Old 05-15-2009, 10:10 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default White smoke and Turbo oil supply
I have allready done major searchs on the subject so please dont flame me. I recently started up my offroad 2.5 RST project engine. It has major white smoke coming out of the exhaust that would typically Indicate a blown head gasket. It does not do it all the time and when it does its worse at higher RPM. It is not your normal condensation smoke. The smoke does not smell like coolant or burning oil. I have done compression checks hot and cold and they are good with only a few pounds drop from cold to hot test for a motor with 100K miles on it. The motor runs good. There is no oil in the coolant and no coolant in the oil and no external leaks. Currently it has 440 Injectors in it with out my greddy connected so it would be running rich however I would expect to see black smoke if that helps. I discovered the Turbo was leaking a lot of oil into the exhaust and had to have it repaired (was a brand new center core). I reinstalled it and it still leaks a lot of oil. I Installed a petcock to reduce the flow to it and that helped however it still has a lot of oil going into the exhaust. The feed line is a 3an. I had this turbo on the 2332 VW motor wiith the same feed line and it did not puke oil out of it. Because the motor has 100K miles on it and with the Turbo I am debating on changing the Head Gaskets just to eliminate that possibilty. Pleas help!
Odyknuck is offline   Reply With Quote
Old 05-15-2009, 07:56 PM   #2
front runner
Member#: 121603
2001 legacy BH
blue
do a quick check of your oil return line. any restrictions could cause oil to leech out to the exhaust and intake side...it happened to me.
front runner is offline   Reply With Quote
Old 05-15-2009, 10:17 PM   #3
Odyknuck
Member#: 192866
2006 Impreza
I "T" the return into one of my dry sump scavenage lines so I wanted to be able to see how well it returned so I used 5/8" ID clear braided hose and the oil flows well. I am thinking that with the added Vaccumme of the pump I may be allowing a lot more oil flow and I am going to try a restrictor in the Supply line.
Old 05-31-2009, 05:13 PM   #4
Odyknuck
Member#: 192866
2006 Impreza
Update,
Replaced both head gaskets and no more white smoke. No Indication of a blown head gasket however they cured the problem. I did go with the thicker DOHC to lower the compression a little.
Fuel smell/white smoke and oil (something wet) leak from turbo after up-pipe install DriftIt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-17-2009 03:37 AM
white smoke and burning oil question .. joe_black Normally Aspirated Powertrain 7 12-15-2006 09:20 AM
Shortblock swap problems: White smoke and leaking oil jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-19-2005 12:45 PM
Shortblock swap problems: White smoke and leaking oil jefersun Texas Impreza Club Forum -- TXIC 11 09-19-2005 12:49 AM
White smoke and burning oil? JayD707 Service & Maintenance 12 07-16-2005 11:47 AM
