Old 05-13-2009, 10:20 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default Making power on Cali 91!
This thing did great for straight Cali 91 Octane.
05 STI with:
FP Red 7cm
GrimmSpeed UP with 38mm EWG
Built Shortblock (CP Pistons, ACL Bearings)
Stock Heads/Cams
APS 3.5" TBE
APS Turbo Inlet Pipe
APS Fuel Rails
Deatschwerks 850cc Injectors
Perrin FMIC w/ Perrin Blow-Through MAF
EQ Tuning Short Ram Intake
UEL Headers
Hallman MBC
EQ Tuning Custom Tune using Cobb AP V2
88F Ambient Temps, 20psi peak by 3600RPM
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 05-13-2009, 10:38 PM   #2
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
great numbers on 91!!
trbowrx is offline   Reply With Quote
Old 05-13-2009, 10:59 PM   #3
PikkaGTR
Member#: 179940
2007 Sti
That's awesome spool for a Red
Is it because it's a 7cm or it's EWG? or Both?
PikkaGTR is offline   Reply With Quote
Old 05-13-2009, 11:54 PM   #4
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Wow...that looks great! Any reason you didn't take it any higher? Even with stock heads/cams, it'd probably hold boost/power really well.
zeropsi is offline   Reply With Quote
Old 05-14-2009, 02:53 PM   #5
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
those are great numbers for pump gas!
achavez is offline   Reply With Quote
Old 05-14-2009, 03:03 PM   #6
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
This has to be the best spool from a Red I've ever seen! Looks to be a perfect street set-up, however once you dump a little race fuel in there and up the boost that 7cm^2 turbine housing will really show it's ugly side.
Good job Ed!
Steve.804 is offline   Reply With Quote
Old 05-14-2009, 03:09 PM   #7
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
05 STI with:
FP Red 7cm
Stock Heads/Cams
APS 3.5" TBE
APS Fuel Rails
UEL Headers
Hallman MBC
Thanks
-- Ed
No way dude! Thats sick power, especially for running piss water. This car could probably go 11.4-11.5 on 91, amazing job. I wonder what 93 could have gained over 91. 15whp?? Anyways, looking forward to track numbers.
STi Mikey is offline   Reply With Quote
Old 05-14-2009, 04:32 PM   #8
CatfaceType-R
Member#: 81102
should last a long time with this nice conservative tune, gosh I hate 91...
ed, this guy isn't a fan of the meth?
another nice tune by ed
CatfaceType-R is offline   Reply With Quote
Old 05-14-2009, 04:38 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I attribute the quick spool to the 7cm housing. The EWG certainly helps to regulate boost, but the overall spool characteristics are turbo dependent.
-- Ed
Old 05-14-2009, 04:40 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
We could have revved it out a bit more but decided to keep it safe on the 91 tune. The motor is also barely broken in .
This car will be getting meth injection soon, as well as a race gas tune, so there was no need to push it too hard on 91. Even still, it made awesome power.
-- Ed
Old 05-14-2009, 04:45 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Good job Ed!
You'd be surprised with the 7cm housing with an EWG. The EWG takes a lot of the restriction away because it dumps the gas before it hits the small exhaust housing.
This is the same car and turbo we were pushing to 30psi and 450whp on the stock block on C16 previously. After almost a year of extreme abuse, the stock motor let go on a 115F day. Initially I gave the customer a 50/50 shot of the motor making it through the actual tune at 30psi. He didn't care and wanted to run as much boost as possible at any cost. We tuned it to 30psi, made awesome power with great response, and amazingly lasted almost a year on the weak, stock pistons . Either way, the 7cm housing isn't too much of a restriction if you run it with a good EWG. Its a great combo for all around response.
Thanks
-- Ed
Old 05-14-2009, 05:38 PM   #12
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
nice numbers. thats a lot for 91 oct + a mustang dyno
WREX88 is offline   Reply With Quote
Old 05-14-2009, 06:51 PM   #13
klenboy
Member#: 130521
2006 Subaru STi
Wow that's great top end! I wish I had that to complement my midrange!
klenboy is offline   Reply With Quote
Old 05-14-2009, 06:55 PM   #14
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Thanks
-- Ed
That's great to know Ed. Makes me even more interested in an 8cm^2 with EWG .
And was that 450whp on your dyno software? If so that is incredible! Must have been good for some solid 10 sec passes I'd guess.
Old 05-14-2009, 06:58 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep that was 450whp on my software. Granted it was on a cool night, but it was still ridiculously quick. The best part was there was almost no lag. On that tune, the car would burn through 1st and 2nd, spin a bit into 3rd and I actually got it to chirp 4th!
-- Ed
Old 05-14-2009, 07:03 PM   #16
zeropsi
Member#: 175453
AE86 GT-S coupe
Damn...this is exciting.
Old 05-14-2009, 07:12 PM   #17
CatfaceType-R
Member#: 81102
-- Ed
mr. hardshift your going to drop a tranny one day and run over it while tuning and i'm going to
Old 05-14-2009, 07:50 PM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I used to shift my 5MT like that and never broke anything... I don't see a 6MT going out on me
Old 05-14-2009, 10:31 PM   #19
subenerd
Member#: 72630
2004 STi
Dang, Ed. That is pretty sweet... over 300ft-lbs before 4,000 rpms is awesome, not to mention the top end. Are these the UEL Headers I saw at the shop, the ones your fabricator made?
Also, how is the FP Red turbo in terms of reliability? Just wondering because I seem to find lots of posts on the Green failing but not so much the Red...
subenerd is offline   Reply With Quote
Old 05-14-2009, 10:39 PM   #20
nation1979
Member#: 192914
06 sti
importimageracing is #1
good numbers
nation1979 is offline   Reply With Quote
Old 05-14-2009, 10:46 PM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No, these are just the standard UEL design.. I think they're Gruppe-S.
This turbo has taken plenty of abuse and still seems to be doing fine. It seems like FP has been having more issues with their more recent turbos.
-- Ed
Old 05-14-2009, 10:47 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by nation1979 View Post
good numbers
Thanks... are you still planning anything for your car?
Old 05-14-2009, 10:54 PM   #23
impreza_punk
Member#: 102900
2005 Impreza STi
Nice numbers, makes me think you could achieve better power on Corona light I love the west but the gas is horrific.
impreza_punk is offline   Reply With Quote
Old 05-15-2009, 11:24 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No kidding! Whenever I tune on 93, I feel like I'm working with race gas. Considering, I'm amazed we can make the power we do on our 91.
-- Ed
Old 05-16-2009, 07:59 AM   #25
LittleBlueGT
Member#: 96204
2013 STI GR
Stock compression ratio?
LittleBlueGT is offline   Reply With Quote
Build engine not making power on FP Red pekoso1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 04-24-2010 01:49 PM
Road Tune: 2.5L + Dom4-XTR Makes 470whp on 91+meth Phatron Proven Power Bragging 77 02-25-2010 10:13 PM
Another Badass EQ Bugeye - 397whp on Cali 91 Octane! Equilibrium Tuning Proven Power Bragging 15 06-12-2009 11:54 PM
Very Satisfied > Cobb AP > Stg. 2 Cali 91 Oct. kalbo_1 Proven Power Bragging 21 05-10-2005 10:10 PM
91 octane: does it really reduce power on a stock WRX? robtmc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 01-09-2003 03:47 PM
