Old 05-13-2009, 03:36 AM   #1
mxpro252
Member#: 156896
06' WRX Wagon
CGM
Default Driving without hoodscoop bad for turbo?
Is there any danger in driving my 07 wrx for a few days without the hoodscoop and just having the open hole in the hood?
mxpro252 is offline   Reply With Quote
Old 05-13-2009, 03:51 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If you stay out of boost you'll be fine.
Old 05-13-2009, 04:07 AM   #3
STi-MAN
Member#: 70252
05 STI
blue
You'll prob heat soak.. but like nsfw if you're not racing you should be fine.
STi-MAN is offline   Reply With Quote
Old 05-13-2009, 04:53 AM   #4
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
Well if you think about the function of the hood scoop and the splitter is to bring air into your intercooler and onto your turbo. If you remove that factor your going to have A MAJOR less cooling efficiency. SO like everyone else said. Just drive normal and don't be jetting around anywhere.
So yea, just stay out of boost. Why are you taking it off for a couple days anyways?
fearmywrx is offline   Reply With Quote
Old 05-13-2009, 10:25 AM   #5
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
^^What he said, but I'd like to add on that what will happen is that your car will pull timing due to the warmer IAT. It'll be almost as if you were running no intercooler at all.
ammo0000 is offline   Reply With Quote
Old 05-13-2009, 10:51 AM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
IAT is measured at the MAF, before the intercooler. Not passing air over the intercooler will have zero effect on measured IAT. It will raise actual IAT, but the ECU doesn't know that, so if you get on it you might start knocking. That said, do as everyone else has said and stay out of boost.
Old 05-13-2009, 11:07 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well said ^^^
KillerBMotorsport is offline   Reply With Quote
Old 05-13-2009, 12:50 PM   #8
mxpro252
Member#: 156896
06' WRX Wagon
CGM
So I know I have gotten into boost so next question would be how would I know if anything has been damaged?
Old 05-13-2009, 12:52 PM   #9
Member#: 51961
2005 STi
2012 WRX
compression and leakdown test
Old 05-13-2009, 01:09 PM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Im sure it will be fine.
stretchedk7 is offline   Reply With Quote
Old 05-13-2009, 01:24 PM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
If it runs and sounds the same its prob fine, justg do what everybody is saying and put the bitch back on.
BlackFighter is offline   Reply With Quote
Old 05-13-2009, 02:00 PM   #12
mxpro252
Member#: 156896
06' WRX Wagon
CGM
Ya ill have my new scoop on tomorrow. It's not off cause I think it looks cool, it was in an accident
Old 05-13-2009, 02:16 PM   #13
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
That's what I meant. Sorry, yes, the timing will be pulled because of the knocking, not because the car reads the higher IAT.
Old 05-13-2009, 02:40 PM   #14
HyperSl4ck3r
Member#: 179982
2008 Impreza WRX STI
Obsidian Black Pearl
Catch a bird? Almost pulled that off in my 05... I miss my 05
HyperSl4ck3r is offline   Reply With Quote
Old 05-13-2009, 04:56 PM   #15
BlackFighter
Member#: 193940
2004 WRX STI Black
^^ HAHA that’s what i was thinking, man with sti scoops the bird would just get stuck on the top mount. Imagine that you open your hood and there is a bird dead on your top mount.
Old 05-13-2009, 08:15 PM   #16
mxpro252
Member#: 156896
06' WRX Wagon
CGM
Thanks for the responses. This is my first turbo'd car so I'm kinda clueless. But I'm also an over thinker too so a leak down and compression test is the only way to find out if somethings wrong? It still runs fine and sounds fine but I worry a lot
Old 05-13-2009, 09:15 PM   #17
Xin0811
Member#: 202323
even if you were pinging with the warmer less dense combustion chamber air, the knock sensor should prevent any damage from occuring. Feel any timing pull?
Xin0811 is offline   Reply With Quote
Old 05-13-2009, 09:52 PM   #18
mxpro252
Member#: 156896
06' WRX Wagon
CGM
What's timing pull? Or heat soak?
Old 05-14-2009, 12:58 AM   #19
Xin0811
Member#: 202323
heat soak is exactly what it sounds like. The intercooler is just sittin there absorbing heat from the engine without the air from the hood scoop to cool it down.
Timing pull means your ecu retarding ignition timing. simply put, retarded timing=slower acceleration. Feel any difference in acceleration compared to before?
Old 05-14-2009, 10:12 AM   #20
mxpro252
Member#: 156896
06' WRX Wagon
CGM
I haven't driven it much so its hard to tell if it's slowed down. It still feels quick, if the timing has changed Its not real noticable. Everything sounds and feels fine to me but I can't tell if something might be off a little. That's why I was looking for a way to test it and eliminate the possiblity of something being wrong.
Old 05-14-2009, 10:36 AM   #21
Member#: 51961
2005 STi
2012 WRX
If that were the case, nobody would blow motors due to detonation, but they do. The knock sensor isn't perfect, and isn't even used above 6k RPM or so (due to noise).
Chances are the engine is fine though, in order for a day's worth of detonation to kill the motor, it has to be pretty bad, like audible bad.
Old 05-14-2009, 01:18 PM   #22
flycaster
Member#: 60142
2011 WRX
Grey
...in order for a day's worth of detonation to kill the motor, it has to be pretty bad, like audible bad.
Are you sure about that?
flycaster is offline   Reply With Quote
Old 05-14-2009, 02:55 PM   #23
mxpro252
Member#: 156896
06' WRX Wagon
CGM
and just something i was thinking about, the car is pretty much stock, so if it can still get up to 60mph in 6 seconds everything is probably how it should be right?
Old 05-14-2009, 09:48 PM   #24
JSarv
Member#: 163445
l33t *******
[email protected]
haha that is a debate all in itself..
I've been in a Dakota 5.9L R/T that detonated everytime the gas pedal was looked at day in/day out and never lost compression..
Then again guys loose rings/lands from 1 non-audible det..
I honestly think its the luck of the draw/knock... 1 bad/bad knock could do a piston or bearing in... Or it might last months with them poor little bb's bouncing around in that tin can
-Jerod
JSarv is offline   Reply With Quote
Old 05-14-2009, 10:52 PM   #25
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
The worlds going to end
tux121 is offline   Reply With Quote
Driving without a hood for a day or two. Bad juju? Pakin North West Impreza Club Forum -- NWIC 8 10-15-2006 12:37 AM
Are Electronic Cut-outs bad for turbo cars? TrizzyDizzy South East Region Forum 20 09-26-2005 12:23 PM
How long can i drive without a tune for 18g? silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 07-23-2005 01:20 PM
Synth Oil bad for turbo?? jjunior887 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 07-13-2002 01:33 PM
