Old 04-21-2002, 10:06 PM   #1
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Question How hard to install borla header?
I'm thinking about buying a Borla header from Larry Ganz and I am wondering what's involved to exhange the stocker for the Borla. Do you have to take anything off of the bottom of the car? Is all that's needed is a socket set and a set of ramps? Also, I remember reading somewhere about a "Generation 4" header, what's up with that? And finally, do check engine lights still plague the masses? If you wrap the header will it prevent the CEL from occuring?
Thank you
-Jason
jay25RS is offline   Reply With Quote
Old 04-21-2002, 10:53 PM   #2
booger
Member#: 6446
99 Impreza 2.5 RS
it was easy in auto shop
booger is offline   Reply With Quote
Old 04-22-2002, 02:05 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Why don't you stick your head up under there & see? It should be pretty easy.
Tim Sanderson is offline   Reply With Quote
Old 04-22-2002, 03:05 AM   #4
JSiwek
Member#: 14909
It's super easy on the Subaru's because the headers are actually the lowest thing on the bottom of the car. The bolts are probably pretty well stuck on there though, you'll need a breaker bar and bolt loosener. Also, get new seals before hand at your dealership.
Jeremy
JSiwek is offline   Reply With Quote
Old 04-22-2002, 10:54 AM   #5
Jademonkey
Member#: 9213
2000 RS
Red
It's pretty easy.. The hardest part is getting the bolts that connect to the cat. The way the flange is position, makes it VERY difficult to get there with a regular rachet. Get yourself a looong extension. It's what I had to do. But other than that, it's a piece o cake. Good luck!
Jademonkey is offline   Reply With Quote
Old 04-22-2002, 12:39 PM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
The hardest part for us was the header to cat bolts. They are pretty tough. We ended up dropping the cats with the header and cutting the bolts off. Kind of a pain.
As for the borla headers. Do yourself a favor. Wrap the last part of the header before you install it. This should help with the CEL issue. I was told to do this by Borla service and tech. You might want to call and get your customer number set up with borla service first and ask them about it. Have them note your file that they told you to wrap them.
Should help the car a lot. It made mine fun.
Jeff
jeffg is offline   Reply With Quote
Old 04-22-2002, 09:54 PM   #7
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
How much more power are all of you feeling? What else do you have in terms of power mods? Right now I have a CAI and a Borla Cat back exhaust. Do you know what the torque specs are for the header bolts?
-Jason
How hard to install STI Version 2 Lip on WRX Wagon rdebow Interior & Exterior Modification 0 04-12-2003 12:57 PM
How hard to install Up-pipe? jlee27 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-08-2002 09:37 AM
How hard to install C-West front lip dman918 Interior & Exterior Modification 9 02-10-2002 12:05 PM
how hard to install JDM lights? yipsta Interior & Exterior Modification 1 02-09-2002 02:01 AM
How hard to install... Dori Dori Brakes, Steering & Suspension 3 09-04-2001 05:38 PM
