Old 07-03-2015, 03:59 PM   #1
rumblewrx13
Member#: 420209
2013 WRX
Default Accessport Dyno 2.5L VF52 STG 2
Event: Cobb accessport virtual dyno
Ambient Temp: 82 Degrees fahrenheit
Elevation:4600 ft
Weather: Sunny
Track Conditions: Highway onramp slightly downhill
Tires: Bridgestone Potenza RE 760 sport 235/45/17
Car: 2013 Subaru Impreza WRX
Tuner: Torqued Performance
Dyno Info: Cobb accessport virtual dyno
Transmission: Stock 5spd
Gear: 3rd
Peak HP at RPM:[email protected] corrected from chp to whp--245whp
Peak Torque at RPM:[email protected] corrected from crank torque to wtq--276wtq
Baseline hp/tq:Unknown
Target Boost:19.5psi
Target AFR:11.03:1
Fuel:Shell 91 v power
Engine/Power Modifications: AEM cold air intake, Tsudo divorced wastegate catless downpipe, Invidia N1 street, GFB blow off valve
Driveline Modifications: Stock
Suspension Modifications: Stock
Other Modifications:None
Hey everybody, wanted to see how accurate the cobb accessport dyno feature is. I know the numbers are most likely inflated, but let me know what you think.
dyno run by charlie macdonald, on Flickr
Last edited by rumblewrx13; 07-07-2015 at 08:39 PM. Reason: Changed from crank out put to wheel hp
rumblewrx13 is online now   Reply With Quote
Old 07-03-2015, 04:06 PM   #2
Xenozx
Member#: 216992
2016 WRX
thought 300/320 HP/TQ was pretty attainable on intake, exhaust and a pro tune. I do see your at a pretty high elevation and only using 91 octane not 93, so they might be a little inflated. Should go do a real dyno, and compare the #'s would be interesting to see.
Xenozx is offline   Reply With Quote
Old 07-03-2015, 08:12 PM   #3
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
post a log..would love to see the 105% idc..lol
BigRob74 is offline   Reply With Quote
Old 07-03-2015, 09:00 PM   #4
boxterWRX
Member#: 416278
Mine with 3650 I weigh 220 in a 2015 wrx on e85 drop in filter muffler delete made 336 whp and 368 tq did the quarter mile app to and was at [email protected] hard launch too that is done off the ecu
boxterWRX is offline   Reply With Quote
Old 07-03-2015, 11:37 PM   #5
rumblewrx13
Member#: 420209
2013 WRX
No problem.. Heres a log, highest idc is 87%
Highest I've ever seen was 95% and that was in the winter time. Eric at Torqued performance has done a great job with my tune, extremely good customer service, and has always run top notch.
https://docs.google.com/spreadsheets...it?usp=sharing
