Old 04-21-2002, 09:33 PM   #1
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Unhappy TecII Installed. Trouble starting Car
Tec has been installed, but had to set ignition advance to 19 and change the injector offset by adding +.500 to the base map to get the car started. But if I touch the accelerator the car stalls.
Can anyone forward me a MY99 map that I can compare the ignition table and the injector tables?
I'm double posting here and in the Vishnu forum cause this site get more traffic and I need to get the car into some semblance of running tonight.
Thanks.
Revision is offline   Reply With Quote
Old 04-21-2002, 10:42 PM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
Can start and run the car near the base enrichment guidlines for now.. But the car still stalls out once the 20 second gamma enrichment ends. Hmm..
I can't believe that the baseline map is so far off..
Old 04-22-2002, 12:14 AM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
Aw heck. Here is a link to the install pics.
http://www.i-club.com/forums/showthr...hreadid=175970
Old 04-22-2002, 01:51 AM   #4
mastervic27
Member#: 557
1999 Impreza 2.5RS
Vishnu Turbo
Good Luck Revision! I can't believe the baseline map is so far off.
I got my TEC-2 this weekend but haven't had a chance to install it yet. Those are some nice pictures you took and gives me an idea as to how things should look.
I see you have the TEC-2 from Vishnu and the intake from Rallispec. Where is your turbo going to be from?
Victor
mastervic27 is offline   Reply With Quote
Old 04-22-2002, 05:14 AM   #5
Revision
Member#: 242
MY05 PSM GGA !STOCK
Still finalizing some parts.
For sure to be powered by a VF23.
Completion ETA Mid-May.
Old 04-22-2002, 09:08 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
Found the culprit!
Old 04-22-2002, 09:25 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
How long did it take to put the TEC-II in? Are there lots of wires that have to be cut and what not, or are there connectors that come with it?
Graham
Graham is offline   Reply With Quote
Old 04-22-2002, 09:59 PM   #8
DoctorNick
Member#: 7022
2013 BRZ Limited
andrew...if ya NEED a car to get around in this week yell at me. I am working downtown from 4am to 6pm so if ya need the ghetto coon tell me. (it will be getting an oil change, tranny fluid change and widows locktighted tomarrow(final subaru check up untill...ya know )
DoctorNick is offline   Reply With Quote
Old 04-23-2002, 01:05 AM   #9
Revision
Member#: 242
MY05 PSM GGA !STOCK
I'd love to borrow your car. In exchange, I'll change out the oil, tranny fluid and filter, and coolant.. Well maybe not the tranny fluid and filter..
BTW, I put around 50-75 miles on my car a day.
I'll have to put real tires on it while I have it too.. The only set I have not in use right now is a set of Dunlops on MY99 RS rims.
Old 04-23-2002, 02:18 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
he's got Sumitomo HTR-z's on it...they are noisy but rather sticky
Old 04-23-2002, 06:25 PM   #11
mastervic27
Member#: 557
1999 Impreza 2.5RS
Vishnu Turbo
If you go with the Vishnu Tec-2 there is only 1 factory wire to cut and that is optional. Check out the installation guide at Vishnu.
Old 04-23-2002, 06:31 PM   #12
mastervic27
Member#: 557
1999 Impreza 2.5RS
Vishnu Turbo
Which cable/connector is that?
Old 04-23-2002, 07:39 PM   #13
8Complex
Member#: 922
04 FXT
Red
That actually -was- the Vishnu kit. Was the first I saw of one, and you can tell the wiring was sent to the lowest bidder for fabrication.
That was the MAF sensor plug.
Old 04-23-2002, 11:38 PM   #14
Revision
Member#: 242
MY05 PSM GGA !STOCK
I didn't "cut" any stock wires.
I did splice into the TPS and the ignition power.
Cutting the wire going to the pollution control system, ie the CEL is considered a Federal crime. -> No thank you.
Old 04-07-2003, 11:23 AM   #15
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Bringing a post from the dead, but is it really a Fed Crime to splice the CEL wire on the ecu harness?
So what can you do to get a check engine light to display a problem with the TEC-II sensors besides getting another light?
latinskllz is offline   Reply With Quote
Old 04-07-2003, 10:31 PM   #16
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
yea cept for the TPS splice, you gotta cut a coolant line to put in the clt temp sensor. everything else is "bolt on" so to speak.
Dan_E is offline   Reply With Quote
Old 04-07-2003, 11:46 PM   #17
Revision
Member#: 242
MY05 PSM GGA !STOCK
wow, talk about bringing a post back from the dead.
Yer not suppose to mess with the emissions stuff. And that includes the cat. The MIL is part of the emissions equipment.
Sides, if you are running a Tec system in parallel with the stock ECU you want the MIL to tell you if there are problems with the stock system... Course that means you need to get the ECU to void normal issues like positive manifold pressure and timing increase/decreases.
Old 04-08-2003, 05:22 PM   #18
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Thanks!
Cause I am finally going to be installing the tec-ii April 26th, 27th along with the damn wrx turbo waterpump.
I'm wondering if I should connect the CLT sensor to the upper nipple since it's a feed FROM WATER TANK....
I know i can T off the heater hose, but perhaps this new location will be better?
Old 04-09-2003, 03:46 PM   #19
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
What upper nipple are you talking about?
You want your CLT sensor to be after the block but before the heater core - it'll give you the hottest (and correct) temp in the system.
Austin is offline   Reply With Quote
Old 04-10-2003, 01:13 AM   #20
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Thanks Austin, so I guess i'll just stick with the tec-ii installation location of the CLT, splitting the heater hose.
It's just that I was reading on the JC Turbo Install instructions and that's the same hose to supply the coolant to the turbo...so I wasn't sure about T'ing the CLT sensor and then the coolant line all from one source even though it's pass through
Old 04-10-2003, 08:47 AM   #21
Revision
Member#: 242
MY05 PSM GGA !STOCK
I did the same thing. Don't worry about it. You do have to shorten that hose a little bit to get all that stuff to fit inline.
If you ever want to go back to stock in the future, you'd have to buy a adapter and a length of coolant hose and that is it.
Old 04-10-2003, 08:51 AM   #22
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
So you T'd the CLT and the coolant feed in the same location?
Damn man, the closer the date comes the more nervous I get
I've had the tec-ii for a year and a half now sitting next to my bed only being admired at from time to time.
I doubt I will ever go back to stock. Turbo RS-T is so much fun to drive.
I am getting the clutch replaced too the same weekend lol.....we'll see.
Trouble Starting car!!!! Zondacl2 Factory 2.5L Turbo Powertrain 12 11-01-2008 05:23 PM
Trouble starting car... SubieRX Factory 2.5L Turbo Powertrain 1 06-06-2007 08:04 PM
Having trouble starting car scoobyimprza Subaru Conversions 16 02-04-2006 07:46 PM
trouble starting car yuletak Service & Maintenance 1 01-23-2006 04:34 PM
Trouble starting car crazy_sherm Newbies & FAQs 11 08-12-2003 03:26 PM
Message Board Statistics All times are GMT -4. The time now is 03:58 PM.
