Old 05-13-2009, 06:15 PM   #1
jtwebb
Member#: 201491
2002 WRX VF39
Stage Blue
Default Radar Detector Installation???
Ok so I am aware of the auto-dimming mirror wire located in the map light housing. But I was wondering how exactly to hook my radar detector to it. The only wire I have for the detector is the kind you plug into your cigarette lighter. Is it as simple as cutting the existing power cord i have and soldering it the auto dimming wire? Or am I missing something?? Any help would be much appreciated.
jtwebb is offline   Reply With Quote
Old 05-13-2009, 07:04 PM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Yes and no.
You will need wire diagrams for both. A simpler place to pull the power from is the clock location. The wire positions are labeled on the back of it, so that takes 50% of your work out.
As far as the cigarette adaptor for your radar detector, just take it apart and not the 12+ and ground, and attach them to the clock location wiring using your desired method (solder, vampire clips ext.)
skingfreak is offline   Reply With Quote
Old 05-13-2009, 08:36 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's important that you don't just cut the cord off the lighter adapter and connect the wire to 12V. The adapter contains a voltage converter which takes the 12-14V from the vehicle and outputs a lower, regulated voltage for the detector. If you connect the detector directly to vehicle power you will blow it up.
Depending on what detector you have, there may be a hardwire power adapter available for it so you don't have to open up the lighter plug.
The mirror harness is a convenient place to wire into if you are mounting the detector up by the mirror.
Radar Detectors memma Off-Topic 186 09-29-2015 02:33 PM
FS : Various stuff : race tires, carbon vinyl, radar detector, stereo, gauges, etc - LA fredtga SCIC Private Classifieds 19 08-06-2010 05:54 PM
('93-'01) Custom installation of Valentine One Radar Detector fastwrx Impreza Forum 18 01-07-2006 01:51 PM
my hard wired radar detector install patrick smith Electrical & Lighting 0 09-06-2005 09:53 PM
Installation ideas for remote radar detector beta Electrical & Lighting 13 12-29-2003 10:48 AM
