-12-2009, 06:35 PM   #1
invisiblecity
Member#: 141093
2007 Impreza Outback
Garnet Red Pearl
Default Fog Light Bulb Replacement 07 OBS
Anyone have a quick easy way to replace my non-working fog lamp bulbs?
I have a 07 Outback Sport.
invisiblecity is offline   Reply With Quote
Old 05-31-2009, 10:02 PM   #2
b154wheel
Member#: 206874
2010 Impreza WRX
Is a fuse possibly blown, bad switch, bad relay, or do you think that both bulbs failed at the same time? If your car is like mine (I have a 07 n/a impreza) I just installed the factory fog light kit.
You need to pop off the fog light surrounding cover, and pull down part of the front under tray to be able to gain access to two bolts (forget the size) and the whole fog light assembly should come out creating easy replacement of the fog light bulb or testing other things.
This post is kinda old though so you've probably figured it out already.
b154wheel is offline   Reply With Quote
2004 WRX Fog light bulb replacement? The Modaholic Electrical & Lighting 7 09-03-2010 11:08 PM
How to access fog light bulbs on '09 OBS Eric91Z Interior & Exterior Modification 4 04-29-2010 03:14 PM
Fog light bulb replacement NickD151 Electrical & Lighting 4 01-19-2005 03:27 PM
Fog Light Bulb Replacement SSR Legacy Forum 3 03-27-2002 09:51 PM
99-01 Fog Light bulb replacement Keith99RS New England Impreza Club Forum -- NESIC 6 11-30-2001 11:19 PM
