Old 05-17-2009, 12:48 AM   #1
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Default What ratio water/coolant do you run? Water Wetter too?
I'll be changing my radiator out pretty soon, and I'm wondering what you track guys run for a water/collant ratio. Currently I'm about 60/40 water/coolant. Not had any problems with the car running hot. When I change out the radiaotr I'm thinking of going to 75/25 and adding a bottle of Water Wetter.
Old 05-17-2009, 01:12 AM   #2
Bueller
Member#: 154696
That depends. For racing we are not allowed to use coolant. Well at least i know NASA doenst allow it. Coolant on track is dangerous. If you drop coolant on track it will create a slippery surface, which will be catastrophic if trailing cars drive over it. Most racers i know, including me, use distilled water and water wetter. Even if youre just a weekend warrior, you should seriously consider not using coolant for track days for safety.
Bueller is offline   Reply With Quote
Old 05-17-2009, 01:20 AM   #3
Prevent
Member#: 149114
50/50 No problems.. I'm sure you know but coolant needs water to lower its freezing point. (you may store your car for winter for all i know... so IDK just tossing that out there)
I've heard about coolant doing this, just never heard of that many people doing only water + water wetter..
**edit**
Oh and in for more info.
Prevent is offline   Reply With Quote
Old 05-17-2009, 02:18 AM   #4
STi-MAN
Member#: 70252
05 STI
blue
I think a 75/25 mix might be ideal for a street/track car. Track only.. distilled and water wetter sounds good.
from what i've heard running straight water, will have a lower boiling point and will be harder on your water pump..
it is true that coolant on the track is bad news.. unless you're running some sanctioned group where there are rules like straight water.. you will still have to deal with other cars that could potentially leak coolant on the track.
These cars are very heat sensitive when you start pushing them, and the ambient temps are high. Also might be a good time to go for a lower temp thermostat.
STi-MAN is offline   Reply With Quote
Old 05-17-2009, 03:21 AM   #5
misterwaterfallin
Member#: 101091
for my race car I use 2 bottles of watter wetter and distilled water. unless you're worried about freezing temps, antifreeze or coolant does nothing in helping temps
misterwaterfallin is offline   Reply With Quote
Old 05-17-2009, 11:02 AM   #6
growling_boxer
Member#: 165744
2000 LGT
2007 STi
i stick with the 50/50, since i drive in < 0F weather every winter, and i haven't wanted to change my coolant out twice a year. my STi is at stock power, so the cooling isn't really much of an issue on track. but i have definitely considered going to no coolant (or much less) for the safety of others on track. i should be running at least 15 days this year if all goes well...3 down so far.
i want to hear if anyone changes their coolant twice a year to handle both track days and winter. and whether having a more diluted mix really makes much of a difference if it starts dumping on track.
growling_boxer is offline   Reply With Quote
Old 05-17-2009, 11:22 AM   #7
MasterKwan
Member#: 98961
2003 WRX
50/50. My temps never go over 180 or so on stock STI power. Anti-freeze has both rust inhibitors, lubricants and seal conditioners on it. If you run pure water (I know you might be required to) you're probably looking at premature cooling system issues. I have been considering pure polypropylene glycol instead of standard coolant though. Boils at 360 degrees and should reduce the chance of detonation.
Old 05-17-2009, 11:48 AM   #8
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
I run 50/50 with a bottle of water wetter on my wagon on track. NASA requires racers to run water, but most regions where freezing temps are likely they allow coolant.
For race cars we usually suggest Water + 2 Bottels of Water Wetter + 1 Cup of Coolant. This will provide enough lube, conditioner and rust inhibitors for a race car.
-mike
Paisan is offline   Reply With Quote
Old 05-17-2009, 11:57 AM   #9
dunk
Member#: 15359
I run water and water wetter.
-Duncan
dunk is offline   Reply With Quote
Old 05-17-2009, 01:36 PM   #10
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I run 75/25 with a bottle of water wetter and a bottle of the subaru coolant conditioner. I think I may drain it and take the coolant out of the equation completely. Last winter my car sat outside but now it has a spot in a heated garage so I don't have to worry about it freezing next offseason.
boost junkie is online now   Reply With Quote
Old 05-17-2009, 01:45 PM   #11
dunk
Member#: 15359
Why do you run the coolant conditioner?
-Duncan
Old 05-17-2009, 02:15 PM   #12
STi-MAN
Member#: 70252
05 STI
blue
-Duncan
It's supposedly makes sure that the seals are in good condition.. or something along those lines. Its recommended at every coolant flush.
Old 05-17-2009, 02:32 PM   #13
MasterKwan
Member#: 98961
2003 WRX
It's required for older subaru engines. I think it's to seal pinhole head gasket leaks. It's just regular cooling system sealer in a subaru bottle.
A lower temp 'stat will have no affect on a car that wants to overheat. Once you're beyond the "full open" temp of the 'stat it doesn't matter what temp it opens at. What I mean is, the 'stat has no impact if your cooling system is too small anyway or compromised with a big front mount or something like that. I have a lower temp 'stat and big radiator. My car doesn't tend to overheat so, the 'stat is keeping the temp at 180 or so. I've also reduced the temp the fans come on so, they come on at 190 instead of 200+.
Old 05-18-2009, 10:17 AM   #14
spazegun2213
Member#: 91208
the '13 Ktm Duke
95% water 5% WW
its a pure race car that spends the winters in a garage... No coolant ever..
spazegun2213 is offline   Reply With Quote
Old 05-18-2009, 12:33 PM   #15
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
50/50 but I'm only a stage II 07 WRX. The car has no cooling issues.
Robbie_B is offline   Reply With Quote
Old 05-20-2009, 09:38 AM   #16
mav1c
Hoodbridge!
Member#: 560
I think I'm going to try 75/20/5 Water/Coolant/WW. I still want to keep some antifreeze in the car since it sits in my unheated garage over the winter. So, what coolant do you guys use?
Old 05-20-2009, 10:52 AM   #17
4porsh
Member#: 12910
2002 WRX/Cobb-APS
+1 for the above-- That what i decided on after running NPG+ for many many years. 75-20-5 working great--oil and water runs cooler then before.
4porsh is offline   Reply With Quote
Old 05-20-2009, 10:55 AM   #18
MasterKwan
Member#: 98961
2003 WRX
You didn't like the NPG+ or was it just cost? I've been thinking about switching to NPG.
Old 05-20-2009, 12:03 PM   #19
mav1c
Hoodbridge!
Member#: 560
So the coolant users...what do you use? Just the old Prestone from Pep Boys, or something else?
Old 05-20-2009, 12:06 PM   #20
STi-MAN
Member#: 70252
05 STI
blue
I just used prestone. like a 80- 20 mix. now.
Old 05-20-2009, 12:12 PM   #21
MasterKwan
Member#: 98961
2003 WRX
All I use is Subaru factory coolant. Other than in emergency's I wouldn't run parts store coolant. There's no standard for coolant like there is for brake or auto transmission fluid so, you don't know if the parts store coolant actually meets all of subaru's requirements. They claim they do but, there's no way to verify it.
Old 05-20-2009, 12:13 PM   #22
mav1c
Hoodbridge!
Member#: 560
Anyone used the Motul Mocool?
Old 05-20-2009, 12:14 PM   #23
STi-MAN
Member#: 70252
05 STI
blue
Does it cost $Texas? Since motul fluids have all went up I've been angry.
It's like motul's water wetter?
Old 05-20-2009, 12:15 PM   #24
mav1c
Hoodbridge!
Member#: 560
$12 from Mach V. Seems to be the cheapeast I can find. Water wetter is what? $9?
Old 05-20-2009, 12:18 PM   #25
STi-MAN
Member#: 70252
05 STI
blue
I might try this out.. i know more local shops that stock motul then redline.
Nice find.
What type of lines do you run? PolarisSnT Water/Methanol Injection, Nitrous & Intercooler Cooling 5 11-21-2007 11:40 PM
What size Exhaust Dia. do you run? Zen Normally Aspirated Powertrain 10 09-09-2003 04:47 PM
Roll call: What header & highflow cat are you using, and do you have a CEL too? BongMan Normally Aspirated Powertrain 35 09-16-2002 08:31 PM
what kind of coolant do you guys use topher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-06-2002 06:32 PM
Auto cross R compounds, what size and tire do you run? STiShawn Motorsports 12 11-27-2001 04:42 PM
