Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 05-15-2009, 01:11 AM   #1
Splash
Member#: 55936
04 WRX STi
Default STU(X) Koni Bumpstops
Those running ZZYZX or Ground Control Konis, Did ya cut the stops (or run any at all)?
Splash is offline   Reply With Quote
Old 05-15-2009, 01:33 AM   #2
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I run ground controls and don't run any bumpstops in the front and full size ones in the rear. My springs will fully compress before my struts bottom out.
pignoseSTI is offline   Reply With Quote
Old 05-15-2009, 07:23 AM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
zzyzx.
No bumpstops.
mccanixx is offline   Reply With Quote
Old 05-15-2009, 08:42 AM   #4
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
zzyzx
no bump stops
Patrick L is offline   Reply With Quote
Old 05-15-2009, 04:37 PM   #5
Splash
Member#: 55936
04 WRX STi
Hmm, there seems to be a pattern there... <grin>
I assume everyone's springs are pretty stiff to start with and figure you'd just let the coils bind, assuming you could put enough load on them to do that...
I think I'm in the same ballpark then...
Old 05-15-2009, 11:24 PM   #6
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
~800lb springs here, should never bind lol
Old 05-16-2009, 02:37 PM   #7
Splash
Member#: 55936
04 WRX STi
Yeah, I bet you do.. 295 Hoosiers will do that.. Whitmire's car had 1050's up front (no bar). I have 600's on ST rubber.
Old 05-16-2009, 07:17 PM   #8
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
450/500 lb/in springs, 13.6" ride height. I cut the bumpstops a little bit based on Scooby921's experiences last year - he cut off the top nub on his and was able to run lower with better ride quality. I drive the car on the street for probably 10K miles a year so I wasn't willing to go no bumpstop - I have Hypercos so they have a lot of travel before binding.
I need a pic of OEM WRX bumpstops bad!!! or know if all Subaru bumpstops are the same Ohannon7 Brakes, Steering & Suspension 5 04-20-2006 12:40 PM
02/03 Koni inserts vs. 04/05 Koni inserts Ski Bum Brakes, Steering & Suspension 13 11-07-2005 10:11 AM
Opinion: Koni/ prodrive vs Spec C, vs Koni/ stock springs ShawnRS Brakes, Steering & Suspension 5 06-17-2005 10:44 AM
Opinion on: Koni Sport; Koni v/ GR-2/AGX on GC/GF Luxter Brakes, Steering & Suspension 13 11-23-2003 11:32 AM
cutting bumpstops wistful Brakes, Steering & Suspension 8 03-15-2001 01:27 AM
