Old 05-14-2009, 12:58 AM   #1
Jackie
Member#: 81608
Default HID wiring diagram help.
I've seen this diagram recommended several times on this site:
I'd like to build and wire in this harness to my bugeye, but had a few questions.
What is a "high beam selenoid"? Would I interpret this simply as the high beam bulb?
What amp/voltage should the relays be?
What about the fuse?
Also, where can I get automotive relays?
Any input is appreciated,
Thanks.
Jackie is offline   Reply With Quote
Old 05-14-2009, 04:11 PM   #2
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
the "high beam solenoid" is for bi-xenon projectors only. It mechanically moves the cutoff shield out of the way when high beams are activated. You can get relays at any automotive store, standard relays are fine. I believe they are rated at 30A. as for the fuse, I'm not sure, I just asked that question in another thread and I'm waiting for an answer
bcWRX-02 is offline   Reply With Quote
hid wiring diagram Dknits782 Electrical & Lighting 1 12-05-2008 07:34 PM
Wiring diagram help zetecdan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-26-2001 02:06 PM
