Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 05-13-2009, 09:35 AM   #1
got_WRX?
Member#: 70074
2005 WRX
CGM
Default Reset CEL for free
I was passing by a Sunoco 2 weeks ago and got some 93 instead of the usual premium gas. Then I got the CEL on. I called STS, Pepboys and Somerset Subaru Dealer in central NJ. They all charge around $90 for the reset. Does anyone know anywhere in CNJ will do reset for free? Thank you.
got_WRX? is offline   Reply With Quote
Old 05-13-2009, 09:50 AM   #2
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Detach negative battery terminal
Step on brakes till power is out
Re-attach negative terminal
Gfunk720 is offline   Reply With Quote
Old 05-13-2009, 09:57 AM   #3
migs76
Member#: 23934
most autozones will scan it for free. might as well find out what's triggering it. they'll reset it too if they're not dickheads about it.
migs76 is offline   Reply With Quote
Old 05-13-2009, 10:01 AM   #4
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
the CEL turns on to tell you something is wrong. Resetting the ECU doesn't fix whatever is wrong with the car
WC LATHE WERKS is offline   Reply With Quote
Old 05-13-2009, 11:00 AM   #5
got_WRX?
Member#: 70074
2005 WRX
CGM
i don't feel anything wrong with my car, i think it was the 93 gas that triggered the CEL as i heard some people have similar situation.
Old 05-13-2009, 11:46 AM   #6
sleepyS14
Member#: 171688
2006 Saabaru 9-2x
Aero Wagon Midnight Black
shoot come over here.. ill reset yer CEL for half the price!
$45 =)
sleepyS14 is offline   Reply With Quote
Old 05-13-2009, 01:08 PM   #7
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Yea dude I would go to autozone they'll pull the code for free then you can tell whether or not something really is wrong. I would right now check your oil level and filter, when was the last time you did that?
PS you should be using 93 gas unless you're tuned differently, so using 93 should NOT throw a cel. Good luck, get to AZ.
JavaBot is offline   Reply With Quote
Old 05-13-2009, 01:29 PM   #8
allmotorhatch
Member#: 174549
2002 wrx
black
you should check your gas cap to see if its lose that throws a cel
allmotorhatch is offline   Reply With Quote
Old 05-13-2009, 02:09 PM   #9
Jus Blaze
Member#: 129428
2002 Wrx
You can reset your ecu by just disconnecting your battery and pumping the brakes for a few seconds. If there is something wrong with your car, the cel will just come back, its just a matter of time.
Jus Blaze is offline   Reply With Quote
Old 05-13-2009, 02:11 PM   #10
WRXGONE
Member#: 18314
02 BLUE SUBARU WRX
06 GG EVO9 MR
where in CJ are you located
WRXGONE is offline   Reply With Quote
Old 05-13-2009, 03:49 PM   #11
Gfunk720
Member#: 42549
E92 M3 M\\\
As opposed to what?
Everywhere I go in the tri-state only has 93 octane
Do you mean you put in 87?
Old 05-13-2009, 04:21 PM   #12
A Guy with a STi
Member#: 127215
01 Fozz 2.0L
Instead of paying ppl to check your CEL why dont you spend the money on one of those cheap scan tools and code book. It practically pays for itself in after two CEL's.
A Guy with a STi is offline   Reply With Quote
Old 05-13-2009, 04:34 PM   #13
migs76
Member#: 23934
http://www.autozone.com/autozone/sto...questid=275559
choose one...come back and post up what cel code you have.
Old 05-13-2009, 07:51 PM   #14
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Yeah, why would 93 octane trigger a cel???
AugustusMaximus is offline   Reply With Quote
Old 05-13-2009, 08:12 PM   #15
Crow-sti07
Member#: 149887
07 Sti Stage2"OTS"
Whale Tail OBP
Probably a lose gas cap..
Crow-sti07 is offline   Reply With Quote
Old 05-13-2009, 09:41 PM   #16
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
better gas is in no way gonna cause a check engine light. i second the loose gas cap.
424wrx is offline   Reply With Quote
Old 05-13-2009, 10:55 PM   #17
seekndestroy19
Member#: 209358
06 Sti
+1 i purchased one from sears awhile ago and it came in handy so many times.
seekndestroy19 is offline   Reply With Quote
Old 05-14-2009, 02:11 PM   #18
got_WRX?
Member#: 70074
2005 WRX
CGM
I just came back from Autozone, the code is P0031:
-heater control circuit low
probable cause
BB1 - Open or short circuit condition
BB2 - Poor electrical connection
BB3 - Failed H02S11
any idea?
Old 05-14-2009, 02:53 PM   #19
sleepyS14
Member#: 171688
2006 Saabaru 9-2x
P0031
HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
bank 1 O2 sensor?
Old 05-14-2009, 03:00 PM   #20
RS Guy1513
Member#: 102812
05 CGM 2.5 RS
07 Triumph Tiger 1050
looks like it might be time for a front 02 sensor
RS Guy1513 is offline   Reply With Quote
Old 05-14-2009, 04:04 PM   #21
migs76
Member#: 23934
^^^ this. had to replace mine so i could pass inspection. chances are if you reset it and didn't fix the problem, it's coming back. home many miles on the clock?
edit - just looked at your car info. hmmm...only an 05. are o2 sensors known to crap out that soon?
Old 05-14-2009, 05:02 PM   #22
bugeye4life
Member#: 146328
07 sti
username is now invalid
maybe you didn't put your gas cap on right?
have an accessport? that thing was amazing for cel codes.
but autozone ran my codes for free. and if its just a fluke, then you can pull the battey cable and reset it yourself.
bugeye4life is offline   Reply With Quote
Old 05-14-2009, 05:36 PM   #23
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
For the love of forum etiquette read the thread!
+1 for front o2 sensor... How many miles on the clock?
Old 05-14-2009, 07:23 PM   #24
seekndestroy19
Member#: 209358
06 Sti
^^ Haha
Old 05-14-2009, 07:31 PM   #25
sleepyS14
Member#: 171688
2006 Saabaru 9-2x
hmm just came across this thread.. might be helpful to OP
http://forums.nasioc.com/forums/show....php?t=1660218
Misfired, CEL, fixed misfire, reset CEL, failed smog... mc2 Normally Aspirated Powertrain 1 03-19-2009 05:59 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
What stores test OBDII CEL codes for free? Sephro New England Impreza Club Forum -- NESIC 11 02-23-2005 04:21 PM
Anywhere to get a CEL read for free? Jesperss North West Impreza Club Forum -- NWIC 3 10-15-2004 04:58 PM
reset cel... janikphoto Legacy Forum 4 09-28-2001 07:20 PM
