Old 11-08-2009, 12:10 AM   #76
karlknaupp
Member#: 60871
2004 WRB WRX
Originally Posted by jmlaser View Post
Nice job backing up your times from the spring,....Sorry you didnt make 11s, They can be illusive!
Ive heard the Lighter FWs are a lil harder to launch.
GL with the house,... thats a WHOLE new ballgame and a fun one.
JM
im glad to see that i gained 3 mph from the spring. yea it def is harder with the lighter fw. i think if i had a stocker launching would have been soooo much easier. o well. i know the car has 11s in it the way it is, just gonna be a while till that happens. thanks the house has a huge garage so the car will hibernate for a bit...
karlknaupp is offline   Reply With Quote
Old 11-08-2009, 01:29 AM   #77
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
117.7 on st8 pump gas??
Even on C16 that is just rediculous. Im tellin u man, if I can go 12.01 @ 112.8, you can go 11.50's-11.60's. @ almost 118, the car def has it in it.
Good luck and keep trying (1.69=impressive for a 2ltr )
STi Mikey is offline   Reply With Quote
Old 11-08-2009, 09:22 AM   #78
karlknaupp
Member#: 60871
2004 WRB WRX
yup straight pump 93 from shell before getting to the track. thanks ill keep trying once i get settled in the house and money becomes more available. in the meantime ill do lil maintenance things like timing belt, have the valvetrain adjusted, blah blah...
Old 11-08-2009, 09:25 AM   #79
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
wow, this car is impressive! 117 with a vf34 is just awesome. I guess I dont have to switch to an 18g (I have similar mods as you).
I want to see this car run on meth or something.
Kitt is offline   Reply With Quote
Old 11-08-2009, 10:46 AM   #80
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
subscribd' what up brother? big up joanne and whats her name? oh wendy for keeping me warm the other night! george seems like a cool fellow.
maxpowr is offline   Reply With Quote
Old 11-08-2009, 12:50 PM   #81
karlknaupp
Member#: 60871
2004 WRB WRX
well here is my 12th pass... cut a 1.71 60' too bad my clutch didnt want to cut it...
Old 11-08-2009, 07:49 PM   #82
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
No vf has ever mph'ed like that on 93 pump. Congrats man!!
Old 11-08-2009, 08:05 PM   #83
karlknaupp
Member#: 60871
2004 WRB WRX
guess i have the freak motor/trans/turbo...
thanks dude
Old 11-08-2009, 08:28 PM   #84
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
this car is really strong, specially at top, 29mph on the back is crazy for 93oct or even race gas.
Did you weight the car? is the turbo ported or something? Any meth or nitro?
Your car is just sick
Old 11-08-2009, 09:39 PM   #85
karlknaupp
Member#: 60871
2004 WRB WRX
thanks. um yea just straight 93 oct. scale was off again.. weight should be the same as the last time i weighed it in the spring as i took the same stuff out as usual. normal vf34 nothing done to it. no meth
Old 11-08-2009, 10:14 PM   #86
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
This car would honestly trap 119.5-120 with a vf39/22 and racegas. Just my personal opinion.
Old 11-08-2009, 10:40 PM   #87
juanmedina
Member#: 133146
07 FPgreen 7.37@95
My question is why and how? The traps speed on 1/8ths are weak in contrast to the 1/4th traps. 93oct + VF34 + full weight does not equal to that kind of trap speeds.
Is the track below sea level?
there is something missing..............
Old 11-08-2009, 10:50 PM   #88
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
congrats nice times
DarkKnightBaku is offline   Reply With Quote
Old 11-08-2009, 10:51 PM   #89
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Its interesting you pointed that out. That 330, 1/8th, and the mph are weak (well, not weak, but where they should be fro a well tuned vf wrx)
In this case, by numbers, the 117-118 is justified. At the same track, trapping 112 I went from the 1000ft to the 1/4 in .2 seconds. At 117+, its taking Karl from the 1000ft to the 1/4 in .15 seconds. That is a substancial difference in which at least 5 mph is needed.
Old 11-08-2009, 10:53 PM   #90
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
pretty much at sea level. karl needs more clutch and more drag radial.
Old 11-08-2009, 11:00 PM   #91
karlknaupp
Member#: 60871
2004 WRB WRX
i never said the car was full weight. it weighed 28xx id have to look back in xdrian's fastest/quickest thread to find what the weight was again.
and how would a vf39 get me higher traps? the 34 is bigger then the 39?
Old 11-08-2009, 11:04 PM   #92
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you get a good clutch, drag radials on 15's and launch control and you'll see 1.4 60 ft.'s.
you need to build boost at the line...stabbin it isn't helping you.
Old 11-08-2009, 11:09 PM   #93
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I should have just said vf22. Back in the day gruppe s rated the 39 as a 35lb/min turbo and a vf34 as a 32lb/min turbo (on their website).
Now it shows the vf34 and the vf48 as a 32lb/min turbo. Sorry for the mislead.
Old 11-08-2009, 11:21 PM   #94
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
DA's for ATCO are frequently below sea level and probably were last night.
Karl, are you the first owner of your VF34? Has it been modified at all, except for the EWG? Hope my questions aren't misconstrued, I'm a huge fan of your setup, just trying to figure out what is the biggest contributor to the top end pull.
28xx with you in it?
OppositeLock is offline   Reply With Quote
Old 11-08-2009, 11:22 PM   #95
karlknaupp
Member#: 60871
2004 WRB WRX
its cool. i thought i knew the 34 was bigger.
um dude i thought i told you its better to stab at the throttle instead of just holding a steady rpm.. what do you think launch control basically is?
Old 11-08-2009, 11:32 PM   #96
karlknaupp
Member#: 60871
2004 WRB WRX
yea i got the turbo brand new 50k miles ago. and that weight is not with me in the car. 2845~ plus 190 so just over 3000 with me.
Old 11-08-2009, 11:43 PM   #97
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i don't think you were stabbing above 5k were you? i launch at 5500. too bad you wouldn't let me drive it.
Old 11-08-2009, 11:51 PM   #98
karlknaupp
Member#: 60871
2004 WRB WRX
was revving to almost 6k..
Old 11-09-2009, 12:14 AM   #99
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
your car is quick karl. no offense brother. 0xox0.
Old 11-09-2009, 02:07 AM   #100
GDAryder
Member#: 184753
2005 WRX
thanks yea i was really hoping that i would have ran the 11sec pass that i was looking for.. dont know when im gonna make it back out to the track to race, seeing how house purchase is going down.. wont have money to play with the car for a bit.
F-it thats a well-worthy reason to pause dumping funds into the flatfour-mobile.
GDAryder is offline   Reply With Quote
07 WRX OG Green on E85 goes to the 1/8th track 7.37 @ 95.2 mph. Phatbotti TKR tuned juanmedina Proven Power Bragging 51 04-17-2011 05:01 PM
Dyno Tune: 2.5 HTA Green 452whp JF824 Proven Power Bragging 25 07-08-2010 12:08 AM
05 Saabaru 2.5 Hybrid HTA68 on E85 aggie113 Proven Power Bragging 9 05-07-2010 12:13 AM
Paintless dent removal day... who was the dude from october-ish that did it???? JSiwek Bay Area Impreza Club Forum -- BAIC 5 05-14-2003 03:56 PM
Heres the Digit Power impreza that did well at Hockenheim a few weeks back Darius General Forum Archive 12 08-12-2000 01:07 AM
