Old 05-15-2009, 12:58 AM   #1
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
Default Stock Coolant temp gauge in 04' STi cluster not working
So i just installed my used 04' STi cluster into my 2002 Bugeye. i followed the couple threads on what wires to cut and the plug to file down that are here on nasioc.
Everything went well when i start up the car all gauges do the sweep like normal but after my car warms up to operating temp it does not register on the gauge, i know its warm since i drove it around and checked the coolant hoses and they are hot, i know that it should be warm but it is not shown.
So i plug my old cluster, coolant temp works and the needle is sitting where it is supposed to be. So does anyone know whats wrong with my cluster? anyone else with this problem ever.
Also my fuel gauge wont go to the full line, im used to it sitting just above when i fill my car, i even went and topped up my tank till it was nearly overflowing and it sits just a needle width or so below the full line.
Anyone with some imput thanks
bugeyesubie is offline   Reply With Quote
Old 05-17-2009, 12:52 PM   #2
bugeyesubie
Member#: 179783
no one?
Bump
Old 05-17-2009, 05:36 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would suspect that sensors are different resistances for both the temp and the fuel level so they aren't calibrated to the newer gauges. You can easily try replacing the coolant sensor from a '04 model I would think. The fuel sensors may be more difficult and expensive to replace.
Never top off your tank as it will damage the charcoal filter.
Old 05-19-2009, 07:19 PM   #4
bugeyesubie
Member#: 179783
hmm ok, ithe only thing is there is a number of people who have done this swap into there 2002/2003 wrx and i havent read anything about this same problem, i am thinking ill do a defi coolant temp gauge anyway just hopefully the fuel will start working,
Coolant Temp gauge not reading badchad Legacy Forum 6 07-16-2008 12:32 AM
2007 STi tranny in 2004 Sti - DCCD not working ? salt Transmission (AT/MT) & Driveline 0 04-11-2008 12:25 PM
Coolant temp gauge on cluster not working - JDM STi V7 Swap moss Subaru Conversions 7 10-14-2007 03:15 AM
Stock coolant temp gauge fluctuating Cation Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-14-2006 10:47 AM
oem coolant temp gauge not working... czo79 Legacy Forum 0 08-01-2003 02:11 PM
