Notices
Old 05-17-2009, 03:44 PM   #1
jaWRX
Member#: 140605
Default 2004 JDM WRX V-Limited EJ205
I thought I'd join my fellow SOCOJ member (DuCash) and post some details of my car. Its an MY04 JDM WRX V-Ltd with an EJ205.
Current mods:
Engine
STI Intercooler
STI 565cc Injectors
VF39/22 hybrid
TGV Delete
MRT Pod Intake
XS Power Semi-Equal Length Headers and up-pipe
eBay 3" Turbo-Back Exhaust
Prodrive 3-Port Boost Control Solonoid
eBay Oil Catch Can
Ecutek with full map-switch, launch control, and per-gear wastegate control
Last dyno at 18psi in 3rd was 266whp and 244wtq
Brakes
DBA4000 vented / slotted rotors
Suspension
STI Genome strut brace
See more info at http://www.socojforum.org/forum/inde...topic,2.0.html
jaWRX is offline   Reply With Quote
Old 05-17-2009, 03:47 PM   #2
jaWRX
Member#: 140605
The following engine is being built for the car:
Engine
USDM EJ25 Block bored out to 100mm
Arias High Compression Pistons
Scat connecting rods
JDM STI cams
Port and Polished heads
MRT Dual-Regulator fuel rails
Brian Crower 1mm oversized valves
Brian Crower Stanless Steel valve springs (capable of 9000rpm)
Brian Crower Titanuim retainers
Denso 750cc top-feed injectors
XS Power FMIC
Exedy Stage 2 Clutch
Power Goal: 350ft/lbs at the wheel at less than 20psi with whatever hp comes with that
The following list shows the mods planned for the rest of the year
Brakes
Wilwood SL6 6-piston calipers (front)
Wilwood 12.9" vented and slotted rotors
Wilwood Steel Braided brake lines
ATE Super Blue brake fluid
Old 05-17-2009, 08:18 PM   #3
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
whats up with the tq in the dyno plot?
FYI: you dont need a built block or any work done to the heads to make 350tq....a well tuned stg2 sti will do that on 93oct. Your setup sounds like overkill for your goals....too much risk and money if you ask me.
Old 05-17-2009, 08:33 PM   #4
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
good to see another west indies folk on tha boards!
adbramsay is offline   Reply With Quote
Old 05-17-2009, 08:55 PM   #5
jaWRX
Member#: 140605
The engine is being built with the eventual aim of reaching 500whp. 350 is the initial goal due to the weakness of the stock 5-MT gearbox. The wick will be turned-up once the PPG gearkit is aquired and installed or a conversion to the STI transmission is done.
Old 05-17-2009, 08:57 PM   #6
jaWRX
Member#: 140605
Thanks dude.
Old 05-18-2009, 12:58 AM   #7
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
When you say VF39/22 hybrid, do you mean a VF39 with a P20 (VF22) hotside?
phlegmon is offline   Reply With Quote
Old 05-18-2009, 09:59 AM   #8
adbramsay
Member#: 152345
whos building your motor?
Old 05-18-2009, 10:46 AM   #9
jaWRX
Member#: 140605
Its the VF39 hotside with the VF22 cold side. It was an experiment that we didn't think would work but I think that 266whp on an internaly stock EJ205 is pretty good so we're happy.
Old 05-18-2009, 10:46 AM   #10
jaWRX
Member#: 140605
Its being built localy by JIM Enterprises, the local Ecutek representative.
He did all the mods to the car so far.
2004 STi Inatke Manifold and 2004 JDM WRX SHORT BLOCK asabater Engine/Power/Exhaust 0 12-05-2006 05:18 PM
2004 JDM WRX heads Skully Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-20-2005 11:02 AM
JDM WRX STi Limited/STi Prodrive garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-24-2004 02:33 PM
2004 JDM WRX wagon seats.. elsanto Private 'Wanted' Classifieds 0 02-25-2004 12:32 AM
In 2002, 2003,2004 jdm wrx, avcs an option? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-11-2003 09:19 PM
