Old 04-22-2002, 11:16 AM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default Performance Testing
Does anyone have some performance number on thier RS-T's?
I'd like to compare my 1.8T with some of the 2.5 and 2.2L turbo's just to see how it's doing.
Here are my times...
0-60: low 8's
30-70: low 8's
For the 0-60, it's from a stop sign that's slightly uphill, but a great place for testing. A total of 3 runs were taken and averaged. I know my car is faster than that, but this is with a slipping clutch and bad 2nd gear syncros. Oh and a 3000 rpm takoff, any more and it's too hard on the stock clutch.
For the 30-70 3 runs were taken in EACH direction on the same stretch of road for a total of 6 runs starting in 2nd gear.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 04-22-2002, 11:22 AM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Me and STiTuner did some "runs" the other night in my car. Using a regular watch, and calling out 60 when it came, I ran about 6.5 seconds, we assume. These numbers probably aren't very accurate, but close enough. STiTuners RS with an intake and exhaust did it in just under 8 seconds.
You know, these numbers probably aren't accurate at all, but what the hell.
(Oh yeah, I'm running about 4 psi)
Graham
Graham is offline   Reply With Quote
Old 04-22-2002, 04:07 PM   #3
subachad
Member#: 8488
Teal
Thanks for the response Graham.
There are so many factors in 0-60 testing to consider which is all the more reason to also do the 30-70 test. For example, I'm not going to drop my clutch at 6k to get a good time, but that would probably get me into the 7's. With an auto, 0-60 is easy... just floor it. My Daewoo for example is about 9.7 5000 miles ago it was around 11 flat
The 30-70 is relatively "low impact" with only 1 shift point. Also the rolling start makes for more consistent times, especially with a 5sp. (make sure to be going a consistant 30mph, not accelerating hard and just starting the timer)
So that said, break out some stop watches and lets share some times.
Chad
93 1.8T
Old 04-22-2002, 04:17 PM   #4
Jewbaru
Member#: 1994
2013 Impreza WRX
I ran a few 0-62mph (100km) runs using my turbo timer. I ran a ~6.5s with another person in the car, and in the rain. I have yet to click off a good run in the dry, with no one in the car.
Jewbaru is offline   Reply With Quote
Old 04-22-2002, 09:36 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
Graham coulda gone faster if he didn't shift like a girl!!!!
JUST KIDDING
I know that torque isn't what our trannies need. But I enjoyed seeing grahams face when I shifted from first to second and when I had my "OK" launch.
Graham just needs to get himself a hardened gearset then we'll try it again
Brad
STiTuner is offline   Reply With Quote
Old 04-22-2002, 10:27 PM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I was shifting worse than a girl (some of them at least). I wouldn't call it bad actually, just SLOW SHIFTING, to preserve the life of my trannsmission. I would say first to second gear took a good second or so.........
We'll do some more runs here soon enough.
Graham
Old 04-22-2002, 11:04 PM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
LOL.. I remember that stop light... red red red.. light turns green and I'm off.. you hear grahams turbo spool up he starts to pull ahead. then PSSSS... and I keep going. I'm getting ready to shift to third and graham is still inbetween 1st and 2nd
Brad
Old 04-25-2002, 02:41 AM   #8
subachad
Member#: 8488
Teal
Anyone else own a stopwatch that can spare a few minutes?
Old 04-25-2002, 03:58 AM   #9
kaos200
Member#: 2692
Im estimating at about 5.3 or so. (Definitely LOW 5s)
I wish I had a full setup to measure like the magazines do!
kaos200 is offline   Reply With Quote
Old 04-25-2002, 03:44 PM   #10
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Well Kaos, don't estimate, prove it!
Grab a friend and a stopwatch and do some runs, I would love to see what you get. Or grab a friend who has a G-Tech, though I don't trust their valididty TOO much.
Graham
Old 04-26-2002, 02:19 AM   #11
kaos200
Member#: 2692
Graham
we did, gtecs suck tho. When it actually launched, it WENT! My friends and my neck hurt from it. (damn clutch gave out now, getting replacement soon, then Ill do some better runs)
(That and the cars Im running (beating) are in that range, so its just another piece to my estimation. But again, I just wish I had those fancy measuring devices!
Old 04-26-2002, 03:06 AM   #12
Jeff 2.5RS
Member#: 1590
2004 Rx8
Shiv tested his car with SCC's equipment a while back when he still had gears, and went from 0-60 in 4.1 seconds , of course that's with hours of tuning involved, I'm assuming my own RS-T wasn't that fast, but a very well tuned RS-T should be able to hit 0-60 in under 5 seconds depending on your annual transmission funds
Jeff 2.5RS is offline   Reply With Quote
Old 04-26-2002, 11:08 AM   #13
Jewbaru
Member#: 1994
2013 Impreza WRX
Thumbs up new time
I did another 0-100km (0-62) run last night. It was dry out, and my gf was in the car filming with me. I managed to click off a 5.71s run. I'm sure with a better launch, and no one else, I could cut some more time off of that.
Old 04-26-2002, 11:08 AM   #14
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
If you have a good tranny (dogs, sychro set, whatever) I thoroughly believe that AT LEAST a second can be shaved off a 0-60 time.
Scootr just posted the other day that he ran a 14.4 in the quarter with his Legacy kit @ 5 psi.
Anyone else?
I still need to do some more runs.......
Graham
Old 04-26-2002, 11:45 AM   #15
Jewbaru
Member#: 1994
2013 Impreza WRX
I'm the car in the Right lane, and that's on 4psi.
Old 04-26-2002, 03:08 PM   #16
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Thats a damn good run for 4 psi Jewbaru. Maybe the Legacy turbo flows a lower CFM per lb. of boost, resulting in less power. That, or he was shifting slow.
Graham
Performance Testing Equipment bcl55 General Community 1 07-16-2006 12:21 AM
Is there a website that does "real world" computer performance tests? -=C=- Off-Topic 0 10-05-2005 01:43 PM
NC - Durham: Safe places to do performance testing? dowroa South East Region Forum 25 02-03-2005 09:04 PM
Some initial performance testing -- Baja T 5 speed ez bturbo Baja Forum 5 03-21-2004 03:39 PM
91 vs. 94 octane performance test robtmc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-18-2003 01:45 PM
