Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 05-12-2009, 08:06 PM   #1
gling
Member Sales Rating: (33)
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
Default GT Spec headers, Invidia DP, Deadbolt 18g, TGV deletes, Perrin intake, & much more
I've decided to go a different route with my car and have these items for sale. All items are located in CT (Coventry mostly) and will ship at buyers expense.
GT Spec Gen. II headers
They are partially wrapped and have about 30,000 mi. on them. There is nothing wrong with them. Sold.
Invidia V3 catless downpipe
Unknown mileage and has two small dents on the bottom from bottoming out due to the previous owner; I've only had this on my car for 300 mi. Aside from the cosmetic flaw, there is nothing wrong with it and works as it should. Sold.
WRX TGV deletes and intake manifold
I ported and semi-polished the housings in addition to deleting the TGVs. The TGV shaft holes were tapped, plugged with copper plugs using red Loctite, and ground down in the interior. They were media blasted with silicone oxide particles when the delete and porting job were completed. The photos show them when I finished the job, and as they are now (for sale) attached to the stock WRX intake manifold. The throttle body is also included in the sale. They worked fine and have no leaks. Asking $300 for the whole setup.
gling is offline   Reply With Quote
Old 05-12-2009, 08:06 PM   #2
gling
Member#: 122654
Perrin 3" to 2.4" black silicone intake tube
Sold.
Deadbolt ported, polished, and coated 18g
Has been on my car for about 30,000 mi. There is no shaft play aside from the factory tolerance as all journal bearing turbos have a bit of play new. Never boosted beyond 21 psi and was properly broken in when installed. The dirt marks on the compressor and turbine wheel is from my dirty gloves when I was checking for shaft play and any other abnormalities. The coolant and oil lines pictured in the images below may or may not come with the turbo (depends on whether I need them or not) Sold.
Grimmspeed 3 mm phenolic intake manifold spacers
It's been on the car for 25,000 mi. and although it shows some color change, it works as it should given that it is non-wear item. Sold.
Custom parallel fuel lines with Nismo R33 Skyline fuel pressure regulator
I made this setup to reroute the fuel in a parallel fashion using copper pipe fittings and Goodyear fuel injection hoses along with the Nismo FPR. Worked like a charm and I never had any problems with it. Asking $100 for the entire setup.
2002 WRX engine harness
IDK, $100 obo?
Helix 660 cc top-feed injectors
Used for 30,000 mi. and there is nothing wrong with them aside from being a bit dirty. Sold.
Old 05-12-2009, 09:08 PM   #3
singincanary
Will mod for Guinness
Member Sales Rating: (78)
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Package price for turbo and injectors? I can pick up this week.
singincanary is offline   Reply With Quote
Old 05-12-2009, 09:42 PM   #4
gling
Member#: 122654
No offense but at this point in time, I would like to keep the prices of those two items the way they are as I think they are more than fair. However, if they don't move in a week or two, I'll get back to you. How does that sound?
Cheers.
Gerald.
Old 05-21-2009, 11:03 AM   #5
gling
Member#: 122654
Bump.
Old 05-21-2009, 06:15 PM   #6
WREXION
Member Sales Rating: (3)
Member#: 204661
2002 wrx
partially muredered out
Default headers
how much picked up
WREXION is offline   Reply With Quote
Old 05-21-2009, 10:56 PM   #7
gling
Member#: 122654
Sorry, headers have been sold.
Old 05-21-2009, 11:23 PM   #8
Flat4TW
Member Sales Rating: (2)
Member#: 200456
0295 WRX
is a tune required for the tgv deletes? you used brand new gaskets after putting them back on between the tgv and the manifold? whats the mileage?
Flat4TW is offline   Reply With Quote
Old 05-25-2009, 07:33 AM   #9
gling
Member#: 122654
A tune is not necessary for the TGV deletes but is recommended to get the most out of it. Yes, I used brand new gaskets when I put them back together. I also have some phenolic spacers if you are interested. The mileage is about 85k mi. with the TGV deletes done 25k mi. ago. Let me know if there is anything else that you need.
Cheers.
Gerald.
Old 05-26-2009, 10:43 AM   #10
gling
Member#: 122654
Bump. Make me some offers - I need these parts gone.
Old 06-15-2009, 03:49 PM   #11
gling
Member#: 122654
Bump for the TGV delete cores and intake manifold!
Old 07-15-2009, 06:18 PM   #12
gling
Member#: 122654
Bump.
Old 08-18-2009, 03:58 PM   #13
gling
Member#: 122654
TGV-deleted cores and intake manifold still available!
GT Spec headers, Invidia DP, Deadbolt 18g, TGV deletes, Perrin intake, & much more gling NESIC Private Classifieds 27 08-08-2011 04:39 PM
GT Spec headers, Invidia DP, Deadbolt 18g, TGV deletes, Perrin intake, & much more gling Engine/Power/Exhaust 26 04-15-2011 11:00 AM
Invidia Exhaust, GT Spec Header, Perrin Uppipe, Invidia DP stevecooper Engine/Power/Exhaust 30 06-24-2008 04:52 PM
JDM STi Spec-C VF36 Turbo Set-up, JDM V8 Headlights Housings & Much More!! outcast Private 'For Sale' Classifieds 15 04-29-2006 12:07 AM
JDM STi Spec-C VF36 Turbo Set-up, JDM V8 Headlights Housings & Much More!! outcast SCIC Private Classifieds 5 04-26-2006 03:56 PM
