Old 04-21-2002, 10:52 PM   #1
booger
Member#: 6446
99 Impreza 2.5 RS
Default car is SLOWER now?!
i just had the act clutch and JUN flywheel installed, and it seems to pull more agressivly in 1st and second gear, mebe third too, but the crazy thing is now my boy in his PORBE GT (200 hp J-Spec motor) that i used to beat is BEATING ME!
it MIGHT be my launches, since i cant just dump the clutch n e more, but even when i beat him off the line he passes me after i shift into third every time. i used to beat him off the line and have enuf power for him not to catch up, but now hes passing me quicker than ever... this blows
current list of mods
ACT clutch
JUN flywheel
short throw
PRM intake
bruillen headers/ cat back exaust
any comments ????
booger is offline   Reply With Quote
Old 04-21-2002, 11:41 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
maybe he is cheating
you shouldn't have a hard time with this with the way you changed your setup. practice launching again
Brad
STiTuner is offline   Reply With Quote
Old 04-22-2002, 01:49 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Well, lets analyze this.
You now have a lighter clutch & flywheel combo correct? So why would your car not accellerate as fast? I'll bet that because of the lighter rotating mass the engine slows down quicker when shifting, thus causing it to have to "catch up" in a sense.
The lightened flywheel not only allows the engine to rev faster, It also allows the engine to lose rpm's faster too. So while your getting used to your new clutch and your glazing the snot out of it before it actually has time to break in properly, Why don't you take it easy & get used to your new setup so that when you and your car is ready, You can beat your buddy.
Tim Sanderson is offline   Reply With Quote
Old 04-22-2002, 02:49 AM   #4
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
how long ago was the clutch installed? a day ago, or a few weeks..
if the clutch was just done in the last day or two your computer was unhooked and lost its settings, it may take 60 miles to re-learn the ignition timing and fuel mixtures..
bobjr94 is offline   Reply With Quote
Old 04-22-2002, 03:32 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
if you are beating on your clutch already then i have NO sympathy for you...and FWIW your but dyno is broken.
Old 04-22-2002, 08:49 AM   #6
BugBomb
Member#: 1342
99 OBS & SUXASS
May your line be smooth
If you recently did an ECU reset, then your power would be at its top. For one, the computer does not change fuel settings for WOT, no matter how many times you reset the ECU. Those values are fixed in your ECU forever. The timing will only get less powerful over time. Timing is changed by the ECU over time to prevent engine damage and does not produce more power. Your car will most likely feel strongest right after a reset.
As far as the combo making your car slower, that is very strange. My times have dropped about 0.36 seconds in the 1/4 since my Clutch/Flywheel/Borla Header install. I also noticed that my brother's GS-R could not pull away from me until ~100MPH (He used to walk away at 70MPH)
BugBomb is offline   Reply With Quote
Old 04-22-2002, 02:28 PM   #7
booger
Member#: 6446
99 Impreza 2.5 RS
well thanks HNDATCH for jumpin to conclutions and flaming me...
i love i-club
YES i did break the clutch in for about 600 miles before i ever raced the car, mainly b/c it was driven from maine to NJ and also b/c i couldnt race the car b/c of bad plugs.
but whatever...
im tired of ppl on this board thinking they are so F***ing smart
i have no sympathy for ppl who act like that, they have no friends
Old 04-23-2002, 01:20 AM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You know it's just miscommunication. You stated that you just got it installed, so thats what i thought you meant. I don't think people are just going to start flaming for no reason. He read it the same as me and we both got the impression that it was pretty new still. Hondatech is a good guy and has helped many people in the midwest forum.
Good luck.
Old 04-23-2002, 02:59 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Good luck.
that's exactly what i thought...just getting something installed means like a day ago to me...sorry i do this stuff every day...i have had to redo cars after 1k miles cause people didn't let the clutch break in. and FWIW my car is tempremental as hell, some days it's fast some day's it's slow...and the WOT maps will never change on these cars.
jeremy
Old 04-23-2002, 04:23 PM   #10
booger
Member#: 6446
99 Impreza 2.5 RS
my bad jeremy i see where your coming from now thanks to tim.
disregard that whole post.
resetting my ecu now... last time i reset it was because i thought it would solve the problem of my fould plugs. Since i installed the new plugs tho i havent been able to reset the ecu yet. mebe thatll clear this all up.
ill gat back later tonite 4 update
Old 04-24-2002, 04:40 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
what color were your plugs which were fouled??
jeremy
Old 04-24-2002, 11:09 PM   #12
booger
Member#: 6446
99 Impreza 2.5 RS
UPDATE
ok, when the plugs were changed they had a bit of brown/orange coloration on the porcelin, the electrodes were a little grey.
but n e way, my car is still slower now than before the clutch n flywheel
ran a 15.9 today, and the probe continued to walk away in third gear. I used to beat this kid by like 2 carlengths off the line and he wouldnt be able to gain on me till like 80mph. I thought the flywheel and clutch would give me better times not worse. With all the money ive put into power mods so far i am really frustrated with the current performance of the car..
Anyone know what i should do? Im almost positive its not a driving skill problem, this is too much of a difference. Also, the rear of the car, as well as right under the center cup holder, is making a repeating clanking noise coming out of first gear. Could the trans have a problem that would make the car driveable but slower? If you were in my situation what would you do?
please help
brent
Old 04-24-2002, 11:11 PM   #13
booger
Member#: 6446
99 Impreza 2.5 RS
bump
Old 04-25-2002, 03:35 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i'm not sure what you did to your car, but i KNOW my car is faster. I run thru the gears much quicker...i went 16.02 @ 82.8 w/ 5800 miles on my car and not knowing how to drive it. YOu might have an O2 sensor getting funky, what gas are you running?? what other mods?? what was your 60ft??
jeremy
Old 04-25-2002, 08:47 AM   #15
booger
Member#: 6446
99 Impreza 2.5 RS
my 60 foot was 2.2
1/8th was 10.1 @ 68.9
1/4 was 15.9 @ 84mph
my reaction time was .989
no other mods than the ones listed above other than a back seat taken out, removed doughnut.
i had 1/4 tank of gas but it diddnt hesitate. The car FEELS a lot faster, cos it revs fast, but its not going anywhere.
i had 84 octane in the car
Old 04-25-2002, 02:16 PM   #16
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
hmm this is weird... does anyone else have the clutch and flywheel done on their cars?
maybe start a new thread with the name "clutch & flywheel lightened problems" etc to get people w/ the set up to give comments?...
i'd like to know why this is happening also as i was planning to do the same setup until now heh
Josico is offline   Reply With Quote
Old 04-25-2002, 04:36 PM   #17
booger
Member#: 6446
99 Impreza 2.5 RS
let me tell you i have never been so depressed about anything until now... im only 17 i worked long hard hours to have these mods on my car... this sucks. what do anyone suggest? should i take it to the dealer? i cant take it back to the place i got the setup done that in maine i live in New Jersey
Old 04-25-2002, 08:51 PM   #18
i realy want the sti
Member#: 11735
2002 RSX type S
Desert silver
I dont know because I dont have a WRX but my best friend does, and he uses 91 octane, and I think with a car this hight performence, you should too. I have an rsx type s and it sais that i need to use premium gas. Doesnt the WRX say that too? my friend said it did. try running it on that for a while.
i realy want the sti is offline   Reply With Quote
Old 04-25-2002, 10:03 PM   #19
booger
Member#: 6446
99 Impreza 2.5 RS
i decided im gona try and find a local (anywhere within a hundred miles is fine if this car gets properly diagnosed and fixed) speed shop or something that has excellent modded subaru experience. something is wrong here and i have no idea why. Also, i think most mechanics really dont know jack s*** when it comes to subarus, and i think somewhere along the line someone that worked on my car really messed up.
Anyone know of any subaru friendly speed shops in NJ or the tri state area?
Old 04-25-2002, 11:17 PM   #20
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
RalliSpec, Ltd.
100 Springdale Rd., A3 PMB255
Cherry Hill, NJ 08003
http://www.rallispec.com
They have an excellent reputation.
JoeT is offline   Reply With Quote
Old 04-25-2002, 11:47 PM   #21
Jademonkey
Member#: 9213
2000 RS
Red
84 Octane?! You should be running at 87 or 89 ! You shouldn't be running premium gas either. For RS's...use 87, and if you mod it, and pinging starts that doesn't go away, try 89. 91+ is too high for an RS. Too much unburned fuel, and you end up loosing performance.
Jademonkey is offline   Reply With Quote
Old 04-26-2002, 12:07 AM   #22
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Hey booger, I'm not going to try and say I can help you because I'm no good at this stuff, but from everything I've ever read, it looks like you SHOULD be making more power, but just read this post that I posted today from SCC.
http://www.i-club.com/forums/showthr...hreadid=178371
Basically, they had their stock car Dyno'd at 177whp -- then they reset the ECU - the best they could get was 167 whp -- and the 10 hp NEVER returned.
Check it out the link and you'll see what I mean.
Best of luck to ya!
CirrusWRX is offline   Reply With Quote
Old 04-26-2002, 12:27 AM   #23
Member#: 11735
2002 RSX type S
Desert silver
Oh, One more thing, and I think this could help. I didnt even realize your car wasnt a WRX,and that it was N/A (used to seeing only WRX threads), but anyway, you have an aftermarket exhaust....did you change your gaskets when you installed it? I know this doesnt always go wrong when you upgrade exhaust, but my gasket went, and the car still felt right, but something was just wrong, and it wasnt as fast. is there less torque? i know i lost torque, cause you lose all the back presure. anyway, I replaced mine, and the second i got it replaced, It felt sooo much different. and FASTER. I could be wrong, but hope this helped. good luck .
Old 04-26-2002, 04:26 PM   #24
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Wow - Call me blind, but I apologize for TOTALLY missing the fact that you DIDN'T have a WRX -- sorry about that!
Hopefully the gasket thing "i really wan the sti" spoke of could solve your problem.
Good luck - let us know the outcome!
Old 04-26-2002, 06:14 PM   #25
booger
Member#: 6446
99 Impreza 2.5 RS
got a CEL today... dunno what thats about
Moms coming home from maine i have to run it by her 2 see if i can take it to rallispec to have it looked at. I hope to god its not something big, but i want a straight awnser from someone who has experience with these cars (not a dealer)
will get back to this thread once everythings fixed
The slow, loud car is slower and louder! ( Q for OT Mechanics) atrodger Off-Topic 8 05-15-2009 10:27 PM
Invidia N1 Race CBE(my car is slower!!) bennd87 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 05-12-2008 08:49 PM
Help! Just installed brullen header/hi-flow cat, but the car is slower! anonymous_wolf Normally Aspirated Powertrain 48 07-23-2005 07:08 PM
my car is slower now... kool168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 06-29-2004 02:13 AM
Ran out of gas. Now my car is slower. Scrappydiggs Newbies & FAQs 16 06-13-2004 04:14 PM
