North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 05-16-2009, 11:35 PM   #1
Drewbaru04
Scooby Scammer- Do Not Buy From User
Member#: 167584
Default VF39 BAD SEALS? What are the reccuring effects of bad seals in a turbo?
Like i said bad seals in VF39? trying to get more information on what are the symptoms of this besides low oil level eventually? Any signs to look for besides that, like a little oil in the downpipe, at idle? Possible smoke out the exhaust? Any help is appreciated...
Thanks Drew
Drewbaru04 is offline   Reply With Quote
Old 05-17-2009, 12:08 AM   #2
jason05wrx
Member#: 93398
2008 STI & FXT
well if it is oil and your burning it then it would smoke but that would most probably be coming out of the exhaust side. If it is leaking from the compressor side you would have a lot of oil in the intercooler. It is normal to get some oil in the I/C due to blow by.
jason05wrx is offline   Reply With Quote
Old 05-17-2009, 12:50 AM   #3
K-Dizzle
Member#: 185365
2015 Forester 2.5i
hot side = smokey exhaust
cold side = oil in inlet and intercooler/ FMIC piping
pull the post maf and look at the inlet with a mirror and flashlight, easier to tell if you have an aftermarket colored inlet
or pull the TMIC and look in there
Kyle
K-Dizzle is offline   Reply With Quote
What are the actual effects of high compression? williaty Built Motor Discussion 22 02-12-2009 05:49 PM
What are the common causes of the engine feeling laggy? hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-22-2008 02:34 AM
What are the best sources of info for local Auto-Xs in NoVA? El Capitan Mid Atlantic Impreza Club -- MAIC 4 07-11-2007 09:14 AM
what are the core demensions of the aps dr650 ic? bigworm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-18-2006 12:03 PM
[sorry if posted before...] What are the pros/cons of removing 2-3 cats? luxcar101 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-15-2001 05:30 PM
