Old 04-22-2002, 12:17 AM   #1
iBlueVirus
Member#: 4679
Default Engine Chock in 2nd at WOT?
I was at autox today and I was in 2nd gear. As I was crossing the finish at WOT, the engine chock like it was engine breaking. My car is stock expect for the tires. Falken A. 215/45/16. Help?
iBlueVirus is offline   Reply With Quote
Old 04-22-2002, 12:58 AM   #2
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Was it your rev-limiter? You said you were at full throttle comming across the finish....
ChosenWon is offline   Reply With Quote
Old 04-22-2002, 01:32 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Did it go out afterwards? I wouldnt worry about it. Take it to the dealer & have them check it out if your worried. I'll bet it's your o2 sensors. OBD2 have one before & one after the catalytic converter. At wide open throttle your probably dumping unignited fuel into the catalytic causing it to burn hot & giving a temporarily false reading. Check your spark plugs & make sure they are gapped correctly and that they are not fouled.
Tim Sanderson is offline   Reply With Quote
Old 04-22-2002, 01:44 AM   #4
iBlueVirus
Member#: 4679
nope not the rev-limiter. I hit it before and I know how it's like. this one felt like bad down shifting or engine breaking... more like engine breaking... Yeah, I am going to bring it in tomorrow and have them check it out... I don't worry about it too much, but just like to know why.
Old 04-22-2002, 03:10 PM   #5
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
How much gas was in the tank and was it right after a sharp turn? Could've been that retarded fuel starvation deal.
Chuck is offline   Reply With Quote
Old 04-22-2002, 05:48 PM   #6
iBlueVirus
Member#: 4679
it wasn't right after a sharp turn. I had about 2.5 - 4 gallon in it...
Old 04-23-2002, 02:34 AM   #7
Blindeye_03
Member#: 4418
2016 Focus ST
I ALWAYS race on atleast 1/2 tank or a full tank. You prolly experienced fuel starvation.
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-23-2002, 10:25 AM   #8
Corey
Member#: 618
2000 2.5 RS #89 STS
MODERacing / Bridgestone
My vote is also for fuel starvation. That is was too little gas to be auto-xing with.
Was the finish line at the end of a long right hand turn?
I usually auto-x with at least 3/4 tank. Anthing less than that and you are asking for fuel starvation.
I've even experienced it with 1/2 tank already and R-compounds with a ton of body roll.
Corey
#89 SM
Corey is offline   Reply With Quote
Old 04-23-2002, 12:13 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have no idea what an engine "chock" is, but if chock = hesitation than I agree that you almost certainly experienced fuel starvation. I, too, have experienced fuel starvation with up to nearly 1/2 tank of gas in the car. That was in my '99 2.5GT. Strangely enough, my '97 seems nearly impervious to fuel starvation - I've run it down to the E on the track and haven't experienced any "chocking".
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-23-2002, 12:59 PM   #10
iBlueVirus
Member#: 4679
I think most of the people race with 1/4 or less at the track... it only happened at the straight finish. It was after a left hand turn, but not too sharp... I've been racing with 1/4 tank for a while and this is the first time... but it's hard to test it out since they change the track everytime... oh well...
Old 04-23-2002, 03:13 PM   #11
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
chock = choke
And my vote goes to fuel starvation. I've suffered from it several times out on the streets.
CosmoTheCat is offline   Reply With Quote
Old 04-23-2002, 03:56 PM   #12
iBlueVirus
Member#: 4679
okiedo! that is actaully a good thing to hear... I still have not gotten a chance to bring this baby in. (midterms)... but I don't think they can reproduce the problem anyway... thanks guys! I guess I'll just go with 1/2 tank next time...
Old 04-23-2002, 04:52 PM   #13
Corey
Member#: 618
2000 2.5 RS #89 STS
I don't know anyone in my region that owns a Subaru and races with less than 1/2 tank. And we usually have 10+ Subaru's at each event.
When I started auto-x I used to go with 1/4 tank. It took just the right set of circumstances but eventually I experienced starvation. Then I got it more and more till someone enlightened me as to why my helmet was hitting the windshield every so often.
Live and learn...
Corey
Check Engine Light at WOT in 4th Aarron_M Service & Maintenance 6 01-06-2007 12:44 AM
Anyone start in 2nd at the drag strip? deblas66 Motorsports 3 08-13-2006 12:22 PM
Upon WOT in 2nd and 3rd, engine shakes codemunky Normally Aspirated Powertrain 3 09-15-2002 01:14 PM
Help! strange fluctuation in boost at WOT!!! speedbuggy67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-01-2002 11:27 PM
Help! strange fluctuation in boost at WOT!!! speedbuggy67 Tri-State Area Forum 5 12-28-2001 06:11 PM
