Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-22-2002, 02:42 AM   #1
webkris
Member#: 70
I sold WRX to buy
Dodge Neon Rally Car
Talking No need for an MBC with Boost Monkey to get 17psi!
LATEST NEWS:
4/22 - Boost "cap" solved! Boost Monkey CAN make MORE then 15psi ON IT'S OWN! Small things make a big difference... We once thought that the solenoid could only bleed enough to make 15psi of boost. We once thought that the pipe that connects the solenoid was just a "junction" between two pipes. We once thought that you would need an MBC as a restrictor to get the boost past 15psi. Nope, wrong, and no. You see we have been testing with every possible combination of bleeder pipe, MBC, and solenoid setting. Removing stock piping, and replacing with bigger fittings... Connecting the MBC before and after the solenoid... Finally last night after a series of over-boosted horrible results - I configured one last test, and went to bed tired. We would see if that made any difference in the morning.
Hopped into the car to head to a NESIC cookout. I turned out of my driveway, and quickly accelerated to get out into traffic. "WOW! That felt strong! How much boost was that??" I asked my co-driver Jeremy. "That felt like more then 14..." he replied. We went WOT again to see where the max boost was hitting. 17psi! Not spiking to 17... Holding steady at 17psi... "What did you do?!"
Well - you know that restrictor pipe that everyone talks about? Well we learned that the stock system really has 3 restrictors in it.
1. The hose with the restrictor piece in it.
2. The T fitting. This acts as a restrictor between the wastegate and the solenoid.
3. The connector piece. That joins the grey hose from the T fitting to the black hose of the solenoid.
Removing just #1 [the restrictor piece] and replacing it with an MBC still works - but some MBC's are not sensitive enough to restrict only 2psi of air. The Hallman is capable - but read more. Removing just #2 [the T fitting] and replacing it with a much larger 3/16" fitting causes the max boost to drop 2-3psi. Removing just #3 [the connector piece] and replacing it with a larger 3/16" connector makes the efficiency of the solenoid increase, and bleed off more air - making more boost without the MBC! We had to turn the Boost Monkey down halfway in order to get only 15psi of boost, and all the way down still resulted in 12psi of max boost.
Why this is perfect! As most of you know the TD04 Turbo in the WRX runs out of steam at 16psi at high RPM's. There is no real benefit to running close to the boost cut, and pushing over that. Now all you'll need is the Boost Monkey to make up to 17psi of boost. Now for the "10 percent'ers" out there that remove the boost limiter, build their motor up, and want to run 20+psi of boost might I suggest the Hallman Boost Controller + Boost Monkey to make that a very steady 20psi...
So - How exactly do I make more than stock boost with my Monkey? (Pictures Soon) Look at the piping by the turbo. Find the T fitting. See the grey hose that heads for the solenoid? Look at how it goes to a connector, and turns into a black hose that connects to the solenoid. REMOVE that connector, and replace it with a 3/16" connector. TURN Boost Monkey's "boost setting" ALL THE WAY DOWN, and increase boost setting slowly until desired max boost is acheived.
Look for Boost Monkey reviews to start popping up - as the first batch was shipped last week.
Thanks,
Kris
http://www.boostmonkey.com
webkris is offline   Reply With Quote
Old 04-22-2002, 03:04 AM   #2
TurboWRXImpreza
Member#: 9911
2008 STi
Lightning Red
Nice product!! Very ideal and great price too!
I'm in !!!!
Raymond
PM'ed ya
TurboWRXImpreza is offline   Reply With Quote
Old 04-22-2002, 07:50 AM   #3
VetteVert
Member#: 5961
2005 STi
CGM
Looks good. Can't wait to see the results. So what occurs with the #3 restrictor replaced with a bigger unit....with no other modifications?
VV
VetteVert is offline   Reply With Quote
Old 04-22-2002, 10:34 AM   #4
WR-REX
Member#: 5250
2007 Tundra RCSB 5.7
Is it still ok to install if you dont have a EGT gauge?
WR-REX is offline   Reply With Quote
Old 04-22-2002, 10:42 AM   #5
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Question small question
Hi, I've looked at your web site and it appears that the "boost monkey" is a square wave generator and it varies the pulse to change the boost...is this all it is doing?
No offense meant, just curious.
Sordid Philosopher is offline   Reply With Quote
Old 04-22-2002, 12:25 PM   #6
webkris
Member#: 70
I sold WRX to buy
Lightbulb Q&A...
VetteVert: I would guess that the car would run a bit higher boost stock. But - as the car is reading the MAP, it would "learn", and turn the boost down to stock levels by not operating the solenoid at the same duty cycle. I'll have to try that, and see how crazy it gets.
WR-REX: Yes. It's okay to install without an EGT gauge. As long as you set the Boost Monkey to engage at more then 70% throttle, and plan not to run more then 16psi of boost. We have taken EGT readings off several cars, and have never seen higher then 1450F degrees with light throttle acceleration with this setup... Remember though - You can still setup the boost monkey to be on all the time (or right when you touch the gas) Doing this WILL give you High EGT's during light throttle acceleration, as it's now acting like an MBC. This is why we recommend an EGT, but if you follow the rules above - you don't need one.
Sordid Philosopher: Yes it is. It also reads the TPS voltage, and engages the boost based on that. This IS something that you can build yourself if you have the time to bread-board the circuit, design a board, etch a board, get all the components working, etc. In order to get a setup that was perfect it took us about 2 months of prototyping.
Thanks,
Kris
Old 04-22-2002, 12:42 PM   #7
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
sorry for the question (I am an EE - does it show), I wouldn't deny you either your profit or your r&d testing to get it right...just curious. Sounds like a great device.
Old 04-22-2002, 01:17 PM   #8
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 04-22-2002, 01:27 PM   #9
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Thumbs up
Kris -- I bought a 3/16" nylon coupler at Aubuchon Hardware during my lunch break, and just installed it. It works perfectly!
... and just when you thought the BoostMonkey couldn't get any better...
/Andrew
Kha0S is offline   Reply With Quote
Old 04-22-2002, 01:27 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
kris have you though a way to make boost monkey take a nap?
or pass through switch?
so a guy could run in STX on the weekends and real boost the rest of the time...
Old 04-22-2002, 01:28 PM   #11
Lerxtwood
Member#: 17070
Default Re: No need for an MBC with Boost Monkey to get 17psi!
Kris,
This is fantastic news! Hopefully this will eliminate the need to install a MBC in conjunction with the Boost Monkey where I was just interested in upping the boost to around 16lbs to compensate for our crappy high altitude air!
Also, it looks from the tracking number like my Boost Monkey should arrive today. Could you please post some detailed photos (when you get them) showing exactly where this connector that needs to be replaced is, either to this thread or to my email address? Thanks!
Originally posted by webkris
LATEST NEWS:
Thanks,
Kris
Lerxtwood is offline   Reply With Quote
Old 04-22-2002, 02:45 PM   #12
webkris
Member#: 70
I sold WRX to buy
Hehe - It's SNOWING in Manchester, NH right now - but I'll try to get some clear shots of the piping.
- Kris
Old 04-22-2002, 02:47 PM   #13
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Yes, yes... it is snowing. Muahah.
I think I know what I'm doing after work with my new skidplates...
Kris -- if you can't get pictures before this evening, I can go outside at the office and snap a few.
/Andrew
Old 04-22-2002, 04:16 PM   #14
john banks
Member#: 11669
Evo IX 345 WHP
You can get over 25 PSI if you like (with a fuel cut lifter/defender and you are stupid enough) if you just plug that little brass restrictor with solder and redrill it. No need for an MBC. 1.1 mm will allow you to go substantially higher. 1.0mm and you can go well over 20 PSI. I did not try a 0.8mm for obvious reasons If you guys like inches 1 inch=25.4mm - sorry if that is patronising, but it wouldn't be the first time someone asked me to convert for them!
Oh, BTW, solder has a perfectly high enough melting point, and I have been running like this for months.
john banks is offline   Reply With Quote
Old 04-22-2002, 04:39 PM   #15
Tex-WReX2
Guest
Member#:
Default Re: Re: No need for an MBC with Boost Monkey to get 17psi!
Originally posted by BOP
Yeah, I noticed that too when I was installing TurboXS stage 2. It includes an ABC (basically, just a bleeder valve) that comes with a T-fitting that replaces that connector piece. Even when the valve is fully closed, it bumps up the boost a couple of psi just because the new T-fitting has larger internal diameter and lets the solenoid bleed more air.
Hey BOP did you find that little plastic connector to be a bastard? I used my best needle nose pliars on it and had to exert brute monkey power to get it, mangling it in the process.
JJ
Old 04-22-2002, 04:47 PM   #16
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Is it possible that a lot of people with EBC's have a hard time configuring their systems due to this restrictor limiting the effectiveness of the factory solenoid?
Mike Robinson
2002 WRX Sport Wagon
bluescoobywagon is offline   Reply With Quote
Old 04-22-2002, 04:50 PM   #17
BOP
Member#: 8681
Post
this is pointless
Old 04-22-2002, 04:51 PM   #18
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Wow... mine just popped right out.
It helps to have the engine a little warm to make all the pressure lines pliable.
/Andrew
Old 04-22-2002, 05:32 PM   #19
Tex-WReX2
Guest
Member#:
Yes, a tough little bastard I actually had to sacrifice about 1/4" of the hose, but the connector is intact and is now sitting in my ashtray... just in case.
Mine appears to still be functional. Should have choped the hose instead. Doh (well)
Old 04-22-2002, 05:47 PM   #20
GOT_WRX
Member#: 7241
Didn't anyone think about the timing issues?
It's has been proved by some people on this board that after 15.5 - 16psi, the stock ECU starts pulling timing at certain RPM range. (4-6k?)
Have you done the dyno (to see the HP gain) and datalogging to see if it's working safely?
GOT_WRX is offline   Reply With Quote
Old 04-22-2002, 06:22 PM   #21
webkris
Member#: 70
I sold WRX to buy
Lightbulb Pictures...
Old 04-23-2002, 02:47 AM   #22
Bailey
Member#: 12572
2004 STi
35R is enough
Default boost levels on stock car with restrictor mod
I removed this restrictor in my otherwise stock WRX and replaced it with a 3/16th connector per the instructions on this thread.
This subtle change definitely affected boost regulation a bit. Initially during the first few accelerations with this modification under WOT the boost would peak to 16 or 17 psi and would then roll back to 10 or 12 before steadily but quickly building toward 15. I think the factory ECU was freaked by the extra flow to the solenoid.
The factory ECU must have relearned the proper duty cycles for the solenoid, as this peaky behavior is now absent. My impression is that boost now builds a little more quickly - perhaps more abruptly - than stock and settles at a slightly higher PSI. Before the mod I didn't see levels over 14.5 PSI. Now my Defi peak warning (set at 14.5 PSI) is on while at max boost in 2nd third and fourth gear. As i was driving alone i don't yet know what the boost was throughout the RPM range in each gear.... i could just see the gauge warning going off during the gear. THe levels were checked afterward via the peak hold.
If this mod is pushing the boost a one to 1.5 PSI - as may be indicated by my peak readings - this is a mod for the masses.... almost free.
As always, the butt dyno is prone to error... is there any reason this might be bad?
Bailey is offline   Reply With Quote
Old 04-23-2002, 09:22 AM   #23
6Pack
Member#: 13901
2002 WRX Sedan
Bailey,
Did you do this WITHOUT an ECU reset?
6Pack is offline   Reply With Quote
Old 04-23-2002, 11:36 AM   #24
webkris
Member#: 70
I sold WRX to buy
Thumbs up Cool - A quick mod for EVERYONE!
Cool Bailey,
As we suspected the car would turn it down once it saw 17psi at WOT. I would also suspect that after a few days it will get it down to 14.5 again or sit around 15 as you described.
This is still a valid mod for those of you who don't have Boost Monkey's. You won't always get full boost in every gear, and the boost won't build as quickly as the Monkey (or MBC) does - but - It will build boost slightly faster then stock, and could raise your peak boost 1psi. - It's worth a $0.75 3/16" connector at least.
Enjoy!
Old 04-23-2002, 11:46 AM   #25
whiterabbit
Member#: 16755
will swapping in a 3/16th connector do anything for me if I dont have a boostmonkey?
whiterabbit is offline   Reply With Quote
Should I use my TXS unichip with no ABC or an MBC instead? How will boost behave? rex n effect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-25-2003 12:10 AM
No boost gauge! Is an EBC with boost gauge good enough madmmt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 04:27 PM
For those w/ a BM, are you using an MBC with it as well? KwanDDS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-26-2002 06:55 AM
VF-23 Turbo MBC or Boost Monkey rdrandal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-02-2002 11:46 PM
MBC or Boost Monkey? avsrule414 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-16-2002 06:40 PM
