Old 05-17-2009, 04:25 PM   #1
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Default Drop in fuel economy and higher revving
Hey, I just did the 30k on my 07 2.5i (air filter, maf cleaning, tranny fluid change, rear diff fluid change, PCV valve change, coolant change and waiting on plug wires to do those) and driving back to school the car was revving a littler higher than usual (about 2700 rpms at 65mph in 5th gear, versus 2500 rpms at 65 mph in 5th gear before) and the coolant temp was a little higher than usual (about 187 degrees versus about 180 before).
This was the first drive (a 200 mile trip) since the maintenance and fuel efficiency is down to 28 (from 30-33 doing the same speed).
I was wondering if anyone had any suggestions on what may be causing this. Does the ECU just need to recalibrate everything because of the new fluids and parts?
Also no CEL lights after the maintenance.
As a note, the tranny fluid is filled to the full fill level and I put fluid into the rear diff until it started coming out the fill hole. I bought 5 quarts and I still have a quart of fluid left. The specs say 3.7 quarts in the front and .8 in the back so shouldn't I be down more? I did the change on level ground too.
Hotsho111 is offline   Reply With Quote
Old 05-17-2009, 04:45 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
reset the ecu to help it learn with the new parts.
yarrgh is online now   Reply With Quote
Old 05-17-2009, 05:22 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
how can the gearing change, that makes no sense. in a given gear the engine speed will always be the same at any given RPM unless there is slippage in the clutch or the gear ratio has physically changed.
You may not be able to get 100% of the old fluid out of the case/diff so it might not accept the full capacity since it has a little bit left in it. I have never put the full 5 qts of engine oil in, like the main manual says is the total capacity, but about 4-4.3 qts like they main manual says is the filling amount at oil change. The maint manual doesn't give a "@ fluid change" capacity for trans/diff fluid, only total capacity for trans/diff fluid so i would expect not to be able to get 100% of the capacity back in, especially for the trans.
GrundleJuice is online now   Reply With Quote
Old 05-18-2009, 01:00 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
This.
Except where he should have said "In a given gear, the engine speed will always be the same for a given vehicle speed". I know that's what he was trying to type though.
As far as the mileage change, there's a huge number of things that could be happening, most of them falling under the heading of "random chance". You need a BUNCH of tanks of gas to make any kind of a guess at a real change in fuel economy.
Old 05-18-2009, 01:41 PM   #5
Button
Member#: 20620
2006 Outback 2.5 i
Willow Green Opal
LMAO!-!-!
Button is offline   Reply With Quote
Old 05-18-2009, 02:49 PM   #6
Back Road Runner
Member#: 60082
2004 Forester STI
^ Yeah, I think that's cute too.
You won't get all the fluid out of the tranny and rear diff. Athough it's labeled at 3.7 and 0.8 quart, you just won't get all of the old fluid out. Expect to have some left over.
Ditto on rpm change -> slipping clutch. Generally you can make it slip, not just showing a little different rpm value. However, the rpm and mph is linked, so it's not like they can automatically vary.
Old 05-18-2009, 03:17 PM   #7
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Any suggestions on why the temp is up?
Old 05-18-2009, 07:31 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Yes. Thank you, sir.
Old 05-19-2009, 12:22 PM   #9
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Ok, so I was wrong about the rpm's, but does anyone know why the car is running hotter?
Old 05-19-2009, 06:32 PM   #10
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
different coolant maybe? less coolant? less efficient coolant? little air in the system? Or making more power so more heat is a byproduct. the 7 degrees higher isnt much... i would just watch it and see if it keeps going up a bit over time then do something about it. Im about to do this same thing, but also will do plugs and not wires. Your fuel economy seem to be normalizing to what you had been getting before?
Old 05-19-2009, 06:43 PM   #11
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I used the OEM coolant. I think the regular idle temp is a little above the first notch, and mine is right in the middle of the first and second notch.
Before, on this same trip (between home and school), doing the same speed I was getting 30-33mpg (30 doing the whole trip at 70, 33 doing the whole trip at 65, and I went back at like 67 and got 28. This was the first long trip since doing the 30k
Old 05-19-2009, 07:25 PM   #12
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ As far as fuel economy goes, it's too little of a difference to tell. Wind by itself can easily cause a +/- 3mpg change. Add to that the relative altitude drop or raise, humidity, and temperature. Unless you anally logged the mpg and average speed using a ScanGauge or something, you simply can't tell.
Temperature: did the thermostat get changed? Maybe your old coolant was all yucky and full of gunk, with a little of a smaller flow around the thermometer, which caused a lower reading
Old 05-19-2009, 07:41 PM   #13
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
The thermostat didn't get changed. Taking an image from STI Sibb at iwsti, the normal temp he has pictured is what mine was at:
and now it is slightly above the middle of between the two so it is noticeable (also the temp gauge I had showed the higher temp too)
Old 05-20-2009, 01:04 PM   #14
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Isn't the temp gauge on the dash a "dummy" sensor?
formula91 is offline   Reply With Quote
Old 05-20-2009, 01:15 PM   #15
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ as hell it is.
According to scangauge, under normal driving the temp ALWAYS cycles in between 85 and 93C (185 and 200F). It's just the cycle of the thermostat. Well guess what? the needle doesn't move at ALL.
Old 05-20-2009, 05:05 PM   #16
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I may be inaccurate, but it was always at the same reading before I changed the coolant, and now it is consistently higher since then
Old 05-22-2009, 09:17 PM   #17
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
any other suggestions on why the temp might be up?
Old 05-22-2009, 09:34 PM   #18
Un0RiGiNaL
Member#: 189748
driving back to school and 65mph doesnt sound good together
Un0RiGiNaL is offline   Reply With Quote
Old 05-22-2009, 09:36 PM   #19
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Ya, its an extremely boring drive. I did it because on the way home (I really didn't want to get there fast) I wanted to see what kinda fuel economy I could get.
I did it on the way back to see if it would change after doing the 30k
As a side note, I don't suggest anyone drive the speed limit on highways...its probably the most dangerous thing you can do. If you want to know why, try it for yourself
Old 05-22-2009, 10:01 PM   #20
Un0RiGiNaL
Member#: 189748
This makes no sense
Old 05-22-2009, 10:08 PM   #21
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Try it, everyone else on the road is going at least 10 mph faster then you, and the one person on the highway that is going slower than you, when you have to pass, is like threading a needle (especially if you maintain the speed limit and don't go faster to pass)
You also always end up in people's blind spots because you're maintaining 65 and when you go to pass that one person that's going slower, for some reason, they ALWAYS speed up when you are on the side of them putting you in their blind spot. Mean while, those 20 or so cars that you have backed up are getting annoyed that they have nowhere to go because you're maintaining the speed limit, so you are essentially a rolling roadblock now.
You also notice how inconsistently people drive, speeding up and slowing down all the time
Maybe its just Massachusetts drivers lol
Again, try going on a 100 mile trip with cruise at the speed limit
Old 05-23-2009, 12:49 AM   #22
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
5 qts? of engine oil?
no manual states that .
watchunglava is offline   Reply With Quote
Old 05-23-2009, 12:52 AM   #23
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Not engine oil tranny oil: 3.7 quarts in the front tranny/diff and .8 quarts in the rear diff
Old 05-23-2009, 12:53 AM   #24
watchunglava
Member#: 168862
yea thats 4.5.
Old 05-23-2009, 12:55 AM   #25
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
and???
Looking to Purchase a 06 WRX Need some Info on SoCal Fuel Economy and What to look 4 SentientByDesign Newbies & FAQs 30 11-18-2009 03:20 PM
Transportation Department Proposes Increas In Fuel Economy Standards for 2011-2015 medamullet News & Rumors 5 04-25-2008 10:38 PM
Very poor fuel economy and gas in my oil pan phibs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-26-2007 09:24 PM
New Drop in fuel pump for 600whp AZScoobie Built Motor Discussion 318 06-26-2007 11:49 AM
Mazda UK enters Mazda 6 MPS & RX-8 in fuel economy marathon NYCshopper Non-Subaru News & Rumors 6 10-13-2006 11:12 AM
