Welcome to the North American Subaru Impreza Owners Club Monday September 1, 2014
Old 05-17-2009, 03:48 PM   #1
sleepy7666
Member#: 211587
Default 98 Subaru Forester Dead...
My mom's 98 Forester is dead... It wont run. It will turn over and just violently shake then sputter out. It died on her while driving. She had it die and struggle to start up last week at Walgreens. When it died at Walgreens it had this darker grey smoke exit the tailpipe. Besides that it was running great.
Its a Manual 98 Forester with 186K on it.
I ran the OBD scanner and came up with
P0106 Pressure sensor circuit range/performance problem (low input)
P0301 Cylinder 1 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P1143 Pressure sensor circuit range/performance (low)
P1507 Idle Control System Malfunction (Fail-safe)
P1520 Cooling fan relay 1 circuit (High)
After searching Nasioc and my own time left to ponder I came up with this to check on later today.
Spark Plugs
Wires
Coil Pack
Injectors
ECU Connections
Timing Belt
(I plan on changing the fuel filter as it needs to be done anyway.)
My dads response to me asking when the timing belt has been changed... "I don't think its been changed since we've owned it"... FML... You think after his 99 VW Passat lost its timing belt (2K earlier than the change period. His appointment was in 2 more days to have it changed) this November and I'm rebuilding the engine this summer. We've owned it for 5 years now. It has 186K now and my mom's put on 70K on it since buying it.
What brand and stock number for spark plugs? Saab's (My car ) are picky and I wonder if Subaru's are the same way?
Any weak pulleys that need to be changed with the timing belt? Idler Pully, Bearings...?
Coil packs... I come from Saab's simple Direct Injection Cassette (It has the coil pack/wires in one giant cassette and its a 5 min swap ... It makes life way easier. Is OEM the only way to go or whats a reputable aftermarket brand and website? Do you replace the wires when you do the coil pack?
Is B12 Chemtool ie Seafoam a good idea to run?
Where is the fuel pressure regulator?
Any thoughts or opinions?
Thanks,
Dylan
sleepy7666 is offline   Reply With Quote
Old 05-17-2009, 09:50 PM   #2
Qman
Member#: 964
'95 work in
progress
Spark Plugs
Wires
Coil Pack
Injectors
ECU Connections
Timing Belt
Thanks,
Dylan
My guess would be a jumped belt. I suppose a coil pack could be going out causing a rich condition. First thing to do is to verify that the belt didn't jump or break. Then run a compression check. Verify that you have compression. Then check for spark at all four plugs. If all that checks out try a known good coil pack.
Qman is offline   Reply With Quote
Old 05-18-2009, 01:31 AM   #3
m0nkeyballz
Member#: 198411
2001 Subaru RSTI
APEX SILVER
headgasket .
m0nkeyballz is offline   Reply With Quote
Old 05-18-2009, 08:31 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Maybe the timing belt jumped a couple teeth (the first time it died) and this time the belt is completely toast or jumped far enough that it won't start anymore?
- Spark plug opinions vary widely. Interestingly enough, in my '97 2.5GT Owner's Manual (same DOHC EJ25D as your Mom's '98 Forester) they list a single spark plug option for the EJ25, but they list 3 or 4 options for the same year EJ22. I've used a variety over the years and have never had any issues with any brand.
- Some guys change out all the idlers when they do the timing belt. With 180k+ miles it probably wouldn't hurt. New tensioner, tensioner pulley, and 2 idlers. Get them through RockAuto.com - exact same parts as the OEM, and they cost about 2/3 as much.
- Coil pack is a no-brainer swap, but is separate from the plug wires. The flat engine design makes replacing both pretty easy.
- Fuel pressure regulator is on the back (firewall) end of the passenger side fuel rail.
Pat Olsen
Old 05-18-2009, 01:30 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you mention replacing the fuel filter, but how is the fuel pump? if you leave a clogged filter in for long, the pump will just have to push all the harder, wearing it out quicker. It may be pumping, but is there enough pressure? Just a thought.
yarrgh is online now   Reply With Quote
Old 05-20-2009, 12:38 AM   #6
sleepy7666
Member#: 211587
Belt is intact and has tension. Cleaned Throttlebody. Replaced Coil Pack and Spark Plugs.... No start... Tested each wire for spark. Has Spark. Check Injectors for pressure... Squirts fuel plenty well...
The only conclusion I can reach is the timing belt jumped time and now needs to be redone... Is this correct? Tomorrow I'm talking to area mechanics on labor cost...
Old 05-20-2009, 11:23 AM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
How bad does the belt look? Heavily cracked? Just a note, the belt is supposed to be replaced every 100k miles.
Old 05-20-2009, 04:43 PM   #8
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Yap. As far as I understand if you have the following things, engine should at least start.
1) Spark (you have),
2) Fuel (you have),
3) Compression
4) Timing (???)
Jerry Xu is offline   Reply With Quote
Old 05-21-2009, 01:36 AM   #9
sleepy7666
Member#: 211587
We have compression too. The belt looks good and was in good shape as far as I could see. It was replaced at 110K miles so it should be good... Should being the key word.
Old 10-10-2009, 12:07 AM   #10
warpspeedwrx
Member#: 36318
2002 wrx
sold :(
Bump for an update. So was it the timing belt?
warpspeedwrx is offline   Reply With Quote
98 Subaru forester MINT part out. SleepingSaabaru Complete Car Part-Out 21 12-16-2013 01:39 PM
FS: 98 subaru forester AWD - winter/daily xtian MWSOC Private Classifieds 14 01-17-2011 08:45 AM
New 98-02 Subaru Forester OEM Rear Cargo Net Torquey Interior/Dressup/Audio & Security 8 12-21-2009 12:24 PM
98 Subaru Forester...swapable engines? SleepingSaabaru Subaru Conversions 18 09-25-2007 10:08 AM
Fs: Subaru Forester Trunk cover screen 98-02 takemetoothemoon Canada Region Private Classifieds 0 01-31-2006 01:41 PM
