Old 05-14-2009, 10:04 AM   #1
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
Default Subframe brace + Roll cage questions
Ok, I have a 2002 wrx with a 10pt cage. It is mainly used as a drag car but i am really interested in doing some Track days. I would have posted this in the suspension section but it seemed like i would get a better answer here and from someone with experience.
Questions: I currently have a Perrin Subframe brace on the car for the weight savings but i have considered taking it off. Should I...
Go without a subframe brace, the cage is sufficient?
Leave the perrin, not the greatest brace as i have read but with the cage should be fine?
Go back stock, i need the extra support?
Thanks
Phillip
oneoverWRX is offline   Reply With Quote
Old 05-14-2009, 11:31 AM   #2
MasterKwan
Member#: 98961
2003 WRX
I'd say initially it won't matter a lick so, I'd change nothing, do some HPDE's and see if you like them. Just upgrade your pads and fluid and have fun.
Keep in mind that most places require that the instructor have the same protection as the driver so, if you have harnesses and seats, you have to have it on both sides. The place I normally track requires real rollbar padding too, not that useless foam pipe insulation.
Old 07-06-2009, 02:22 AM   #3
cubuff
Member#: 38345
2004 WRB WRX
Bringing back this topic. I would guess it wouldnt matter one bit about your subframe.
I would take it off and save the weight. you have a 10 point cage that is holding the whole car together. There should be zero flex in your chassis.
cubuff is offline   Reply With Quote
Old 07-06-2009, 03:17 AM   #4
shemoves
Member#: 80663
2005 STi
Actually, I could see how the subframe and the cage would work well together. The subframe basically connects portions of the front of the car (effectively in front of the cage) to portions in the center of the car that the cage is supporting.
I'll use a pic of the Perrin and a better underbody shot of the GT Spec to explain.
Perrin
GT Spec
The support of the cage basically 'ends' around the middle of the rear sections of the GT Spec braces. One can see; however, that there is a great deal of room for flex in front of that (in all the various suspension components). Adding the Perrin unit would help tie the front section to the middle (where the cage is). Actually, I wonder if adding just a cage would do some unfavorable things to both handling and component longevity. Having just a cage makes the front end absorb much more of the various forces from a system that was originally designed to also have the chassis helping.
shemoves is offline   Reply With Quote
Roll Cage question Signal Monkey North West Impreza Club Forum -- NWIC 20 07-01-2005 11:54 AM
Roll Cage question STi300 Interior & Exterior Modification 11 06-08-2005 11:16 PM
Roll Cage question ttimpreza Member's Car Gallery 3 05-26-2004 03:32 PM
1320 roll cage question? Tigris Proven Power Bragging 1 02-18-2004 10:27 AM
roll-cage questions axis Motorsports 5 06-21-2002 12:06 PM
