Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 05-14-2009, 09:49 PM   #1
Rokkit
Member Sales Rating: (23)
Member#: 84181
NASA #530 GTS2
Default Clutch, Flywheel, turbo X-members, Linkage, Diff
5 MT Driveshaft, OEM - 120k - Offer?
Rear Axles Only - 120k - $80+shipping Fronts Sold
R160 WRX Rear Diff - 75$
Turbo Motor X-Member - 150$
Transmission X-Member - ??? Offer
Rear WRX Subframe - $75
WRX Shift Linkage - $35 (With upgraded bushings)
Excedy Stage 1 Organic Clutch - 20-25k Miles - SOLD
5 Speed Flywheel -20-25k Miles - SOLD
Rokkit is offline   Reply With Quote
Old 05-15-2009, 02:02 PM   #2
cordizzle
Member Sales Rating: (1)
Member#: 55109
2006 sti
is this excedy clutch in good condition? most likely interested
cordizzle is offline   Reply With Quote
Old 05-17-2009, 12:25 AM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
clutch and flywheel pending
Old 05-19-2009, 10:47 PM   #4
dirtbikeridr12
Member Sales Rating: (19)
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
is the rear diff still 3.54 or is it 3.9?
dirtbikeridr12 is offline   Reply With Quote
Old 05-21-2009, 06:47 PM   #5
Rokkit
Member#: 84181
NASA #530 GTS2
It's a stock 2002 wrx rear LSD which i believe is 3.9
Old 05-24-2009, 08:10 PM   #6
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
Question
do you have the rear diff still? and have the ring and pinion been changed? because my 03 is a 3.54 but if you think this diff is a 3.9 is there a wa you could check and make sure?
also what is the x-member out of? i need one for my 6mt swap for my 03 wrx
thanks
tim
Old 05-25-2009, 09:50 PM   #7
oops2low
Member#: 212110
how much for the linkage shipped to 32607
oops2low is offline   Reply With Quote
Old 05-26-2009, 09:35 AM   #8
Rokkit
Member#: 84181
NASA #530 GTS2
thanks
tim
Ok, checking my sources the 02-03's have a 3.54! so its a 3.54! stock 02 diff!
X-member is out of a wrx - If you're talking about the transmission xmember i believe they are the same but the tranny mount is different.
Old 05-31-2009, 12:15 AM   #9
wickedscooby
Member Sales Rating: (15)
Member#: 55963
99rs sti v5 LISC #57
how much for the 2 front axles shipped to 11716??
wickedscooby is offline   Reply With Quote
Old 06-01-2009, 09:25 AM   #10
Rokkit
Member#: 84181
NASA #530 GTS2
PM'ed you both
FS: Spec B 6-speed tranny, clutch, flywheel, center diff, and rear diff CHEAP dahane Legacy Specific Parts 5 12-23-2009 03:22 PM
fs: 02 wrx clutch, flywheel, driveshaft. diff, trans with linkage mprex02 Drivetrain 4 10-14-2009 01:55 PM
04 sti clutch, flywheel,preasure plate, shift linkage Redscoob Drivetrain 0 01-03-2008 06:11 PM
sti r180 rear diff NEW, r160 rear diff, 3.90 ring and pinion, clutches/flywheel gimmewar Drivetrain 5 02-06-2007 05:14 PM
sti r180 rear diff NEW, r160 rear diff, 3.90 ring and pinion, clutches/flywheel gimmewar SCIC Private Classifieds 2 02-03-2007 04:07 PM
