Old 05-13-2009, 09:39 PM   #1
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Default "Backyard Special" (BYS) style tilted license plate brackets
So on my way home tonight I saw a pretty clean looking white S2000
Noticed this cool looking front license plate holder. Usually, I'm not a fan of those tilted license frames but this had me stopping to take a look. It looked cooool... and made me want it.
After some searching on S2ki I found out it's made by Backyard Special for the S2000 -- but I don't see any reason it wouldn't fit a Subaru though right? Thoughts?
$60-80 for the real deal JDM BYS part but it apparently doesn't fit USDM license plates. Fail.
But there is a $32 'similar model' that does fit USDM license plates:
http://www.ricks2k.com/products/plateholder.php
...Or you could probably make one with home depot + DIY ability
I'm tempted to try it out (the 'similar model')... Better than the buck tooth.
I used to have no front plate at all but got too many tickets (meter maids give out the tickets where I live so you don't have to be pulled over to get slammed with a $50 ticket).
edit: bought / installed / pics...
I love this part... really minimalist design and it changes the look of the front a bit.
^^ actually used spare gold bolts from an ARC part. JDM Fresh™
NOTE: To install the Rick's part... you need license plate mounts which you can buy for a few cents at any hardware store.
silverF4turbo is offline   Reply With Quote
Old 05-13-2009, 10:06 PM   #2
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
The spacing for the holes should be virtually the same for every USDM car, so yes, it should work fine on your Subaru.
You could get the replica, but I think you could get equally good results with a sheet of aluminum and a drill. Parts don't come much more simple than that.
573 is offline   Reply With Quote
Old 05-13-2009, 10:39 PM   #3
Micker72
Member#: 132820
2005 Impreza RS
they have them at autozone for $10. I got one and painted it flat black, it looks pretty sick
Micker72 is offline   Reply With Quote
Old 05-14-2009, 02:23 AM   #4
pastadog
Member#: 192051
05 suby rex
obp black
at autozone? really, what brand is it and what part of the store r they in?
pastadog is offline   Reply With Quote
Old 05-14-2009, 02:53 AM   #5
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
You might be talking about the generic one with the tilting rotational axis... Those are the kind that I'm less a fan of.
THESE: http://www.sigmaautomotive.com/SeikoSangyo/brackets.php
Too much hardware involved to be cool... should be the world's simplest part
And the Backyard Special one has... SPEED HOLES!!!
Old 09-23-2010, 03:23 PM   #6
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Just ordered one today... with speed holes! (the replica)
I'll post up the results
Old 09-23-2010, 03:28 PM   #7
RaineMan
Member#: 256727
2007 2.5I Wagon
In for pics... I noticed that the dealer screwed a front tag-frame INTO my front bumper and did not use the stock mounting holes. So now I've got 4 holes up front instead of two.
RaineMan is offline   Reply With Quote
Old 09-23-2010, 03:38 PM   #8
vms150
Member#: 172917
2004 WRX
we pretty much all have 4 holes as US plates don't fit in the stock subaru holes
vms150 is offline   Reply With Quote
Old 09-23-2010, 04:27 PM   #9
Sleepy Wagon.
Member#: 132498
98 Lexus LS400/VIP
usVERSUSthem Krew!
USDM!
AutoZone!
Sleepy Wagon. is offline   Reply With Quote
Old 09-23-2010, 05:59 PM   #10
anthony_delprete84
Member#: 88254
That would get you pulled over pretty quick here in Houston. Looks good but I'd rather not call attention to cops
anthony_delprete84 is offline   Reply With Quote
Old 09-23-2010, 06:15 PM   #11
DjMuzz
Member#: 179990
'06 STi - WRB
'03 Ninja 636
Have that same Autozone adjustable bracket! Mines not quite at that much of an angle, but close. Also, not sure how long you've had it, but mine rusted SO fast, so I pulled it off and sprayed it with black rustoleum and it looks much better!
Edit: nevermind.. dont have to worry about rusting in LA
DjMuzz is offline   Reply With Quote
Old 09-23-2010, 06:22 PM   #12
RaineMan
Member#: 256727
2007 2.5I Wagon
Ain't that a bitch.
I noticed the holes were too big... but I figured there was some kind of tag holder that went in the holes and had a mount for a US plate.
I must say, of all the models I like the bugeyes the best. Too bad the odds of finding one with low miles are zero.
Ah well... will have to check out this autozone adjustable tag holder thingy when my plates come in.
Old 09-23-2010, 08:36 PM   #13
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
Originally Posted by Sleepy Wagon. View Post
USDM!
AutoZone!
completely off topic but will wagon bumpers fit a sedan? i think the wagon bumpers look better
japspecjohn is offline   Reply With Quote
Old 09-23-2010, 09:25 PM   #14
WRX USA
Member#: 11192
.. VF48'd Bugeye
Wagon's don't have fender flares so the bumper won't line up unless you do some work on it.
I am curious if there are issues with extreme angles on the plate like the one above and legality.
WRX USA is offline   Reply With Quote
Old 09-24-2010, 01:10 AM   #15
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
if you rock the wagon fenders
you just need to get the wagon front bumper
to accommodate the width as the sedan will be sticking out a tad bit wider.
bbun is offline   Reply With Quote
Old 09-24-2010, 10:07 AM   #16
japspecjohn
Member#: 222993
2003 Stage 2 WRX
Sonic yellow
ahh nm then not gonna swap fenders...I just like how it looks like a molded lip on the bottom
Old 09-24-2010, 03:55 PM   #17
dub c
Member#: 145069
Keep It Sleazy
I bought one a while back, like Sleepy's.
Never did use it.
Get an adjustable one.
dub c is offline   Reply With Quote
Old 09-24-2010, 09:42 PM   #18
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
By the way Rick's Signature Accessories carries the replica Backyard Special
I like to be the first on the block with new stuff but seeing as this is a replica may as well post it
Old 09-24-2010, 09:45 PM   #19
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
me 2
lester mini lip looks similar
I have their full lip sitting in my living room right now
Old 09-24-2010, 09:52 PM   #20
Sleepy Wagon.
Member#: 132498
98 Lexus LS400/VIP
usVERSUSthem Krew!
For people asking if i get pulled over alot for the angle, No i dont. I like to angle it like that so the camera wont see all of it. If they do stop me i would just simply say its loose and i can bend it in front of them. :]
Old 09-28-2010, 02:09 AM   #21
DaltonSR20DET
Member#: 125414
05 Oh-Five Rex
WRB XPT Stage II
Default Get in the ZONE! Autozone!
Yep, I have the same one from Autozone for $10 made by PILOT. This thing rusted SO fast after a rainy day that I'd advise the first thing to do is paint it. Haven't been pulled over in Bay Area California. Not sure if the street light/red light camera's take a clear shot of it but I do know that the FasTrak cameras does miss the front.
DaltonSR20DET is offline   Reply With Quote
Old 09-28-2010, 02:14 AM   #22
FlannelWagon
Member#: 209998
2007 Fxt
Urban Grey Metallic
what happens when the red light camera takes a picture of the rear of the car like they all do?.... lol
FlannelWagon is offline   Reply With Quote
Old 09-28-2010, 02:17 AM   #23
WRX USA
Member#: 11192
.. VF48'd Bugeye
Originally Posted by DaltonSR20DET View Post
...but but I do know that the FasTrak cameras does miss the front.
I have to ask. Did you find out the hard way?
Old 10-13-2010, 03:03 PM   #24
RaineMan
Member#: 256727
2007 2.5I Wagon
Anybody ever get pics of the BYS one on a scooby? My tags came in yesterday... so I guess I'm gonna go over to autozone today and see if they have one of the Pilot ones.
Old 10-13-2010, 08:16 PM   #25
piecemealBHC
Member#: 106248
2015 WRX CWP
2000 RS 2.5
http://www.totsubomotorsports.com/TM...erior_FFLM.htm
It's a little on the costly side, but allegedly it uses the 'factory' holes so that you don't have to drill your bumper.
There's also these for those who don't want a folding style... or prefer to spend their money on fun parts instead of license plate holders.
http://www.totsubomotorsports.com/TM...terior_FLM.htm
piecemealBHC is offline   Reply With Quote
WTB: JDM EXEA EX-45 Tilting License Plate Holder openerup Private 'Wanted' Classifieds 3 04-26-2010 12:55 PM
Where can I get the tilted license plate bracket? under5 Interior & Exterior Modification 14 11-08-2009 11:26 AM
JDM Front tilting license plate bracket Krang Interior & Exterior Modification 7 07-13-2008 07:20 PM
JDM black angled/tilted liscense plate bracket ommmjido Exterior/Styling 3 10-19-2006 04:28 PM
Tilted license plate mount kit? aakrusen Interior & Exterior Modification 18 04-04-2006 06:11 PM
