Old 04-22-2002, 01:54 AM   #1
G-REX
Member#: 8804
2008 Impreza STi
Dark Gray Metallic
Question Head spacer?
Going with a thicker head gasket effectively drops the compression in the cylinders. Not by much though.
So has anyone fabricated a custom "spacer" that goes between the head and the block? It would use two gaskets; one between the head and spacer, and between the spacer and block.
Does something like this exist already?
I'm thinking a metal plate about 1/2 inch thick and takes the shape of a gasket. What could be the compression drop from say 10:1? Speculation welcome.
Also, what would you think the problems with this would be? I would think probably the bolts would be too short, and maybe there would be a clearance issue since the heads are further from the block, but that's really it.
EDIT: Hmm, just thought about something. The exhaust might not line up correctly, and maybe the fuel rails.
G-REX is offline   Reply With Quote
Old 04-22-2002, 02:25 AM   #2
Andrew
Member#: 1170
2005 STi
if you want to lower the CR, this isnt the proper way. do it by changing out the pistons.
Andrew is offline   Reply With Quote
Old 04-22-2002, 02:35 AM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
this will drop it to what? 9.9:1?
KillerTHC is offline   Reply With Quote
Old 04-22-2002, 03:28 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
actually MR gasket just released a new series of head gaskets w/ spacers...my boss has one and we'll see how it works...as you all well damn know i DON'T trust gaskets to lower CR in high performance applications...but i do know that the MR gasket piece lowers compression from 9.6:1 all the way down to 8.2:1 at it's thickest setting...pretty unreal...we'll have to see how it works...the next concern would be the lack of length in the timing belt to take advantage of this.
jeremy
edit: i can type 90WPM....but no one said i had to spell at the same time.
Old 04-22-2002, 10:17 AM   #5
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
As Jeremy stated I would be concerned about the timing belt length and the fact that with our flat engines you can't space the heads out too far before you will need to "modify" the intake manifold and the exhaust manifold to fit.
When I used copper head gaskets that were about 2x's as thick as stock, the intake manifold barely would bolt on without modification. Any more distance and I would of had to enlarge the bolt holes in the manifold.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 04-22-2002, 12:36 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
aaron brought up a point i totally forgot about last night...you have to consider the fact that you will be effectively lengthenging the short block. anyhow...get the pistons...do it right and do it once.
jeremy
Old 04-22-2002, 01:36 PM   #7
Jewbaru
Member#: 1994
2013 Impreza WRX
I was reading about "Squish" the other day, and by using a larger gasket, you're screwing up the "squish" of an engine. This can lead to problems.
Jewbaru is offline   Reply With Quote
Old 04-22-2002, 08:38 PM   #8
STiTuner
Member#: 5778
09 135i
Jet Black
if you did this on a boxer motor wouldn't you need a custom header?
Brad
STiTuner is offline   Reply With Quote
Old 04-23-2002, 02:49 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Brad
there is a slight amount of space to go......but theoretically yes.
joel-yes it does mess with the "squish" area designed in the piston.
jeremy
Old 04-23-2002, 11:25 AM   #10
Jewbaru
Member#: 1994
2013 Impreza WRX
Originally posted by HndaTch627
andrew-yes it does mess with the "squish" area designed in the piston.
jeremy
Andrew said that? I thought I did.
Old 04-23-2002, 01:04 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
sorry joel i tend to read thru things too quick and not pay attention all the time....changed it....my bad.
jeremy
Old 04-23-2002, 04:24 PM   #12
Andrew
Member#: 1170
2005 STi
you think i would know what squish is jeremy? !!
Old 04-24-2002, 03:02 AM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you've been surprising me lately once again sorry joel
Used EJ257 2.5L shortblock Cheap! $650 Grimmspeed intake mani spacers OEM Head gasket big67 Engine/Power/Exhaust 4 07-29-2015 01:01 AM
VOLK CE28N 18x8.5 5-100/New VOLK TE37 SL/ENKEI GTC-01 19x8.5 +42/Lug Nuts & Spacers!! Fizz Autosports Wheels/Tires 39 07-28-2010 10:25 AM
FS : 25mm 5x100 wheel spacers $50 (pair) SmokedWRX SCIC Private Classifieds 4 06-05-2010 11:55 AM
$250~OBO Pioneer head unit+Polk Audio Speakers+Door Spacers+4gb FlashDrive+Wiring Dz1978 NESIC Private Classifieds 6 06-01-2008 09:43 AM
MR Gasket Head Spacer Fails HndaTch627 Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-28-2002 02:13 AM
