Old 05-17-2009, 06:48 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default Anti-Seize On O2 Sensor, Bad?
I have been having idle issues lately, with front O2 Sensor and IACV CE lights. I am running aftermarket headers, so I did the spacer mod on the O2 sensor, and got a smudge of anti-seize on the sensor itself.
I am getting surging at idle now and wanted to know if it's the spacing, anti-seize, or a dead sensor.
I reset the ECU.
Bry.
BrysImpreza is offline   Reply With Quote
Old 05-17-2009, 07:06 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Try cleaning the IACV.
PhilSine is offline   Reply With Quote
Old 05-17-2009, 07:11 PM   #3
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Did a few times, no difference. It's the probe type sensor, not the reservoir like the WRX one.
Old 05-18-2009, 01:57 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I reset the ECU.
Bry.
I see what you did there.
Undo it.
Old 05-19-2009, 12:16 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
Undo it.
So if Will's observations are consistent with what you did then are we to assume that you did the O2 sensor spacer mod on the front O2 sensor?
If so, good catch Will, I missed that when reading through it.
The front O2 sensor stays in the flow of the exhaust like it should be.
The rear O2 sensor is the one to get out of the exhaust flow as to trick it into reding normal. I did this with my first NA catless set up and it worked.
Old 05-19-2009, 12:22 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That statement needs modified a bit.
On all years, the front O2 sensor MUST be fully inserted into the exhaust stream, as it would be stock.
On 04 and older cars, the rear O2 sensor can be partially or fully removed from the exhaust stream.
On 05 and newer cars, the rear O2 sensor MUST be fully inserted into the exhaust stream as it would be stock.
Old 05-19-2009, 09:25 AM   #7
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Really? So, do you have to disable the resulting code, or can you otherwise work around it? I'm fighting this particular battle at the moment, and my car is getting P0420s, but they are usually clearing themselves in a day or so. The extender has not helped. With the code coming on and off regularly, I fear that my ECU is not really learning what it needs to...
This is with the OBX header on an '05 Saabaru NA car, and yeah, my exhaust kills my dandelions for me (no cats).
Boxer4Dad is offline   Reply With Quote
Old 05-19-2009, 02:20 PM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Exactly, at the moment, the only way to deal with the P0420 code on 05+ cars is to disable it in software. All of the mechanical and electric "tricks" to defeat the CEL result in fueling errors.
Old 05-19-2009, 10:43 PM   #9
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Well, thx. Not what I wanted to hear, but based on my experience, I'd agree. It IS close, though, because sometimes it will clear itself up. Guess Ima hafta get into the "Tactrix club", now, too.
Dielectric and anti-seize on NGK's wiz561 Service & Maintenance 15 05-14-2010 04:17 PM
Bad O2 sensor bad for your car? kodakeos Normally Aspirated Powertrain 3 09-23-2004 09:39 AM
Do I need to put anti-seize on downpipe and uppipe bolts? Stou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 01-21-2004 05:04 AM
o2 sensor bad pdxscoob North West Impreza Club Forum -- NWIC 3 02-26-2003 02:08 PM
make sure to use anti seize on tein coilovers suberboy Brakes, Steering & Suspension 5 07-10-2001 12:11 PM
