Old 05-17-2009, 03:49 PM   #1
GraimeG
Member#: 64865
1993 Impreza L AWD
Default Brake Lights - only work when headlights on
1993 Impreza L AWD
So my brake lights are being kind of finicky of late.
The bulbs are good
The fuse is good
Brake lights only work when headlights are on.
--Even then, the middle light (on rear windshield) sometimes lights up, sometimes not.
If the headlights are off, the brake lights do not work.
I don't think it's the pedal switch because the lights still DO work, just in specific situations. Any ideas with what could be causing the problem?
GraimeG is offline   Reply With Quote
Old 05-17-2009, 04:25 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would first suspect the grounding for the brake lights may be bad. You could prove that by making a jumper and tieing that between a good ground point and the ground side of one of the brake lights.
Old 05-18-2009, 04:01 PM   #3
GraimeG
Member#: 64865
1993 Impreza L AWD
If the grounding points were bad, wouldn't that mean that the brake lights wouldn't work at all?
Old 05-18-2009, 04:19 PM   #4
Cougar4
Member#: 53443
Winestone
The trouble can be intermittent. It depends on the resistance of the bad connection at the time, which can change. By checking to see if the lights are getting power with a test light probe when you step on the brake will show you if the ground is bad or not.
break lights on when headlights on kaio Electrical & Lighting 0 11-23-2007 06:15 PM
Horn only work when pressed on left side? Knightmare69 Service & Maintenance 3 11-20-2006 02:10 PM
Defi Gauges only on when headlights on - Help! JGary Electrical & Lighting 1 07-30-2006 03:33 PM
Greddy gauges only work when lights are off shotoyan Electrical & Lighting 5 06-04-2006 07:26 AM
STI center Brake light only HALF WORKING@!! ohforesti Interior & Exterior Modification 1 05-28-2006 11:38 PM
