Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 01-22-2012, 12:20 PM   #651
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
womp womp wobble wobble.
i had the idea of doing a built h6 swap with a nice 6266 or bigger with a 6spd. but have decided to stick with a ej2#. slowly selling off things from the car that i wont be needing or upgrading. injectors are gone, dp is long gone, gotta sell this hta68 and grimmspeed up tial 38 setup. havent decided whether to go with a forward facing setup or a standard rotated kit either way it will most likely be a 6266. my heads are currently still at the machine shop getting lots of love, like actually being ported and a valve job that actually seals. not sure which direction to go with block, lost whether to try again with a 205 or finally step up to a 2.5 block, if 2.5 it will most likely be a destroker.
in the meantime, concentrating on getting my renovations finished up and working on other peoples car to help fund the new build.. K&W Motorsports FTW!
karlknaupp is offline   Reply With Quote
Old 01-22-2012, 01:32 PM   #652
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
k&w ftw. cant wait to get started...on both of them.
maxpowr is offline   Reply With Quote
Old 01-22-2012, 07:01 PM   #653
wrxtacular
Member#: 181711
2004 278whpVF34wagon
Jorge Tuned
Followed this thread from the start as I have a VF34... Have you considered a EJ207 with a 6 speed swap? I'd love to see how far you could push that.
wrxtacular is offline   Reply With Quote
Old 01-22-2012, 08:42 PM   #654
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
i could do that, but i would probably end up building the 207 motor before i used it, at that point i might as well just go with the 2.5 block built. i still want to see how far i could go with the 205. i think a properly built 205 will put up some really good numbers. i mean i ran 121 mph on a motor that had some issues, with only 22 psi being limited by the id1000s on e85. i think this time around my motor will be built with properly machined parts.
Old 01-22-2012, 10:56 PM   #655
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i know a shop...
Old 06-30-2012, 12:43 AM   #656
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
could it be true? coming back with the vf34? only time will tell. xdrian im coming after your record...
Old 06-30-2012, 06:38 AM   #657
CatfaceType-R
Member#: 81102
andy forrest gave everyone a h6 hardon...damn, I got it bad.
Anyone need a 2.0 case in good shape, pm me.
CatfaceType-R is offline   Reply With Quote
Old 07-17-2012, 07:59 AM   #658
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
So i think i have a plan. it has a couple steps but the end result will be where i want to be at. Main goal now is to get my car driving again. I've played the idea of getting a stock motor and small turbo, but i kinda see that as both wasted money and time. so hear me out on this one. i pretty much can get my built 205 back together relatively easy and not too much money. so i could put that back together and have a built motor. now for turbo, i want to end up rotated so i figure do it now instead of later, trying to avoid having to do things multiple times. so how bad does a 6262 sound on a built 205 on e85. nothing crazy just like 18-20 Psi. next is the stock 5spd well lets hope that it will stay around till a 6spd can be put in with a built 2.5.
so to recap built 205 with stock 5spd and rotated 6262 at 18-20 Psi on e85. for now.
built 2.5 with 6spd later.
So what is the opinion on the go rotated with big turbo now so i can drive. instead of having to buy another stock location turbo setup.
Old 07-17-2012, 08:05 AM   #659
CatfaceType-R
Member#: 81102
Sounds great, get some valve springs and rev her out. That setup gives me an ewang, do it!
Old 07-17-2012, 08:08 AM   #660
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
Heads are built. springs retainers valves +1 ported gsc 272 cams
Old 07-17-2012, 08:25 AM   #661
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I like it, but get a hta35r instead of the 6262.
Old 07-17-2012, 09:57 AM   #662
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
dewit.
Old 07-17-2012, 10:33 AM   #663
CatfaceType-R
Member#: 81102
Decent price bump, and iirc 6262 has more power potential, with later spool.
Old 07-17-2012, 10:46 AM   #664
juanmedina
Member#: 133146
AWD motorsports made 700whp with the hta3582 and it doesn't fall apart .
Old 07-17-2012, 11:26 AM   #665
CatfaceType-R
Member#: 81102
Ibn20iroc'spicofhisdeadprecisionturbo
I would just run a 6262 for cost efficiency, but it can't rain on Carmi forever.
6262 is a bad azz turbo, I forgot the max that someone made with one, could've sworn it was in the 800's.
Old 07-17-2012, 11:28 AM   #666
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
When do you guys think ill get to 18-20 psi? 5500-6000? or before
Old 07-17-2012, 11:32 AM   #667
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
My buddy made 750 whp on his 10:1 e85 evo. i know the turbo can crank out some air.
Old 07-17-2012, 11:43 AM   #668
juanmedina
Member#: 133146
I like the HTA35r for the spool, why not get the HTA86 it makes more than the 6262 and it will spool faster. I don't know if the new CTA wheels are that much better. Yes the precision turbos are cheap but they are not known for the reliability.
Old 07-17-2012, 12:52 PM   #669
CatfaceType-R
Member#: 81102
I'm just guessing (not as familiar with our cam's on that 2.0) that it sounds about right what you say(comparing to some old 2.0 35r setups, ~5krpm) If you can rev to 9k, then it's going to be one fun ride, hard to drive well; but i'm sure you will be able to take care of that.
you can always try and do a t4 twin scroll 6262 and short runners with larger id custom manifold...$$$$$
The quick spool valve could be an option too It really is a great idea...
or just 'run what ya brung'
Old 07-17-2012, 01:03 PM   #670
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Karl,
Have you looked at any of the Holset options? Or am I speaking a different language entirely?
Subian is offline   Reply With Quote
Old 07-17-2012, 03:58 PM   #671
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
I know of holset just not familiar with sizes
Old 07-18-2012, 12:30 AM   #672
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
My 30r on my 2.0 was fun. Full boost by 4300. Can't wait to finish up the 257 version....
Old 07-18-2012, 06:55 AM   #673
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
Did i ever drive it?
Old 08-06-2012, 08:39 PM   #674
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
looks like im gonna be turning the 04 into a street car by week and track slut on the weekend.
guess ill be taking my 5spd and suspension out to source 5x114 goodness and 6spd greatness!
Old 08-06-2012, 10:49 PM   #675
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Dibs on the coils...
07 WRX OG Green on E85 goes to the 1/8th track 7.37 @ 95.2 mph. Phatbotti TKR tuned juanmedina Proven Power Bragging 51 04-17-2011 04:01 PM
Dyno Tune: 2.5 HTA Green 452whp JF824 Proven Power Bragging 25 07-07-2010 11:08 PM
05 Saabaru 2.5 Hybrid HTA68 on E85 aggie113 Proven Power Bragging 9 05-06-2010 11:13 PM
Paintless dent removal day... who was the dude from october-ish that did it???? JSiwek Bay Area Impreza Club Forum -- BAIC 5 05-14-2003 02:56 PM
Heres the Digit Power impreza that did well at Hockenheim a few weeks back Darius General Forum Archive 12 08-12-2000 12:07 AM
