Old 05-14-2009, 06:58 AM   #1
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Default Electronic climate control gurus: I need your help!
Or anyone who has a detailed wiring diagram of this system...
This is a fun one. My climate control has pretty much stopped working, although it will start working again if I hit a bump or (sometimes) honk my horn. Yes at this point I expect you to be thinking "WTF?" I'm right there with you.
More details/examples:
Most of the time, my outside temperature gauge will read 100+ degrees though it's much cooler outside. I've already checked and replaced the temperature sensor by the radiator.
A few months ago I was sitting at a red light behind another car. The light turned green, car in front of me hesitated too long for my liking. I honked the horn. Suddenly I had cool air blowing from the vents! I glanced down and my outside temperature reading was quickly dropping to ambient temp. WTF. This sort of thing has been inconsistently repeatable. My coworkers think it's hilarious. "Oh, you're hot back there? Here, let me try honking the horn to see if that helps..." If it works, great. If not, the windows get rolled down.
Recently I've also noticed that hitting bumps in the road can cause the climate control to start working again. On my way to work this morning, for example, my outside temp gauge read 122 degrees and I wasn't getting any air from the vents. I ran over some train tracks and had cool air. Sure enough, the outside temperature gauge was dropping fast. It eventually settled on ambient temperature, ~58 degrees.
My car does not have aftermarket horns or anything wired into the climate control system. It does have an aftermarket alarm (I installed it 5 years ago), but that is not wired into the horns or climate control. This has only started happening within the past 6 months or so, and I have not changed anything electrical on the car in that period of time. This seems like it has to be a loose connection some where, but I have no idea where to look. And the fact that honking the horns triggers it is even more confusing. Maybe there's a relay shared between the climate control and the horns/temperature sensor?
Any help would be greatly appreciated. I wouldn't even bother taking the car some place for an issue like this... It's way too inconsistent.
RP31 is offline   Reply With Quote
Old 05-14-2009, 11:00 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you remove the ground connections to the chassis under the hood and clean them. If that doesn't work then clean the grounds under the dash. Hopefully that will help clear this trouble.
Old 05-14-2009, 11:05 AM   #3
RP31
Member#: 123574
CGM STi
That's easy enough that I'll try it out as a troubleshooting step. Do you have previous experience that made you suggest this, or just a hunch? It certainly couldn't hurt, just wondering if I should get my hopes up beforehand.
Old 05-14-2009, 11:39 AM   #4
Cougar4
Member#: 53443
Winestone
Bad grounds have caused many problems like this. It might not solve the trouble but then it just might.
Old 05-14-2009, 03:51 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
was there ANYTHING done to the car just prior to this issue starting??
ANYTHING????
Old 05-14-2009, 04:39 PM   #6
RP31
Member#: 123574
CGM STi
Hmmm... Nothing out of the ordinary. Winter wheel/tire swap, washer fluid change, and an oil change. I haven't done any real changes to the car in years.
Old 05-14-2009, 05:48 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
no new gauges....or new 'system' or nothing electrical, then???
Old 05-14-2009, 06:03 PM   #8
RP31
Member#: 123574
CGM STi
Unfortunately not. Going to clean up the grounds now. May take a few days to know whether or not that solves the problem... Climate control was still working after the drive home.
Old 05-14-2009, 08:36 PM   #9
RP31
Member#: 123574
CGM STi
Update: Spent about an hour cleaning all of the grounds. Ate dinner, watched some TV, reconnected the negative battery cable and started up the car.
1) Temperature gauge read 110 degrees (read ambient temp when I parked the car).
2) Honking the horn once dropped the temperature reading to 66 degrees.
3) The thermostat in my garage also read 66 degrees.
Old 05-14-2009, 09:02 PM   #10
Cougar4
Member#: 53443
Winestone
Since cleaning the ground connections didn't help I suggest you next remove the cluster and disconnect the connections to it, and then reconnect them back up. Maybe the trouble is due to a faulty connection there. There should be a voltage regulator for those circuits and it is inside the cluster.
Old 05-14-2009, 09:07 PM   #11
RP31
Member#: 123574
CGM STi
That could help, but the most curious thing is definitely how the horn "activates" the temperature sensor without the car moving. I'd like to figure out how they might be connected. Something like that doesn't strike me as a loose connection.
Old 05-14-2009, 10:30 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
vibration of the horn itself....mebbe???
Old 05-15-2009, 03:04 AM   #13
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Yeah, if a bump can cause it to start working, sounds like a bad connection or bad wire somewhere. Perhaps a wire that's been severed, but gets bumped/vibrated back into making contact.
You could try vibrating the frame next to the temp sensor (with something like sawzall or jigsaw without the blade). That might tell you if it's strictly physical (and not related to the horn's electrical circuit).
Since you're seeing wacky temp readings, look closely at those wires trace them back to the A/C control module. Good wiring diagrams would help. A dealer might print off some of the pages for you if you ask nicely.
SVXdc is offline   Reply With Quote
Old 05-15-2009, 08:31 AM   #14
RP31
Member#: 123574
CGM STi
Update from the morning commute: I decided to test out more possible horn connections by disconnecting the horns. When I first started my drive, climate control was working. Hit some bumps and it stopped working. Pressing the horn multiple times did nothing. Eventually hitting some other bumps reactivated the climate control.
Right now front end vibration near the temp sensor is looking like the most likely culprit. Just have to trace it back.
Old 05-15-2009, 12:19 PM   #15
Cougar4
Member#: 53443
Winestone
Here is another thing you could try. The earlier versions had a couple of major wire connections near the battery area. I'm not sure if the newer ones are the same way or not but assume they are. Some folks have solved this kind of trouble by disconnecting and reconnecting the connectors. You can also try using a screwdriver handle to tap on suspected trouble areas to see if you can pin the trouble area down.
Cell phone gurus: Need your help!! JM530 Mid West Subaru Owners Club Forum -- MWSOC 5 02-27-2008 10:34 PM
OT Web Gurus: Need your help kage Off-Topic 3 03-08-2006 06:02 PM
suspension gurus: I need your opinion eyeballs Brakes, Steering & Suspension 23 12-03-2003 05:25 PM
ATTN: electronic masters i need your help White 2.5rs Electrical & Lighting 4 09-16-2003 12:41 PM
Which electronic boost controller is best in your opinion? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 05-18-2002 12:06 AM
