Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-13-2009, 11:58 AM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Another Utec/Idle/Cams question
I've seen a couple other threads regarding the subject, but none that pertained directly to my situation.....Looking for input from people that have actually dealt with this.
I have some Kelford custom 272 cam that like to cause the motor to die on idle. I've tried a few obvious things already but don't seem to do the trick. Starting off, the car never dies after cold start, only after it warms up. When cold, it's lopey (as expected) but not horrible. So far I've kicked up the idle in the ecu as far as 1100 rpms. The fueling is about right on afr-wise but I have played with 0 column values in the utec, adding and subtracting fuel. I also put some timing values in the 0 column, like around 14deg up to 1500 rpms, and played around with low rpm 10% column values as well.
The thing is, when driving and coming to a stop, it wants to drop all the way down and then come back up, so upping the idle doesn't do much to help because it's not "catching" it on decel. Once it dies it wants to die every time after that as well.
Given that temperature seems to make a difference, I'm wondering what I can do to work with that?
TyranosaurusWRX is offline   Reply With Quote
Old 05-13-2009, 12:46 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
If this is a drive by cable then use the idle stop screw and crack open the butterfly a little. Once you have done that go back into the UTEC and recalibrate the TPS to ensure that it reads zero.
If this is a drive by wire then drill a small hole in the butterfly.
You need more air flow.
Don't open it too much otherwsie the idle will be too high
mick_the_ginge is offline   Reply With Quote
Old 05-13-2009, 12:54 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Excellent idea, thank! I should have mentioned it was a 02 wrx.
Old 05-13-2009, 01:11 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
HA, i just fixed this yesterday. I had the same exact problem. Mick's idea works, as its the same thing i did.
NITROS is offline   Reply With Quote
Old 06-08-2009, 10:09 PM   #5
STIBungy
Member#: 51684
What size should the hole be on a dbw?
STIBungy is offline   Reply With Quote
Old 06-10-2009, 01:25 PM   #6
NITROS
Member#: 41561
04 GT3076 2.1
I would say pretty small. When I used the set screw to crack mine open, it looked like i hadn't done anything. Yet it made a world of a difference.
Cant you adjust idle tps angle with OpenSource. I'd check that out.
Old 06-16-2009, 09:44 AM   #7
cynet2k
Member#: 110177
2011 WRX 4Dr SWP
RIP 2007 LGT SpecB 524whp
add 2-4 degrees of timing in the low load rpm areas with OS. i had the same issue and it fixed mine... i have same cams and all
cynet2k is offline   Reply With Quote
Old 06-19-2009, 01:09 PM   #8
NITROS
Member#: 41561
04 GT3076 2.1
I tried this approch first but it did not help me. Only cracking the Throttle Plate open a bit helped.
Another Hydra Idle Control Question napphappy Other Engine Management 2 01-04-2010 02:22 PM
will a utec idle ok with 280 cams tech145 UTEC 2 04-21-2009 09:05 AM
Another High Idle Question.. VSG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-08-2004 05:03 PM
Another UTEC map question bhkim126 Engine Management & Tuning 3 11-20-2003 02:54 PM
Another UTEC question DiMensionX Engine Management & Tuning 26 10-01-2002 03:03 AM
