Old 05-15-2009, 11:35 AM   #1
KENT56
Member#: 163129
Midnite
Default 02 to 05 HID rewiring, help please
hi all, im doing front conversion from 2002 to 2005, i need help with rewiring. I got OEM wrx plug, on the 05lights i have connectors but nothing like on my wrx ... please help
KENT56 is offline   Reply With Quote
Old 05-17-2009, 02:00 AM   #2
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
The bug eye headlights are dual filament bulbs. So the one wire the connects to the bulb would need to be spliced into the high beams of the 05 wrx headlights and one directly to the low beams. Then as for the turn signal and parking light wiring, I'll have to double check on it. I'll see if I can get you some pics as to how mine were wired. I hope this helps you somewhat....
Project Barnie is offline   Reply With Quote
Old 05-17-2009, 09:30 PM   #3
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Post pics of your plugs, i'm sure you will get more help that way.
As far as powering your 05' HID's you are going to need to make harness that pulls power directly from the battery, is grounded to the chasis, and has a relay that is activated by the lowbeam switch (the wires that were used to power your stock WRX lowbeams).
As far as the highbeams, like P. Barnie mentioned, you are going to need to splice into your stock (WRX) high beam connector (same plug as your low beam, since both lows and highs were produced by one bulb in your 02') and just hook those up to your 05' wires. no relay is needed for the high beams.
Like P. Barnie, im at a loss for the turn signals, but im willing to be the plugs are very similar.
EDIT: Here is a diagram, most of this you wont need, but look on the left hand side for the 9007 headlight plug (your stock 02' wrx plug) this should help you see what i'm attempting to explain.
EDIT #2:
It looks like after re-looking on that wire diagram, if you disregard the diagram on the bottom (the one with blue lines), and only mimik the one on top, that should tell you how to make your wire harness for your lowbeams.
Then for the high beams, just splice the common +++ and the high - to your 05' high beams, and you should be in business.
***The diagram is not mine, I DID NOT create it, i used it in a thread of mine, which references the originator of it. Please give credit to him.
Original Thread: http://forums.nasioc.com/forums/show....php?t=1544617
skingfreak is offline   Reply With Quote
Old 01-18-2012, 11:55 AM   #4
spydernooby
Member#: 307299
is there anywhere that sells a wiring harness to for a conversion from stock 2002 wrx bugeye headlights to a 2004 sti blobeye hid set?
or is there a detailed instruction guide on how to do it. iv searched all over and cant find any clear instructions.
spydernooby is offline   Reply With Quote
Old 01-18-2012, 12:09 PM   #5
infinite012
Member#: 74392
2015 Forester
Contact Lightwerkz.
infinite012 is offline   Reply With Quote
Old 01-18-2012, 12:14 PM   #6
spydernooby
Member#: 307299
will do, just emailed them. hopefully they sell a easy plug and play harness as im not to good with electrical nor do i think my body shop is.
Old 01-18-2012, 12:29 PM   #7
infinite012
Member#: 74392
2015 Forester
If your body shop can't do electrical work, they shouldn't work on cars.
Old 01-18-2012, 12:56 PM   #8
spydernooby
Member#: 307299
mmh true, iv never used this body shop. referred through a friend. im sure they can do simple electrical but i dont know if they would have figured out the headlight wiring without help. i know i wouldnt have.
Old 01-28-2014, 05:05 PM   #9
SpOoLiNwHoRe
Member#: 108361
2004 STi
black
Did lightwerkz ever respond about a plug and play harness for 02to04-05?
SpOoLiNwHoRe is offline   Reply With Quote
Old 01-28-2014, 08:20 PM   #10
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
2 years later? just email Lightwerkz on your own, chances are they will reply sooner than OP
aerosaaber is offline   Reply With Quote
02 WRX turbo problem need help please vroomvrroom7 Normally Aspirated Powertrain 3 02-16-2006 03:31 PM
05 Wagon Need Help Please benji25 Brakes, Steering & Suspension 7 10-24-2005 02:57 PM
PICs request please, 02 to 05 imprezas on prodrive 1 rims chanyeehon Member's Car Gallery 4 09-15-2005 03:49 PM
Le28Ns on 05 STI need help please WRXTwiztid Tire & Wheel 7 02-01-2005 01:02 PM
I have 10 days to get my car to pass inspection.. DFW help please. Texas25RS Texas Impreza Club Forum -- TXIC 37 01-25-2005 11:47 AM
