Old 05-14-2009, 05:10 PM   #1
Un0RiGiNaL
Member#: 189748
Default How to extend o2 sensor without wasting 30$ on extension?
Does anyone know how/ what kind of wire you need to extend the o2 sensor? Im gonna do the borla swap/catpipe and I dont want to spend 30$ on a sensor extension
ive searched but couldnt find out how
Un0RiGiNaL is offline   Reply With Quote
Old 05-14-2009, 05:16 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
i've heard you can get a spark plug anti-fouler and drill it out to allow for an o2 sensor, but have never done it.
Old 05-14-2009, 06:16 PM   #3
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I bought the extension and both connections were wrong so I still have to cut the wires but at least I had the right wires. Sorry I searched forever and couldn't find anything not even the right extender or connectors. I know its a braided small gage wire maybe 16 or 18.
aclver1 is offline   Reply With Quote
Old 05-14-2009, 06:22 PM   #4
piker28
Member#: 22664
After personally cutting up my o2 sensor when i changed out my catpipe. spending the 30 bucks for the extension is WELL worth it
piker28 is offline   Reply With Quote
Old 05-14-2009, 06:55 PM   #5
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i just bought some wire at fredmeyers, and did mine. it was really easy and i havent had a problem yet
olsen726 is offline   Reply With Quote
Old 05-14-2009, 07:39 PM   #6
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
The cat pipes from rallisportracing.com don't require a o2 sensor wiring extension.
blk6s is offline   Reply With Quote
Old 05-14-2009, 10:17 PM   #7
Un0RiGiNaL
Member#: 189748
what kind of wire? thats my main question
Old 05-14-2009, 10:25 PM   #8
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Cut the wire off of a bad O2 sensor. That way you already have the right connector and the wire matches.
GuyLR is offline   Reply With Quote
Old 05-14-2009, 10:37 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
Wire, butt connectors(with shrink wrap, grab a lighter if you don't have a heat gun), wire loom split tubing. I've done this with two O2s so far, zero problems. I run mine with a 3' extension to reach my O2 bung on my aftermarket header. I just grabbed everything from Ace Hardware, and it's all in one isle right next to each other, well at least at my store.
Old 05-14-2009, 10:43 PM   #10
Un0RiGiNaL
Member#: 189748
where can i find this
Old 05-14-2009, 10:43 PM   #11
Un0RiGiNaL
Member#: 189748
what kind of wire? isnt there specific wire?
Old 05-14-2009, 11:38 PM   #12
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The stock wiring looks like 18 ga. wire. If you could go to a junkyard and find a spare sensor in a car or laying around, you could use that, as stated above. If you decide to splice in some extra wire in between the sensor plug and the sensor, you should solder it for a good connection. Shrinkwrap and electrical tape are a must also.
Dont use solid core wire w/e you do.
~Josh~
Old 05-15-2009, 01:14 AM   #13
Forester_007
Member#: 87139
2003 Forester XS
JBP
Use any copper wire splice them to the O2 Sensor to make it longer thats it. NO biggy
Forester_007 is offline   Reply With Quote
Old 05-15-2009, 01:27 AM   #14
AWD_TY
Member#: 183584
BLACK
spark plug anti fouler drilled out works just fine. i have done it on my car and a friends
AWD_TY is offline   Reply With Quote
Old 05-15-2009, 01:29 AM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
Any wire. You just don't use solid because it's not flexible. Any multi-strand wire will do, doesn't need to be big either. 18-22awg, doesn't really matter.
Old 05-15-2009, 01:37 AM   #16
kingbobdole
Member#: 85055
1989 XT-6
Junkyard? I might be crazy, but on my 03 H6 legacy, the rear O2 had a 3' extender the was mounted to the tranny. Unplugged at the front and at the back.
kingbobdole is offline   Reply With Quote
Old 05-15-2009, 08:14 PM   #17
WcW
Member#: 209963
The JDM sensor for the N/A ej25 (my95-?) Legacy has a 26 inch pigtail. The pins are easily swapped from the JDM square connector to the USDM triangular connector. Maybe this is some help somehow.
WcW is offline   Reply With Quote
Old 05-15-2009, 08:47 PM   #18
Un0RiGiNaL
Member#: 189748
I picked up some 10GA wiring is that fine? i forgot what ppl said in this thread when i was there so i just got some 10GA. i got the sleeves and the loom tubing. Is 10Ga wire fine?
WTF is solid core wire?
Old 05-16-2009, 04:32 AM   #19
SubiFTW
Member#: 138728
MY06 2.5i Impreza
Just use romraider and wipe the code from your ecu completely, it'll never come back again.
SubiFTW is offline   Reply With Quote
Old 05-16-2009, 09:41 AM   #20
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Solid core wire is just that - it's like insulated coat hanger. Used a lot in house wiring because it's cheap.
10 gauge sounds somewhat excessive. It will work just fine, but will look.... odd.
sniper1rfa is offline   Reply With Quote
Old 05-16-2009, 12:34 PM   #21
Un0RiGiNaL
Member#: 189748
eh ill just go pickup some 18ga it was only like 60 cents
Old 05-16-2009, 04:45 PM   #22
scoob2.5i
Member#: 181914
dude its SOOOO easy to extend.
snip the wires, strip the wire, take 18ga wire and extend each wire the same amount of distance, but dont twist it all up. solder the connections to make sure they're strong. heat shrink it, then electrical tape the whole length of the extension to make sure. I did this when i did the uel on my 2.5i
SOOO EASY and worth saving the $30 each extension.
GOODLUCK buddy
scoob2.5i is offline   Reply With Quote
need to buy o2 sensor extender ASAP!!! WHERE?!?! maxipad Vancouver Impreza Club Forum -- VIC 6 08-30-2007 11:51 AM
Extending O2 sensor wire for Vishnu turbo-back? mhlady Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-27-2004 07:11 PM
What gauge wire to extend O2 sensor? hossak8 Electrical & Lighting 3 02-22-2004 09:03 PM
extending O2 sensor wiring Overtime Electrical & Lighting 5 12-22-2003 12:25 PM
how to install O2 sensor, fuel filter and air control valve Suladed Service & Maintenance 4 11-11-2001 09:30 PM
