Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 05-13-2009, 01:45 AM   #1
Darksun Racer
Member#: 103328
2006 STI
White/Red Racing Stripes
Question Easy access point for +12V Ignition on
Hey there,
Kinda noobie question .. but ...
Could someone recommend an easy access point for "+12V Ignition on" near the fuse box or near the radio of a 06 STI ...
Furthermore ... the color of the wire I am looking for ... or a file picture would be useful ...
I tried to look at old post via "search" but found little that would aide an amateur...
Oh ... an I am putting the finishing touches on an install of a Laser Interceptor ... obviously ... hardware is my thing (vs. electrical) ...
Thank you for your help in advance ...
DSR
Darksun Racer is offline   Reply With Quote
Old 05-13-2009, 09:39 AM   #2
LYHTSPD
Member#: 26374
2004 WRX Sedan
San Remo Red
You could tap into the wiring harness that comes down from the ignition, which should be right under the steering column. You will need to supply your own fuse if you tie into this wire.
That radio harness will also have a 12 volt constant, and a 12 volt acc wire. Just be sure that the fuse for the radio has enough capacity to run both the radio and the laser interceptor.
There are all kinds of wires in/around the fuse box that carry a 12 volt acc line.
I don't have any documentation on the 06 model, so I am not even going to guess on any wire colors, sorry. I think you may have to find those on your own. Look around for threads relating to car stereo installs, other radar detector installs, etc. I am sure you should be able to find all that info on here.
LYHTSPD is online now   Reply With Quote
Old 05-13-2009, 07:04 PM   #3
danmezz
Member#: 126339
2003 WRX Wagon
If the cigarette lighter turns on and off with the ignition in an 06, that's also a good place to tap into... just get to the back of the cigarette lighter and tap into the positive wire. I'm guessing it's red but may be a different color
danmezz is offline   Reply With Quote
Some creepy big brother **** with Wifi access points going on. aod Off-Topic 37 10-12-2009 05:53 PM
Is there an optimal ignition point for STi? bboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-02-2007 05:25 PM
Fs: Queens Cisco Access Point For Sale 30 psi Non-Subaru Stuff 2 11-29-2007 07:52 PM
Need a switched (either headlights or ignition) wire with easy access grue Car Audio, Video & Security 4 05-15-2002 02:05 PM
Where's the fill point for front differential on AT cars? remarcable Transmission (AT/MT) & Driveline 7 12-11-2001 09:35 PM
