Old 05-16-2009, 03:49 PM   #1
BGPunk2001
Member#: 46134
Default Anyone know how to release the pistons in the rear calipers of this vehicle?
I was doing a brake job on my wife's 2006 Buick Lacrosse. I replaced the fronts just fine, but I took one of the rear calipers off and I can't compress the piston back into the caliper. After speaking to someone I have been told that because the parking brake system is built into the caliper, there is a ratcheting mechanism that has to be released.
I have the car in pieces and now I can't even get the calipers back onto the old brake pads. The car is currently dead in the water till I cen find out how to do this.
Does anyone know how to release the ratcheting mechanism in the rear brake caliper?
BGPunk2001 is offline   Reply With Quote
Old 05-16-2009, 03:51 PM   #2
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Sometimes on the backside of the caliper there's a bolt/hex you need to spin to release or retract the ratcheter. Well, thats how it was on my Mazda. Check around on the caliper in the back for any sort of unusual looking bolthole?
Kiel is offline   Reply With Quote
Old 05-16-2009, 03:57 PM   #3
The Dayman
Member#: 84815
2015 water n badass.
badass n water.
I know some Nissans the piston has to be twisted back in on the rears. Could be the same.
The Dayman is offline   Reply With Quote
Old 05-16-2009, 03:58 PM   #4
Clothesoff
Member#: 181197
95 K Swiss
Bigger hammer.
Clothesoff is offline   Reply With Quote
Old 05-16-2009, 04:02 PM   #5
gmtech111
Member#: 165754
2006 sti
There is a special tool you need to compress the piston. You can try and turn the piston clockwise with a pair of pliers or turn it by the two notches on the face of the piston and see if it screws in, otherwise you will need the tool.
Note: there is no release, the piston must be screwed back in
Good luck
gmtech111 is offline   Reply With Quote
Old 05-16-2009, 04:02 PM   #6
Kiel
Member#: 133439
2003 WRX
The rear caliper pistons must be screwed back into their bore, using a special tool,
Retract the brake caliper piston (2) into the brake caliper bore. Use a suitable spanner type wrench and turn the piston clockwise until it bottoms out fully in the brake caliper (MacŪ Tools DBC 25 C 2500 MA Disc Brake Caliper Tool Set, or equivalent).
Align the indents on the piston face to match the pin on the back of the inboard brake pads.
OK, so the piston has to be turned with a brake tool (or a wrench) to get them to back in.
Old 05-16-2009, 04:07 PM   #7
BGPunk2001
Member#: 46134
Oh, you guys are ****ing awesome. I was afraid I was about to have to tow it to the brake shop.
I <3 YOU OT!!!!
OT: Anyone know anyplace to buy Perferated Metal in the northwest? Phreaker North West Impreza Club Forum -- NWIC 12 03-06-2009 01:40 PM
Does anyone know how to change shift knob for the legacy? EJ20(GDB) Legacy Forum 10 07-26-2005 11:37 AM
Anyone know how to (DIY) clear lense on the new 04 models ImpreziveRS415 Electrical & Lighting 2 05-03-2004 10:45 PM
anyone know how to prevent copying cds in media player -=C=- Off-Topic 18 04-26-2004 03:08 PM
Anyone know how I can have "Objects in the mirror are losing" done... Need4Boost Interior & Exterior Modification 12 11-21-2002 12:50 AM
