Old 05-15-2009, 01:22 AM   #1
xazzu
Member#: 129036
2006 WRX Sedan
Default What size bolt on the driver's side exhaust bushing
Apparently lost it somewheres. Going to stop by the Home Depot tomorrow to pick up a replacement, but can't seem to find what size it is. Preeze halp!
xazzu is offline   Reply With Quote
Old 05-15-2009, 02:10 AM   #2
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
What do you mean by drivers side exhaust bushing?
And I like your location.. I am moving there in July to go to full sail. Look for me cruisin around.
evan_impreza is offline   Reply With Quote
Old 05-15-2009, 08:19 AM   #3
Rodwrx23
Member#: 170948
I think he's talking about the one that goes through the collar inside the exhaust hanger and gets bolted into the bracket on the driver side. Don't know what the size of it is but the thread will most likely be 1.25. I would suggest taking the hanger with the collar inside of it and finding one that will fit through. I would try a M10x1.25. I also thing there was a comprehensive thread with bolt sizes somewhere.
Rodwrx23 is offline   Reply With Quote
Old 05-15-2009, 09:30 AM   #4
xazzu
Member#: 129036
2006 WRX Sedan
Robwrx23 is correct, it's the bolt that goes through the top of the driver's side bushing through the collar there. Sorry I responded so slow, I hit the sack after I got home last night. If anyone has a better idea of length, etc, let me know, I'm heading out to get one at lunch.
EDIT: Unofficial FAQ: Bolt Sizes , looks like it is 10x1.25, though they mention something about the head size having to be 14mm. If it's 12mm, then the bolt is 8x1.25. I'll probably just buy both.
And evan_impreza, welcome to the area! Good luck with the 3am classes, I had a few buddies that went there a few years ago. Give me a shout when you're in town, we'll go have a beer.
Old 05-15-2009, 01:15 PM   #5
Rodwrx23
Member#: 170948
I'm positive that it's a 14mm head from the last time I swapped rear sections so it looks like my guess about the M10x1.25 was correct.
Old 05-15-2009, 05:58 PM   #6
xazzu
Member#: 129036
2006 WRX Sedan
It was indeed M10x1.25. I picked up a 50mm, but 40mm should do it as well. I made sure it was grade 8 (says 8.8 on the top). I was a 17mm head.
Thanks everyone!
what size and pitch is the banjo bolts on the td04 turbo. supernick77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-22-2009 02:01 PM
what size bolt and nut are the ones on the turbo? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-14-2009 12:37 PM
What size bolt on airbox? PoopRSkupe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2007 01:47 AM
What size is the torque bolt on the injectors on an 05 STi? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-10-2006 03:40 PM
what size bolt is the drain plug?? jmott Texas Impreza Club Forum -- TXIC 4 11-16-2002 04:42 PM
