Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 05-17-2009, 06:31 PM   #1
SethV
Member#: 121995
Default car runs horrible with maf plugged in but fine when not
Like it says I have a 2004 sti and the car ran fin all of a sudden after putting stock tgvs in and 2 trips the car started acting up it woud start fine and after about 20 seconds the idle dips down and the car has no throttle responce starts sputtiering and pinging and will shut off on its own after a few more seconsds
But if I unplug the maf the car runs completly smooth. I tried to use a friend maf off another 04 sti and did the same thing.
I have 1 cel for tgv having low input due to me cutting the wires on accident installing the tgvs butt conected them just to plug the sensor in.
Thanks.
Seth.
SethV is offline   Reply With Quote
Old 05-17-2009, 06:44 PM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
Sounds like you have a post maf leak.
MartinSTi05 is offline   Reply With Quote
Old 05-17-2009, 08:48 PM   #3
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
You need to either borrow or build a pressure tester and find the leak. Do a search and find some picts. I think I spent about $25 on the one that I built and got all the parts from Home Depot. One word of advice, do NOT overpressure your motor. In my opinion, the system should only see about 10psi with the motor not running so that you dont blow out your oil seals.
dexterous is offline   Reply With Quote
Old 05-17-2009, 09:14 PM   #4
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
May also be a bad MAF sensor.
bcblues is offline   Reply With Quote
Old 05-17-2009, 11:18 PM   #5
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Could a very dirty maf sensor cause this also? I don't know. It was just an idea.
ThreeEleven is offline   Reply With Quote
Old 06-12-2009, 07:06 AM   #6
05wrx09
Member#: 204111
2005 WRX
Bump for followup.
Did you ever find the culprit? Just curious because although I'm not experiencing your idle issue and I haven't tried removing the MAF altogether, I'm told I might have a Post-MAF leak because of my AF #s or whatever. They're way too high usually, so I forget if that means I'm running lean or rich, I forget. Anyways, I've tried the DIY boost leak tester and couldn't find any leaks. I had my oil cap off though...
05wrx09 is offline   Reply With Quote
Old 06-12-2009, 11:35 AM   #7
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's a dirty or dead MAF or a leak after the MAF
Old 06-14-2009, 06:43 PM   #8
JasonOJordan
Member#: 213982
2002 Impreza WRX
Im having the same issue how ever my car runs/idles fine up to 5500 rpm then it gets kinda a sputtering noise and it is very had 2 get past that point and it seems to have no power. I unpluged my maf and obviously had no power but it eaisly moved past the 5500 rpm mark with no notable change in engine noise. i had the maf sensor out about 2 weeks ago and cleaned it because when i got the car the filter that was on there was so pluged even after washing it for almost a half an hr you could still not see through it. when i pulled my maf sensor it was very much caked in dirt. After cleaning it fixed another issue but not this one is it possible because of the amount of dirt it is faulty? or would you suspect a leak somewhere?
Also just a side note i also have stock tgv's and am getting a circuit 2 low
JasonOJordan is offline   Reply With Quote
Old 06-14-2009, 07:09 PM   #9
Longarm
Member#: 132140
'11 WRX Hatch
SSM
+1+2+3+4+5+6+7+8+9 - car ran fine prior to install, accid. cut wires while install of stock part. Did you reset ecu ? the car will run fine with leak if you disconnect maf, so if it runs fine it sounds to me like a leak.. good luck
Longarm is offline   Reply With Quote
Old 06-14-2009, 07:29 PM   #10
Got Boost?
Member#: 113096
06 sti
hopefully you did not over tighten the manifold to the tgv housings as they require very little torque...8inch/lbs if I remember right. My dealer hooked me up and did this when I broke a ring land, a cracked tgv housing is what I got for no extra charge
It has to be a leak after the maf as mentioned, especially since you tried a known good maf in your car and got the same result. also, you might wanna check the turbo inlet, as you were just working around it.
Got Boost? is offline   Reply With Quote
Old 06-15-2009, 01:46 AM   #11
JasonOJordan
Member#: 213982
2002 Impreza WRX
where are some common leak areas that would cause a high rpm sputter that is no longer there with the maf unplugged?
Old 06-15-2009, 11:42 AM   #12
Member#: 51961
2005 STi
2012 WRX
a tear in the turbo inlet
Old 06-15-2009, 05:19 PM   #13
JasonOJordan
Member#: 213982
2002 Impreza WRX
mine had one awhile back but i fixed it. Also im fairly certain that its the MAF sensor causing the issue as my CEL came on today maf sensor circut low.
Old 06-15-2009, 10:21 PM   #14
bcblues
Member#: 17256
04 STi
Almost certainly a MAF sensor or a post MAF leak.
Urgent help needed: Car will not run with MAF plugged in. Carter Alaskan Impreza Club Forum -- AKIC 11 02-25-2009 10:49 PM
Need urgent help: Car will not run with MAF plugged in. Carter Normally Aspirated Powertrain 10 02-25-2009 10:47 PM
Turned the car on before putting MAF plug in Mdub Newbies & FAQs 2 08-01-2007 01:25 AM
Bad not to have exhaust heat shields? my cars running horrible. rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-07-2005 11:34 PM
Car runs better without IAC plugged in?!?! blaznc Normally Aspirated with bolt-on Forced Induction Powertrain 15 07-13-2004 09:53 PM
